[QGIS Commit] r15310 - in trunk/qgis: python/core src/core
src/gui/symbology-ng
svn_qgis at osgeo.org
Wed Mar 2 09:45:49 EST 2011
Author: mhugent
Date: 2011-03-02 06:45:49 -0800 (Wed, 02 Mar 2011)
New Revision: 15310
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h
trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp
Add uniqueValues() method for vector layer. Fixes #3528
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2011-03-02 10:16:18 UTC (rev 15309)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2011-03-02 14:45:49 UTC (rev 15310)
@@ -549,6 +549,13 @@
@note public and static from version 1.4 */
static void drawVertexMarker( double x, double y, QPainter& p, QgsVectorLayer::VertexMarkerType type, int vertexSize );
+ /**Returns unique values for column
+ @param index column index for attribute
+ @param uniqueValues out: result list
+ @limit maximum number of values to return (-1 if unlimited)
+ @note: this method was added in version 1.7*/
+ void uniqueValues( int index, QList<QVariant>& uniqueValues, int limit );
public slots:
/** Select feature by its ID, optionally emit signal selectionChanged() */
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2011-03-02 10:16:18 UTC (rev 15309)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2011-03-02 14:45:49 UTC (rev 15310)
@@ -4942,6 +4942,67 @@
+void QgsVectorLayer::uniqueValues( int index, QList<QVariant> &uniqueValues, int limit )
+ uniqueValues.clear();
+ if ( !mDataProvider )
+ return;
+ int maxProviderIndex;
+ QgsVectorLayerJoinBuffer::maximumIndex( mDataProvider->fields(), maxProviderIndex );
+ if ( index <= maxProviderIndex && !mEditable ) //a provider field
+ return mDataProvider->uniqueValues( index, uniqueValues, limit );
+ else // a joined field?
+ if ( mJoinBuffer )
+ int indexOffset; //offset between layer index and joined provider index
+ const QgsVectorJoinInfo* join = mJoinBuffer->joinForFieldIndex( index, maxProviderIndex, indexOffset );
+ if ( join )
+ QgsVectorLayer* vl = dynamic_cast<QgsVectorLayer*>( QgsMapLayerRegistry::instance()->mapLayer( join->joinLayerId ) );
+ if ( vl && vl->dataProvider() )
+ return vl->dataProvider()->uniqueValues( index - indexOffset, uniqueValues, limit );
+ //the layer is editable, but in certain cases it can still be avoided going through all features
+ if ( mDeletedFeatureIds.size() < 1 && mAddedFeatures.size() < 1 && !mDeletedAttributeIds.contains( index ) && mChangedAttributeValues.size() < 1 )
+ //we need to go through each feature
+ QgsAttributeList attList;
+ attList << index;
+ select( attList, QgsRectangle(), false, false );
+ QgsFeature f;
+ QVariant currentValue;
+ QHash<QString, QVariant> val;
+ while ( nextFeature( f ) )
+ currentValue = f.attributeMap()[index];
+ val.insert( currentValue.toString(), currentValue );
+ if ( limit >= 0 && val.size() >= limit )
+ break;
+ uniqueValues = val.values();
void QgsVectorLayer::stopRendererV2( QgsRenderContext& rendererContext, QgsSingleSymbolRendererV2* selRenderer )
mRendererV2->stopRender( rendererContext );
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2011-03-02 10:16:18 UTC (rev 15309)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2011-03-02 14:45:49 UTC (rev 15310)
@@ -638,7 +638,14 @@
/**Caches joined attributes if required (and not already done)*/
void createJoinCaches();
+ void uniqueValues( int index, QList<QVariant> &uniqueValues, int limit = -1 );
public slots:
void select( int featureId, bool emitSignal = true );
Modified: trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h
--- trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h 2011-03-02 10:16:18 UTC (rev 15309)
+++ trunk/qgis/src/core/qgsvectorlayerjoinbuffer.h 2011-03-02 14:45:49 UTC (rev 15310)
@@ -66,6 +66,13 @@
const QList< QgsVectorJoinInfo >& vectorJoins() const { return mVectorJoins; }
+ /**Finds the vector join for a layer field index.
+ @param index this layers attribute index
+ @param maxProviderIndex maximum attribute index of the vectorlayer provider
+ @param indexOffset out: offset between layer index and original provider index
+ @return pointer to the join if the index belongs to a joined field, otherwise 0 (possibily provider field or added field)*/
+ const QgsVectorJoinInfo* joinForFieldIndex( int index, int maxProviderIndex, int& indexOffset ) const;
/** Helper function to find out the maximum index of a field map
@return true in case of success, otherwise false (e.g. empty map)*/
static bool maximumIndex( const QgsFieldMap& fMap, int& index );
@@ -91,13 +98,6 @@
@param attributeIndexOffset index offset to get from join layer attribute index to layer index*/
void addJoinedFeatureAttributes( QgsFeature& f, const QgsVectorJoinInfo& joinInfo, const QString& joinFieldName, const QVariant& joinValue,
const QgsAttributeList& attributes, int attributeIndexOffset );
- /**Finds the vector join for a layer field index.
- @param index this layers attribute index
- @param maxProviderIndex maximum attribute index of the vectorlayer provider
- @param indexOffset out: offset between layer index and original provider index
- @return pointer to the join if the index belongs to a joined field, otherwise 0 (possibily provider field or added field)*/
- const QgsVectorJoinInfo* joinForFieldIndex( int index, int maxProviderIndex, int& indexOffset ) const;
#endif // QGSVECTORLAYERJOINBUFFER_H
Modified: trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp 2011-03-02 10:16:18 UTC (rev 15309)
+++ trunk/qgis/src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp 2011-03-02 14:45:49 UTC (rev 15310)
@@ -10,8 +10,6 @@
#include "qgssymbolv2selectordialog.h"
#include "qgsvectorlayer.h"
-#include "qgsvectordataprovider.h" // for uniqueValues
#include <QMenu>
#include <QMessageBox>
#include <QStandardItemModel>
@@ -245,7 +243,7 @@
QString attrName = cboCategorizedColumn->currentText();
int idx = mLayer->fieldNameIndex( attrName );
QList<QVariant> unique_vals;
- mLayer->dataProvider()->uniqueValues( idx, unique_vals );
+ mLayer->uniqueValues( idx, unique_vals );
//DlgAddCategories dlg(mStyle, createDefaultSymbol(), unique_vals, this);
//if (!dlg.exec())
