[QGIS Commit] r15402 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org
Wed Mar 9 10:26:37 EST 2011
Author: pcav
Date: 2011-03-09 07:26:37 -0800 (Wed, 09 Mar 2011)
New Revision: 15402
trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm
trunk/qgis/src/plugins/grass/modules-common/v.generalize.qgm
Improved v.distance and v.generalize GRASS modules
Modified: trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm 2011-03-09 13:16:41 UTC (rev 15401)
+++ trunk/qgis/src/plugins/grass/modules-common/v.distance.qgm 2011-03-09 15:26:37 UTC (rev 15402)
@@ -4,9 +4,10 @@
<qgisgrassmodule label="Find nearest element in vector 'to' for elements in vector 'from'. Various information about this relation may be uploaded to attribute table of input vector 'from'" module="v.distance">
<option key="from" typemask="point" layeroption="from_layer"/>
<option key="to" typeoption="to_type" layeroption="to_layer"/>
- <option key="upload"/>
- <option key="dmax"/>
- <option key="dmin"/>
- <field key="column" layer="from" type="integer,double" label="Attribute field" />
- <option key="output"/>
+ <option key="upload" />
+ <field key="to_column" layer="to" type="string" label="(Optional) column to read labels" />
+ <field key="column" layer="from" type="integer,double,string" label="Attribute field to (over)write" />
+ <option key="output" advanced="yes"/>
+ <option key="dmax" advanced="yes"/>
+ <option key="dmin" advanced="yes"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.generalize.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.generalize.qgm 2011-03-09 13:16:41 UTC (rev 15401)
+++ trunk/qgis/src/plugins/grass/modules-common/v.generalize.qgm 2011-03-09 15:26:37 UTC (rev 15402)
@@ -4,20 +4,20 @@
<qgisgrassmodule label="Simplify vector" module="v.generalize">
<option key="input" typeoption="type" layeroption="layer" />
<flag key="c" answer="on" hidden="yes" />
- <option key="type" />
+ <option key="type" label="Feature type (for polygons, choose Boundary)"/>
<option key="method" />
- <option key="threshold" answer="1.0" />
- <option key="look_ahead" answer="7" />
- <option key="reduction" answer="50" />
- <option key="slide" answer="0.5" />
- <option key="angle_thresh" answer="3" />
- <option key="degree_thresh" answer="0" />
- <option key="closeness_thresh" answer="0" />
- <option key="betweeness_thresh" answer="0" />
- <option key="alpha" answer="1.0" />
- <option key="beta" answer="1.0" />
- <option key="iterations" answer="1" />
- <option key="layer" answer="1" />
+ <option key="threshold" answer="1.0" label="Maximal tolerance value (higher value=more simplification)" />
+ <option key="look_ahead" answer="7" advanced="yes" />
+ <option key="reduction" answer="50" advanced="yes" />
+ <option key="slide" answer="0.5" advanced="yes" />
+ <option key="angle_thresh" answer="3" advanced="yes" />
+ <option key="degree_thresh" answer="0" advanced="yes" />
+ <option key="closeness_thresh" answer="0" advanced="yes" />
+ <option key="betweeness_thresh" answer="0" advanced="yes" />
+ <option key="alpha" answer="1.0" advanced="yes" />
+ <option key="beta" answer="1.0" advanced="yes" />
+ <option key="iterations" answer="1" advanced="yes"/>
+ <option key="layer" answer="1" advanced="yes"/>
<flag key="r" />
<option key="output" />
</qgisgrassmodule>
