[QGIS Commit] r15379 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Mon Mar 7 10:36:54 EST 2011
Author: aghisla
Date: 2011-03-07 07:36:54 -0800 (Mon, 07 Mar 2011)
New Revision: 15379
docs/trunk/english_us/user_guide/working_with_vector.tex
Add example of Reshape tool. Thanks Tim for the inspiring haiku.
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2011-03-07 07:34:23 UTC (rev 15378)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2011-03-07 15:36:54 UTC (rev 15379)
@@ -1836,11 +1836,20 @@
You can reshape line and polygon features using the
\toolbtntwo{mActionReshape}{Reshape Features} icon on the toolbar. It
replaces the line or polygon part from the first to the last intersection
-with the original line. With polygons this can sometime lead to unintended
+with the original line. With polygons this can sometimes lead to unintended
results. It is mainly useful to replace smaller parts of a polygon, not major
overhauls and the reshapeline is not allowed to cross several polygon rings
-as this would generate an invalide polygon.
+as this would generate an invalid polygon.
+For example, you can edit the boundary of a polygon with this tool. First,
+click in the inner area of the polygon next to the point where you want to
+add a new vertex. Then, cross the boundary and add the vertices outside the
+polygon. To finish, right-click in the inner area of the polygon. The tool
+will automatically add a node where the new line crosses the border. It is
+also possible to remove part of the area from the polygon, starting the new
+line outside the polygon, adding vertices inside, and ending the line outside
+the polygon with a right click.
\textbf{Note}: The reshape tool may alter the starting position of a polygon
ring or a closed line. So the point that is represented 'twice' will not be
the same any more. This may not be a problem for most applications, but it is
