[QGIS Commit] r15369 - in branches/raster-providers/src/providers: gdal grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Mar 6 14:33:54 EST 2011
Author: rblazek
Date: 2011-03-06 11:33:54 -0800 (Sun, 06 Mar 2011)
New Revision: 15369
   branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
   branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
   branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
   branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
clean up
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp	2011-03-06 19:12:00 UTC (rev 15368)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp	2011-03-06 19:33:54 UTC (rev 15369)
@@ -66,9 +66,6 @@
   // TODO: add signals to providers
   static double dfLastComplete = -1.0;
-  //QgsRasterLayer * mypLayer = ( QgsRasterLayer * ) pProgressArg;
   if ( dfLastComplete > dfComplete )
     if ( dfLastComplete >= 1.0 )
@@ -195,10 +192,6 @@
   mHasPyramids = GDALGetOverviewCount( myGDALBand ) > 0;
-  //populate the list of what pyramids exist
-  // TODO
-  //buildPyramidList();
   // Get the layer's projection info and set up the
   // QgsCoordinateTransform for this layer
   // NOTE: we must do this before metadata is called
@@ -277,17 +270,14 @@
       switch ( srcDataType( i ) ) {
         case QgsRasterDataProvider::Byte:
           // Use longer data type to avoid conflict with real data
-          //myNoDataValue = 255.0;
           myNoDataValue = -32768.0;
           mGdalDataType.append( GDT_Int16 );
           break;
         case QgsRasterDataProvider::Int16:
-          //myNoDataValue = -32768.0;
           myNoDataValue = -2147483648.0;
           mGdalDataType.append( GDT_Int32 );
           break;
         case QgsRasterDataProvider::UInt16:
-          //myNoDataValue = 65535.0;
           break;
@@ -384,14 +374,7 @@
   GDALClose( mGdalDataset );
   mGdalDataset = NULL;
-  //mHasPyramids = false;
-  //mPyramidList.clear();
-  //mRasterStatsList.clear();
 QString QgsGdalProvider::metadata()
@@ -543,42 +526,24 @@
 void QgsGdalProvider::readBlock( int theBandNo, QgsRectangle  const & theExtent, int thePixelWidth, int thePixelHeight, void *theBlock )
-  return readBlockOld( theBandNo, theExtent, thePixelWidth, thePixelHeight, QgsCoordinateReferenceSystem(), QgsCoordinateReferenceSystem(), theBlock );
-void QgsGdalProvider::readBlockOld( int theBandNo, QgsRectangle  const & theExtent, int thePixelWidth, int thePixelHeight, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *theBlock )
   QgsDebugMsg( "thePixelWidth = "  + QString::number( thePixelWidth ) );
   QgsDebugMsg( "thePixelHeight = "  + QString::number( thePixelHeight ) );
   QgsDebugMsg( "theExtent: " + theExtent.toString() );
   QgsDebugMsg( "crs(): " + crs().toWkt() );
-  QgsDebugMsg( "theSrcCRS: " + theDestCRS.toWkt() );
-  QgsDebugMsg( "theDestCRS: " + theDestCRS.toWkt() );
   GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
   GDALDataType myGdalDataType = GDALGetRasterDataType( myGdalBand );
-  //QString myMemDsn = QString( "MEM:::DATAPOINTER=%1,PIXELS=%2,LINES=%3,BANDS=1,DATATYPE=%4,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0")
-    //.arg ( (long) theBlock )
-    //.arg ( thePixelWidth )
-    //.arg ( thePixelHeight )
-    //.arg ( GDALGetDataTypeName( myGdalDataType ) );
   QString myMemDsn;
   myMemDsn.sprintf ( "DATAPOINTER = %p", theBlock );
   QgsDebugMsg(  myMemDsn );
-  // TODO: more bands support
-  //myMemDsn.sprintf ( "MEM:::DATAPOINTER=%lu,PIXELS=%d,LINES=%d,BANDS=1,DATATYPE=%s,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0", (long)theBlock, thePixelWidth, thePixelHeight,  GDALGetDataTypeName( myGdalDataType ) );
   myMemDsn.sprintf ( "MEM:::DATAPOINTER=%lu,PIXELS=%d,LINES=%d,BANDS=1,DATATYPE=%s,PIXELOFFSET=0,LINEOFFSET=0,BANDOFFSET=0", (long)theBlock, thePixelWidth, thePixelHeight,  GDALGetDataTypeName( (GDALDataType)mGdalDataType[theBandNo-1] ) );
   QgsDebugMsg( "Open GDAL MEM : " + myMemDsn );
   CPLErrorReset();
-  //GDALDatasetH myGdalMemDataset = GDALOpen( myMemDsn.toAscii().constData(),GA_Update);
   GDALDatasetH myGdalMemDataset = GDALOpen( TO8F( myMemDsn ), GA_Update );
   if ( !myGdalMemDataset )
@@ -589,15 +554,8 @@
      return;
-  // TODO add CRS to method params
-  // TODO: SRC CRS can be forced from GUI - check? Also default project sould be
-  // probably used if the source has no CRS
-  //GDALSetProjection( myGdalMemDataset, crs().toWkt().toAscii().constData() );
-  //const char *mySrcCRSChar = crs().toWkt().toAscii().constData();
+  //GDALSetProjection( myGdalMemDataset, theDestCRS.toWkt().toAscii().constData() );
-  //GDALSetProjection( myGdalMemDataset, GDALGetProjectionRef( mGdalDataset ) );
-  GDALSetProjection( myGdalMemDataset, theDestCRS.toWkt().toAscii().constData() );
   double myMemGeoTransform[6];
   myMemGeoTransform[0] = theExtent.xMinimum(); /* top left x */
   myMemGeoTransform[1] = theExtent.width()/thePixelWidth; /* w-e pixel resolution */
@@ -623,7 +581,6 @@
   myWarpOptions->nBandCount = 1;
   myWarpOptions->panSrcBands =
     (int *) CPLMalloc(sizeof(int) * myWarpOptions->nBandCount );
-  //myWarpOptions->panSrcBands[0] = 1;
   myWarpOptions->panSrcBands[0] = theBandNo;
   myWarpOptions->panDstBands =
@@ -637,37 +594,18 @@
   myWarpOptions->pTransformerArg =
       GDALCreateGenImgProjTransformer(
         mGdalDataset,
-        //mySrcCRSChar,
-        //GDALGetProjectionRef(mGdalDataset),
-        theSrcCRS.toWkt().toAscii().constData(),
+        NULL,
         myGdalMemDataset,
-        GDALGetProjectionRef(myGdalMemDataset),
+        NULL,
         FALSE, 0.0, 1
   CPLAssert( myWarpOptions->pTransformerArg  != NULL);
   myWarpOptions->pfnTransformer = GDALGenImgProjTransform;
-  //double myNoDataRow = (double *) CPLMalloc( sizeof(double) * thePixelWidth );
   myWarpOptions->padfDstNoDataReal = (double *) CPLMalloc( myWarpOptions->nBandCount * sizeof(double));
   myWarpOptions->padfDstNoDataImag = (double *) CPLMalloc( myWarpOptions->nBandCount * sizeof(double));
-  for  ( int i = 0; i < myWarpOptions->nBandCount; i++ )
-    myWarpOptions->padfDstNoDataReal[i] = mNoDataValue;
-    myWarpOptions->padfDstNoDataImag[i] = 0.0;
-    GDALSetRasterNoDataValue( GDALGetRasterBand( myGdalMemDataset,
-                        myWarpOptions->panDstBands[i] ),
-                        myWarpOptions->padfDstNoDataReal[i] );
   myWarpOptions->padfDstNoDataReal[0] = mNoDataValue[theBandNo-1];
   myWarpOptions->padfDstNoDataImag[0] = 0.0;
@@ -682,7 +620,6 @@
   myWarpOptions->eResampleAlg = GRA_NearestNeighbour;
   GDALWarpOperation myOperation;
   myOperation.Initialize( myWarpOptions );
@@ -745,7 +682,6 @@
  * @param theList a pointer the object that will hold the color table
  * @return true of a color table was able to be read, false otherwise
-//bool QgsRasterLayer::readColorTable( int theBandNumber, QList<QgsColorRampShader::ColorRampItem>* theList )
 QList<QgsColorRampShader::ColorRampItem> QgsGdalProvider::colorTable(int theBandNumber)const
   QgsDebugMsg( "entered." );
@@ -887,10 +823,6 @@
     for ( int i = 1; i <= GDALGetRasterCount( mGdalDataset ); i++ )
       GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, i );
-      //GDALDataType type = GDALGetRasterDataType( gdalBand );
-      //int size = GDALGetDataTypeSize( type ) / 8;
-      //void *data = CPLMalloc( size );
       double value;
       CPLErr err = GDALRasterIO( gdalBand, GF_Read, col, row, 1, 1,
@@ -1090,7 +1022,6 @@
     theBandStats.isHistogramOutOfRange = theIgnoreOutOfRangeFlag;
     int *myHistogramArray = new int[theBinCount];
      *  CPLErr GDALRasterBand::GetHistogram (
      *          double       dfMin,
@@ -1285,8 +1216,6 @@
     //close the gdal dataset and reopen it in read only mode
     GDALClose( mGdalBaseDataset );
-    //mGdalBaseDataset = GDALOpen( QFile::encodeName( mDataSource ).constData(), GA_ReadOnly );
-    //mGdalBaseDataset = GDALOpen( QFile::encodeName( dataSourceUri() ).constData(), GA_ReadOnly );
     mGdalBaseDataset = GDALOpen( TO8F( dataSourceUri() ), GA_ReadOnly );
     //Since we are not a virtual warped dataset, mGdalDataSet and mGdalBaseDataset are supposed to be the same
     mGdalDataset = mGdalBaseDataset;
@@ -1305,8 +1234,6 @@
   int myHeight = mHeight;
   int myDivisor = 2;
-  //if ( mDataProvider ) return mPyramidList;
   GDALRasterBandH myGDALBand = GDALGetRasterBand( mGdalDataset, 1 ); //just use the first band
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.h	2011-03-06 19:12:00 UTC (rev 15368)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.h	2011-03-06 19:33:54 UTC (rev 15369)
@@ -204,7 +204,6 @@
     void readBlock( int bandNo, int xBlock, int yBlock, void *data );
     void readBlock( int bandNo, QgsRectangle  const & viewExtent, int width, int height, void *data );
-    void readBlockOld( int bandNo, QgsRectangle  const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS,  void *data );
     double noDataValue() const;
     void computeMinMax(int bandNo);
@@ -230,14 +229,6 @@
     /** \brief ensures that GDAL drivers are registered, but only once */
     static void registerGdalDrivers();
-    //void buildSupportedRasterFileFilter( QString & theFileFiltersString );
-    //bool isValidRasterFileName( QString const & theFileNameQString, QString & retErrMsg );
-    //bool isValidRasterFileName( const QString & theFileNameQString );
-    //static QStringList subLayers( GDALDatasetH dataset );
     /** \brief Returns the sublayers of this layer - Useful for providers that manage their own layers, such as WMS */
     QStringList subLayers() const;
@@ -298,8 +289,6 @@
     /** \brief Values for mapping pixel to world coordinates. Contents of this array are the same as the GDAL adfGeoTransform */
     double mGeoTransform[6];
-    //QHash<QString, QString> mInfo;
     QgsCoordinateReferenceSystem mCrs;
     QList<QgsRasterPyramid> mPyramidList;
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp	2011-03-06 19:12:00 UTC (rev 15368)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp	2011-03-06 19:33:54 UTC (rev 15369)
@@ -208,9 +208,6 @@
   QgsDebugMsg( "pixelHeight = "  + QString::number( pixelHeight ) );
   QgsDebugMsg( "viewExtent: " + viewExtent.toString() );
-  //QImage *image = new QImage( pixelWidth, pixelHeight, QImage::Format_ARGB32 );
-  //image->fill( QColor( Qt::gray ).rgb() );
   QStringList arguments;
   arguments.append( "map=" +  mMapName + "@" + mMapset );
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h	2011-03-06 19:12:00 UTC (rev 15368)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h	2011-03-06 19:33:54 UTC (rev 15369)
@@ -237,7 +237,6 @@
     RASTER_MAP_TYPE mGrassDataType; // CELL_TYPE, DCELL_TYPE, FCELL_TYPE
-    //QgsRectangle mExtent;
     int mCols;
     int mRows;
     int mYBlockSize;
More information about the QGIS-commit mailing list
