[QGIS Commit] r15410 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Wed Mar 9 21:01:37 EST 2011
Author: telwertowski
Date: 2011-03-09 18:01:37 -0800 (Wed, 09 Mar 2011)
New Revision: 15410
trunk/qgis/src/app/main.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/core/qgsapplication.cpp
trunk/qgis/src/core/qgsapplication.h
Use QFileOpenEvent to handle double clicking a file icon in the Mac OS X Finder. This works for both Cocoa and Carbon. Remove Carbon-only OpenDocument code.
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2011-03-09 21:40:48 UTC (rev 15409)
+++ trunk/qgis/src/app/main.cpp 2011-03-10 02:01:37 UTC (rev 15410)
@@ -129,70 +129,6 @@
static QStringList myFileList;
-#ifdef Q_OS_MACX
-/* Mac OS OpenDocuments AppleEvent handler called when files are double-clicked.
- * May be called at startup before application is initialized as well as
- * at any time while the application is running.
-OSErr openDocumentsAEHandler( const AppleEvent *event, AppleEvent *reply, SRefCon refCon )
- AEDescList docs;
- if ( AEGetParamDesc( event, keyDirectObject, typeAEList, &docs ) == noErr )
- // Get count of files to open
- long count = 0;
- AECountItems( &docs, &count );
- // Examine files and load first project file followed by all other non-project files
- myProjectFileName.truncate( 0 );
- myFileList.clear();
- for ( int i = 0; i < count; i++ )
- FSRef ref;
- UInt8 strBuffer[256];
- if ( AEGetNthPtr( &docs, i + 1, typeFSRef, 0, 0, &ref, sizeof( ref ), 0 ) == noErr &&
- FSRefMakePath( &ref, strBuffer, 256 ) == noErr )
- QString fileName( QString::fromUtf8( reinterpret_cast<char *>( strBuffer ) ) );
- if ( fileName.endsWith( ".qgs" ) )
- // Load first project file and ignore all other project files
- if ( myProjectFileName.isEmpty() )
- myProjectFileName = fileName;
- else
- // Load all non-project files
- myFileList.append( fileName );
- // Open files now if application has been fully initialized (has objectName).
- // Otherwise (if this routine is called by processEvents inside the QgisApp constructor
- // at startup) wait for the command line file loader to notice these files.
- QgisApp *qgis = QgisApp::instance();
- if ( qgis && qgis->objectName() == "QgisApp" )
- if ( !myProjectFileName.isEmpty() )
- qgis->openProject( myProjectFileName );
- for ( QStringList::Iterator myIterator = myFileList.begin();
- myIterator != myFileList.end(); ++myIterator )
- QString fileName = *myIterator;
- qgis->openLayer( fileName );
- return noErr;
-#endif
/* Test to determine if this program was started on Mac OS X by double-clicking
* the application bundle rather then from a command line. If clicked, argv[1]
* contains a process serial number in the form -psn_0_1234567. Don't process
@@ -512,13 +448,6 @@
QCoreApplication::setApplicationName( "QGIS" );
QCoreApplication::setAttribute( Qt::AA_DontShowIconsInMenus, false );
#ifdef Q_OS_MACX
- // Install OpenDocuments AppleEvent handler after application object is initialized
- // but before any other event handling (including dialogs or splash screens) occurs.
- // If an OpenDocuments event has been created before the application was launched,
- // it must be handled before some other event handler runs and dismisses it as unknown.
- // If run at startup, the handler will set either or both of myProjectFileName and myFileList.
- AEInstallEventHandler( kCoreEventClass, kAEOpenDocuments, openDocumentsAEHandler, 0, false );
// If the GDAL plugins are bundled with the application and GDAL_DRIVER_PATH
// is not already defined, use the GDAL plugins in the application bundle.
QString gdalPlugins( QCoreApplication::applicationDirPath().append( "/lib/gdalplugins" ) );
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2011-03-09 21:40:48 UTC (rev 15409)
+++ trunk/qgis/src/app/qgisapp.cpp 2011-03-10 02:01:37 UTC (rev 15410)
@@ -570,6 +570,9 @@
QgsDebugMsg( QgsApplication::showSettings() );
QgsDebugMsg( "\n--------------------------\n\n\n" );
+ // request notification of FileOpen events (double clicking a file icon in Mac OS X Finder)
+ QgsApplication::setFileOpenEventReceiver( this );
} // QgisApp ctor
@@ -622,6 +625,9 @@
deletePrintComposers();
removeAnnotationItems();
+ // cancel request for FileOpen events
+ QgsApplication::setFileOpenEventReceiver( nil );
// delete map layer registry and provider registry
QgsApplication::exitQgis();
@@ -646,24 +652,31 @@
// so we test for length to make sure we have something
if ( !fileName.isEmpty() )
- // check to see if we are opening a project file
- QFileInfo fi( fileName );
- if ( fi.completeSuffix() == "qgs" )
- QgsDebugMsg( "Opening project " + fileName );
- openProject( fileName );
- else
- QgsDebugMsg( "Adding " + fileName + " to the map canvas" );
- openLayer( fileName, true );
+ openFile( fileName );
event->acceptProposedAction();
+bool QgisApp::event( QEvent * event )
+ bool done = false;
+ if ( event->type() == QEvent::FileOpen )
+ // handle FileOpen event (double clicking a file icon in Mac OS X Finder)
+ QFileOpenEvent *foe = static_cast<QFileOpenEvent *>( event );
+ openFile( foe->file() );
+ done = true;
+ else
+ // pass other events to base class
+ done = QMainWindow::event( event );
+ return done;
// restore any application settings stored in QSettings
void QgisApp::readSettings()
@@ -2970,6 +2983,25 @@
return ok;
+// Open a file specified by a commandline argument, Drop or FileOpen event.
+void QgisApp::openFile( const QString & fileName )
+ // check to see if we are opening a project file
+ QFileInfo fi( fileName );
+ if ( fi.completeSuffix() == "qgs" )
+ QgsDebugMsg( "Opening project " + fileName );
+ openProject( fileName );
+ else
+ QgsDebugMsg( "Adding " + fileName + " to the map canvas" );
+ openLayer( fileName, true );
void QgisApp::newPrintComposer()
if ( mMapCanvas && mMapCanvas->isDrawing() )
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2011-03-09 21:40:48 UTC (rev 15409)
+++ trunk/qgis/src/app/qgisapp.h 2011-03-10 02:01:37 UTC (rev 15410)
@@ -140,22 +140,23 @@
//! Remove all layers from the map and legend - reimplements same method from qgisappbase
void removeAllLayers();
/** Open a raster or vector file; ignore other files.
- Used to process a commandline argument or OpenDocument AppleEvent.
+ Used to process a commandline argument, FileOpen or Drop event.
+ Set interactive to true if it is ok to ask the user for information (mostly for
+ when a vector layer has sublayers and we want to ask which sublayers to use).
@returns true if the file is successfully opened
bool openLayer( const QString & fileName, bool allowInteractive = false );
- /** Open the specified file (project, vector, or raster); prompt to save
- previous project if necessary.
- Used to process a commandline argument, OpenDocument AppleEvent, or a
- file drag/drop event. Set interactive to true if it is ok to ask the
- user for information (mostly for when a vector layer has sublayers and
- we want to ask which sublayers to use).
+ /** Open the specified project file; prompt to save previous project if necessary.
void openProject( const QString & fileName );
/** opens a qgis project file
@returns false if unable to open the project
bool addProject( QString projectFile );
+ /** Convenience function to open either a project or a layer file.
+ void openFile( const QString & fileName );
//!Overloaded version of the private function with same name that takes the imagename as a parameter
void saveMapAsImage( QString, QPixmap * );
/** Get the mapcanvas object from the app */
@@ -431,6 +432,9 @@
//! layer selection changed
void legendLayerSelectionChanged( void );
+ //! Watch for QFileOpenEvent.
+ virtual bool event( QEvent * event );
protected:
//! Handle state changes (WindowTitleChange)
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2011-03-09 21:40:48 UTC (rev 15409)
+++ trunk/qgis/src/core/qgsapplication.cpp 2011-03-10 02:01:37 UTC (rev 15410)
@@ -20,6 +20,7 @@
#include "qgsexception.h"
#include <QDir>
+#include <QFileOpenEvent>
#include <QMessageBox>
#include <QPalette>
#include <QSettings>
@@ -34,6 +35,8 @@
#include <ogr_api.h>
+QObject * QgsApplication::mFileOpenEventReceiver;
+QStringList QgsApplication::mFileOpenEventList;
QString QgsApplication::mPrefixPath;
QString QgsApplication::mPluginPath;
QString QgsApplication::mPkgDataPath;
@@ -79,6 +82,34 @@
+bool QgsApplication::event( QEvent * event )
+ if ( mFileOpenEventReceiver )
+ // Forward event to main window.
+ done = notify( mFileOpenEventReceiver, event );
+ else
+ // Store filename because receiver has not registered yet.
+ // If QGIS has been launched by double clicking a file icon, FileOpen will be
+ // the first event; the main window is not yet ready to handle the event.
+ mFileOpenEventList.append( static_cast<QFileOpenEvent *>( event )->file() );
+ done = true;
+ else
+ done = QApplication::event( event );
+ return done;
bool QgsApplication::notify( QObject * receiver, QEvent * event )
// Send event to receiver and catch unhandled exceptions
@@ -102,6 +133,23 @@
return done;
+void QgsApplication::setFileOpenEventReceiver( QObject * receiver )
+ // Set receiver for FileOpen events
+ mFileOpenEventReceiver = receiver;
+ // Propagate any events collected before the receiver has registered.
+ if ( mFileOpenEventList.count() > 0 )
+ QStringListIterator i( mFileOpenEventList );
+ while ( i.hasNext() )
+ QFileOpenEvent foe( i.next() );
+ QgsApplication::sendEvent( mFileOpenEventReceiver, &foe );
+ mFileOpenEventList.clear();
void QgsApplication::setPrefixPath( const QString thePrefixPath, bool useDefaultPaths )
mPrefixPath = thePrefixPath;
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2011-03-09 21:40:48 UTC (rev 15409)
+++ trunk/qgis/src/core/qgsapplication.h 2011-03-10 02:01:37 UTC (rev 15410)
@@ -17,6 +17,7 @@
#define QGSAPPLICATION_H
#include <QApplication>
+#include <QEvent>
#include <qgis.h>
@@ -32,9 +33,15 @@
QgsApplication( int & argc, char ** argv, bool GUIenabled, QString customConfigPath = QString() );
virtual ~QgsApplication();
//! Catch exceptions when sending event to receiver.
virtual bool notify( QObject * receiver, QEvent * event );
+ //! Set the FileOpen event receiver
+ static void setFileOpenEventReceiver( QObject * receiver );
/** Set the active theme to the specified theme.
* The theme name should be a single word e.g. 'default','classic'.
* The theme search path usually will be pkgDataPath + "/themes/" + themName + "/"
@@ -195,6 +202,9 @@
static QString relativePathToAbsolutePath( QString rpath, QString targetPath );
private:
+ static QObject* mFileOpenEventReceiver;
+ static QStringList mFileOpenEventList;
static QString mPrefixPath;
static QString mPluginPath;
static QString mPkgDataPath;
