[QGIS Commit] r15418 - in trunk/qgis/src: core providers/gdal
svn_qgis at osgeo.org
Thu Mar 10 13:50:00 EST 2011
Author: rblazek
Date: 2011-03-10 10:50:00 -0800 (Thu, 10 Mar 2011)
New Revision: 15418
trunk/qgis/src/core/qgsrasterdataprovider.cpp
trunk/qgis/src/core/qgsrasterdataprovider.h
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
GDALWarpOperation -> GDALRasterIO
Modified: trunk/qgis/src/core/qgsrasterdataprovider.cpp
--- trunk/qgis/src/core/qgsrasterdataprovider.cpp 2011-03-10 13:33:45 UTC (rev 15417)
+++ trunk/qgis/src/core/qgsrasterdataprovider.cpp 2011-03-10 18:50:00 UTC (rev 15418)
@@ -22,6 +22,7 @@
#include <QTime>
#include <QMap>
+#include <QByteArray>
void QgsRasterDataProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *data )
@@ -179,4 +180,55 @@
return "text/plain";
+QByteArray QgsRasterDataProvider::noValueBytes( int theBandNo )
+ int type = dataType(theBandNo);
+ int size = dataTypeSize(theBandNo) / 8;
+ QByteArray ba;
+ ba.resize(size);
+ char * data = ba.data();
+ double noval = mNoDataValue[theBandNo-1];
+ unsigned char uc;
+ unsigned short us;
+ short s;
+ unsigned int ui;
+ int i;
+ float f;
+ double d;
+ switch (type)
+ case QgsRasterDataProvider::Byte:
+ uc = (unsigned char)noval;
+ memcpy ( data, &uc, size);
+ break;
+ case QgsRasterDataProvider::UInt16:
+ us = (unsigned short)noval;
+ memcpy ( data, &us, size);
+ break;
+ case QgsRasterDataProvider::Int16:
+ s = (short)noval;
+ memcpy ( data, &s, size);
+ break;
+ case QgsRasterDataProvider::UInt32:
+ ui = (unsigned int)noval;
+ memcpy ( data, &ui, size);
+ break;
+ case QgsRasterDataProvider::Int32:
+ i = (int)noval;
+ memcpy ( data, &i, size);
+ break;
+ case QgsRasterDataProvider::Float32:
+ f = (float)noval;
+ memcpy ( data, &f, size);
+ break;
+ case QgsRasterDataProvider::Float64:
+ d = (double)noval;
+ memcpy ( data, &d, size);
+ break;
+ default:
+ QgsLogger::warning( "GDAL data type is not supported" );
+ return ba;
// ENDS
Modified: trunk/qgis/src/core/qgsrasterdataprovider.h
--- trunk/qgis/src/core/qgsrasterdataprovider.h 2011-03-10 13:33:45 UTC (rev 15417)
+++ trunk/qgis/src/core/qgsrasterdataprovider.h 2011-03-10 18:50:00 UTC (rev 15418)
@@ -33,6 +33,7 @@
class QImage;
class QgsPoint;
class QgsRasterBandStats;
+class QByteArray;
#define TINY_VALUE std::numeric_limits<double>::epsilon() * 20
@@ -456,6 +457,8 @@
static QString makeTableCell( QString const & value );
static QString makeTableCells( QStringList const & values );
+ /** \brief Set null value in char */
+ QByteArray noValueBytes(int theBandNo);
protected:
/**Dots per intch. Extended WMS (e.g. QGIS mapserver) support DPI dependent output and therefore
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-10 13:33:45 UTC (rev 15417)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-10 18:50:00 UTC (rev 15418)
@@ -510,6 +510,9 @@
void QgsGdalProvider::readBlock( int theBandNo, int xBlock, int yBlock, void *block )
+ // TODO!!!: Check data alignment!!! May it happen that nearest value which
+ // is not nearest is assigned to an output cell???
QgsDebugMsg( "Entered" );
QgsDebugMsg( "yBlock = " + QString::number( yBlock ) );
@@ -528,8 +531,166 @@
QgsDebugMsg( "thePixelWidth = " + QString::number( thePixelWidth ) );
QgsDebugMsg( "thePixelHeight = " + QString::number( thePixelHeight ) );
QgsDebugMsg( "theExtent: " + theExtent.toString() );
- QgsDebugMsg( "crs(): " + crs().toWkt() );
+ // TODO: fill block with no data values
+ QgsRectangle myRasterExtent = theExtent.intersect( &mExtent );
+ if ( myRasterExtent.isEmpty() )
+ QgsDebugMsg( "draw request outside view extent." );
+ return;
+ QgsDebugMsg( "myRasterExtent: " + myRasterExtent.toString() );
+ double xRes = theExtent.width()/thePixelWidth;
+ double yRes = theExtent.height()/thePixelHeight;
+ // Find top, bottom rows and left, right column the raster extent covers
+ // These are limits in target grid space
+ int top = 0;
+ int bottom = thePixelHeight-1;
+ int left = 0;
+ int right = thePixelWidth-1;
+ if ( myRasterExtent.yMaximum() < theExtent.yMaximum() )
+ top = static_cast<int> ( round( ( theExtent.yMaximum() - myRasterExtent.yMaximum() ) / yRes ) );
+ if ( myRasterExtent.yMinimum() > theExtent.yMinimum() )
+ bottom = static_cast<int> ( round( ( theExtent.yMaximum() - myRasterExtent.yMinimum() ) / yRes ) - 1 );
+ if ( myRasterExtent.xMinimum() > theExtent.xMinimum() )
+ left = static_cast<int> ( round( ( myRasterExtent.xMinimum() - theExtent.xMinimum() ) / xRes ) );
+ if ( myRasterExtent.xMaximum() < theExtent.xMaximum() )
+ right = static_cast<int> ( round( ( myRasterExtent.xMaximum() - theExtent.xMinimum() ) / xRes ) - 1 );
+ QgsDebugMsg( QString("top = %1 bottom = %2 left = %3 right = %4").arg(top).arg(bottom).arg(left).arg(right) );
+ // We want to avoid another resampling, so we read data approximately with
+ // the same resolution as requested and exactly the width/height we need.
+ // Calculate rows/cols limits in raster grid space
+ // IMHO, we cannot align target grid to raster grid using target grid edges
+ // and finding the nearest raster grid because it could lead to cell center
+ // getting outside the right cell when doing resampling, example
+ // Raster width is 30m and it has 3 columns and we want to read xrange 5.1-30
+ // to 3 columns, the nearest edge for beginning in raster grid is 10.0
+ // reading cols 1-2, we get raster[1] value in target[0], but the center of
+ // target[0] is 5.1 + ((30-5.1)/3)/2 = 9.25 so it falls to raster[0]. Is it right?
+ // => We are looking for such alignment with which the center of first/last cell
+ // alls to the right raster cell
+ double center, centerRaster;
+ int rasterTop, rasterBottom, rasterLeft, rasterRight;
+ // top
+ center = myRasterExtent.yMaximum() - yRes/2;
+ // center in raster space
+ // GDAL states that mGeoTransform[3] is top, but probably it can be also bottom
+ // if mGeoTransform[5] is negative
+ if ( mGeoTransform[5] > 0 )
+ centerRaster = ( mGeoTransform[3] - center ) / mGeoTransform[5];
+ else
+ centerRaster = ( center - mGeoTransform[3] ) / mGeoTransform[5];
+ rasterTop = static_cast<int> ( floor ( centerRaster ) );
+ // bottom
+ center = myRasterExtent.yMinimum() + yRes/2;
+ else
+ rasterBottom = static_cast<int> ( floor ( centerRaster ) );
+ // left
+ center = myRasterExtent.xMinimum() + xRes/2;
+ centerRaster = ( center - mGeoTransform[0] ) / mGeoTransform[1];
+ rasterLeft = static_cast<int> ( floor ( centerRaster ) );
+ // right
+ center = myRasterExtent.xMaximum() - xRes/2;
+ rasterRight = static_cast<int> ( floor ( centerRaster ) );
+ QgsDebugMsg( QString("rasterTop = %1 rasterBottom = %2 rasterLeft = %3 rasterRight = %4").arg(rasterTop).arg(rasterBottom).arg(rasterLeft).arg(rasterRight) );
+ // Allocate temporary block
+ int width = right - left + 1;
+ int height = bottom - top + 1;
+ int rasterWidth = rasterRight - rasterLeft + 1;
+ int rasterHeight = rasterBottom - rasterTop + 1;
+ QgsDebugMsg( QString("width = %1 height = %2 rasterWidth = %3 rasterHeight = %4").arg(width).arg(height).arg(rasterWidth).arg(rasterHeight) );
+ // fill with null values
+ QByteArray ba = noValueBytes(theBandNo);
+ char *nodata = ba.data();
+ char *block = (char *) theBlock;
+ for ( int i = 0; i < thePixelWidth * thePixelHeight; i++ )
+ memcpy ( block, nodata, size );
+ block += size;
+ GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
+ // Calc beginnig of data if raster does not start at top
+ block = (char *) theBlock;
+ if ( top != 0 )
+ block += size * thePixelWidth * top;
+ // Cal nLineSpace if raster does not cover whole extent
+ int nLineSpace = size * thePixelWidth;
+ if ( left != 0 ) {
+ block += size * left;
+ GDALDataType type = ( GDALDataType )mGdalDataType[theBandNo-1];
+ CPLErrorReset();
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read,
+ rasterLeft, rasterTop, rasterWidth, rasterHeight,
+ (void *)block,
+ width, height, type,
+ 0, nLineSpace );
+ if ( err != CPLE_None )
+ QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ QgsDebugMsg ( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+// this is old version which was using GDALWarpOperation, unfortunately
+// it may be very slow on large datasets
+#if 0
+void QgsGdalProvider::readBlock( int theBandNo, QgsRectangle const & theExtent, int thePixelWidth, int thePixelHeight, void *theBlock )
+ QgsDebugMsg( "thePixelWidth = " + QString::number( thePixelWidth ) );
+ QgsDebugMsg( "thePixelHeight = " + QString::number( thePixelHeight ) );
+ QgsDebugMsg( "theExtent: " + theExtent.toString() );
QString myMemDsn;
myMemDsn.sprintf( "DATAPOINTER = %p", theBlock );
QgsDebugMsg( myMemDsn );
@@ -672,6 +833,7 @@
GDALClose( myGdalMemDataset );
+#endif
double QgsGdalProvider::noDataValue() const
