[QGIS Commit] r15306 - in trunk/qgis/src: app app/legend ui
svn_qgis at osgeo.org
Tue Mar 1 19:35:38 EST 2011
Author: jef
Date: 2011-03-01 16:35:38 -0800 (Tue, 01 Mar 2011)
New Revision: 15306
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
implement #3535
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2011-03-01 12:58:56 UTC (rev 15305)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2011-03-02 00:35:38 UTC (rev 15306)
@@ -522,7 +522,19 @@
void QgsLegend::mouseDoubleClickEvent( QMouseEvent* e )
- QgisApp::instance()->layerProperties();
+ QSettings settings;
+ switch( settings.value( "/qgis/legendDoubleClickAction", 0 ).toInt() )
+ case 0:
+ QgisApp::instance()->layerProperties();
+ break;
+ case 1:
+ QgisApp::instance()->attributeTable();
+ break;
+ default:
+ break;
void QgsLegend::handleRightClickEvent( QTreeWidgetItem* item, const QPoint& position )
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2011-03-01 12:58:56 UTC (rev 15305)
+++ trunk/qgis/src/app/qgisapp.h 2011-03-02 00:35:38 UTC (rev 15306)
@@ -394,6 +394,9 @@
//! open the properties dialog for the currently selected layer
void layerProperties();
+ //! show the attribute table for the currently selected layer
+ void attributeTable();
//! mark project dirty
void markDirty();
@@ -716,9 +719,6 @@
//! shows label settings dialog (for labeling-ng)
void labeling();
- //! show the attribute table for the currently selected layer
- void attributeTable();
//! starts/stops editing mode of a layer
bool toggleEditing( QgsMapLayer *layer, bool allowCancel = true );
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2011-03-01 12:58:56 UTC (rev 15305)
+++ trunk/qgis/src/app/qgsoptions.cpp 2011-03-02 00:35:38 UTC (rev 15306)
@@ -282,6 +282,8 @@
cbxCreateRasterLegendIcons->setChecked( settings.value( "/qgis/createRasterLegendIcons", true ).toBool() );
leNullValue->setText( settings.value( "qgis/nullValue", "NULL" ).toString() );
+ cmbLegendDoubleClickAction->setCurrentIndex( settings.value( "/qgis/legendDoubleClickAction", 0 ).toInt() );
//set the color for selections
int myRed = settings.value( "/qgis/default_selection_color_red", 255 ).toInt();
int myGreen = settings.value( "/qgis/default_selection_color_green", 255 ).toInt();
@@ -568,32 +570,33 @@
settings.setValue( "/qgis/enable_render_caching", chkUseRenderCaching->isChecked() );
settings.setValue( "/qgis/use_qimage_to_render", !( chkUseQPixmap->isChecked() ) );
settings.setValue( "/qgis/use_symbology_ng", chkUseSymbologyNG->isChecked() );
- settings.setValue( "qgis/capitaliseLayerName", capitaliseCheckBox->isChecked() );
- settings.setValue( "qgis/askToSaveProjectChanges", chbAskToSaveProjectChanges->isChecked() );
- settings.setValue( "qgis/warnOldProjectVersion", chbWarnOldProjectVersion->isChecked() );
- settings.setValue( "qgis/nullValue", leNullValue->text() );
+ settings.setValue( "/qgis/legendDoubleClickAction", cmbLegendDoubleClickAction->currentIndex() );
+ settings.setValue( "/qgis/capitaliseLayerName", capitaliseCheckBox->isChecked() );
+ settings.setValue( "/qgis/askToSaveProjectChanges", chbAskToSaveProjectChanges->isChecked() );
+ settings.setValue( "/qgis/warnOldProjectVersion", chbWarnOldProjectVersion->isChecked() );
+ settings.setValue( "/qgis/nullValue", leNullValue->text() );
//overlay placement method
int overlayIndex = mOverlayAlgorithmComboBox->currentIndex();
if ( overlayIndex == 1 )
- settings.setValue( "qgis/overlayPlacementAlgorithm", "Chain" );
+ settings.setValue( "/qgis/overlayPlacementAlgorithm", "Chain" );
else if ( overlayIndex == 2 )
- settings.setValue( "qgis/overlayPlacementAlgorithm", "Popmusic tabu chain" );
+ settings.setValue( "/qgis/overlayPlacementAlgorithm", "Popmusic tabu chain" );
else if ( overlayIndex == 3 )
- settings.setValue( "qgis/overlayPlacementAlgorithm", "Popmusic tabu" );
+ settings.setValue( "/qgis/overlayPlacementAlgorithm", "Popmusic tabu" );
else if ( overlayIndex == 4 )
- settings.setValue( "qgis/overlayPlacementAlgorithm", "Popmusic chain" );
+ settings.setValue( "/qgis/overlayPlacementAlgorithm", "Popmusic chain" );
else
- settings.setValue( "qgis/overlayPlacementAlgorithm", "Central point" );
+ settings.setValue( "/qgis/overlayPlacementAlgorithm", "Central point" );
if ( cmbTheme->currentText().length() == 0 )
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2011-03-01 12:58:56 UTC (rev 15305)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2011-03-02 00:35:38 UTC (rev 15306)
@@ -59,9 +59,9 @@
<property name="geometry">
<rect>
<x>0</x>
- <y>-369</y>
- <width>746</width>
- <height>827</height>
+ <y>0</y>
+ <width>744</width>
+ <height>817</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_12">
@@ -168,8 +168,8 @@
<property name="title">
<string>Application</string>
</property>
- <layout class="QGridLayout" name="gridLayout">
- <item row="0" column="0">
+ <layout class="QVBoxLayout" name="verticalLayout_2">
+ <item>
<layout class="QHBoxLayout" name="horizontalLayout_3">
<item>
<widget class="QLabel" name="textLabel1_4">
@@ -211,7 +211,7 @@
</item>
</layout>
</item>
- <item row="1" column="0">
+ <item>
<layout class="QHBoxLayout" name="horizontalLayout_7">
<item>
<widget class="QLabel" name="textLabel1_5">
@@ -248,77 +248,115 @@
</item>
</layout>
</item>
- <item row="2" column="0">
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_8">
+ <item>
+ <widget class="QLabel" name="label_15">
+ <property name="text">
+ <string>Double click action in legend</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_6">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QComboBox" name="cmbLegendDoubleClickAction">
+ <item>
+ <string>Open layer properties</string>
+ </property>
+ </item>
+ <item>
+ <string>Open attribute table</string>
+ </property>
+ </item>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
<widget class="QCheckBox" name="capitaliseCheckBox">
<string>Capitalise layer names in legend</string>
</property>
</widget>
</item>
- <item row="3" column="0">
+ <item>
<widget class="QCheckBox" name="cbxLegendClassifiers">
<string>Display classification attribute names in legend</string>
</property>
</widget>
</item>
- <item row="4" column="0">
+ <item>
<widget class="QCheckBox" name="cbxCreateRasterLegendIcons">
<string>Create raster icons in legend</string>
</property>
</widget>
</item>
- <item row="5" column="0">
+ <item>
<widget class="QCheckBox" name="cbxHideSplash">
<string>Hide splash screen at startup</string>
</property>
</widget>
</item>
- <item row="6" column="0">
+ <item>
<widget class="QCheckBox" name="cbxShowTips">
<string>Show tips at start up</string>
</property>
</widget>
</item>
- <item row="7" column="0">
+ <item>
<widget class="QCheckBox" name="cbxIdentifyResultsDocked">
<string>Open identify results in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item row="8" column="0">
+ <item>
<widget class="QCheckBox" name="cbxSnappingOptionsDocked">
<string>Open snapping options in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item row="9" column="0">
+ <item>
<widget class="QCheckBox" name="cbxAttributeTableDocked">
<string>Open attribute table in a dock window (QGIS restart required)</string>
</property>
</widget>
</item>
- <item row="10" column="0">
+ <item>
<widget class="QCheckBox" name="cbxAddPostgisDC">
<string>Add PostGIS layers with double click and select in extended mode</string>
</property>
</widget>
</item>
- <item row="11" column="0">
+ <item>
<widget class="QCheckBox" name="cbxAddNewLayersToCurrentGroup">
<string>Add new layers to selected group</string>
</property>
</widget>
</item>
- <item row="12" column="0">
+ <item>
<layout class="QHBoxLayout" name="horizontalLayout_5">
<item>
<widget class="QLabel" name="textLabel1_7">
@@ -360,7 +398,7 @@
</item>
</layout>
</item>
- <item row="13" column="0">
+ <item>
<layout class="QHBoxLayout" name="horizontalLayout_6">
<item>
<widget class="QLabel" name="label_14">
@@ -387,7 +425,7 @@
</item>
</layout>
</item>
- <item row="14" column="0">
+ <item>
<widget class="QGroupBox" name="groupBox_4">
<string>Plugin paths</string>
@@ -461,8 +499,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>479</height>
+ <width>666</width>
+ <height>466</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_8">
@@ -632,8 +670,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>500</height>
+ <width>612</width>
+ <height>469</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_4">
@@ -912,8 +950,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>762</width>
- <height>458</height>
+ <width>310</width>
+ <height>86</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_10">
@@ -987,8 +1025,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>462</height>
+ <width>838</width>
+ <height>432</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_13">
@@ -1317,8 +1355,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>531</height>
+ <width>416</width>
+ <height>568</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_15">
@@ -1413,8 +1451,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>552</height>
+ <width>519</width>
+ <height>567</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_17">
@@ -1504,8 +1542,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>548</height>
+ <width>407</width>
+ <height>508</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_20">
