[QGIS Commit] r15422 - trunk/qgis/src/providers/gdal
svn_qgis at osgeo.org
Thu Mar 10 16:27:01 EST 2011
Author: rblazek
Date: 2011-03-10 13:27:01 -0800 (Thu, 10 Mar 2011)
New Revision: 15422
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
alignment better
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-10 21:26:59 UTC (rev 15421)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-10 21:27:01 UTC (rev 15422)
@@ -532,6 +532,11 @@
QgsDebugMsg( "thePixelHeight = " + QString::number( thePixelHeight ) );
QgsDebugMsg( "theExtent: " + theExtent.toString() );
+ for ( int i = 0 ; i < 6; i++ )
+ QgsDebugMsg( QString( "transform : %1" ).arg( mGeoTransform[i] ) );
// TODO: fill block with no data values
QgsRectangle myRasterExtent = theExtent.intersect( &mExtent );
@@ -589,46 +594,57 @@
double center, centerRaster;
int rasterTop, rasterBottom, rasterLeft, rasterRight;
+ // We have to extend destination grid for GDALRasterIO to keep resolution:
+ double topSpace, bottomSpace, leftSpace, rightSpace;
// top
center = myRasterExtent.yMaximum() - yRes/2;
// center in raster space
// GDAL states that mGeoTransform[3] is top, but probably it can be also bottom
- // if mGeoTransform[5] is negative
- if ( mGeoTransform[5] > 0 )
+ // if mGeoTransform[5] is negative ??? No, mGeoTransform[5] is negative normaly
+ // - vice versa?
+ //if ( mGeoTransform[5] > 0 )
+ if ( mGeoTransform[5] < 0 )
- centerRaster = ( mGeoTransform[3] - center ) / mGeoTransform[5];
+ centerRaster = -1. * ( mGeoTransform[3] - center ) / mGeoTransform[5];
else
centerRaster = ( center - mGeoTransform[3] ) / mGeoTransform[5];
rasterTop = static_cast<int> ( floor ( centerRaster ) );
+ topSpace = (mGeoTransform[3] + rasterTop*mGeoTransform[5])- myRasterExtent.yMaximum();
// bottom
center = myRasterExtent.yMinimum() + yRes/2;
else
rasterBottom = static_cast<int> ( floor ( centerRaster ) );
+ bottomSpace = myRasterExtent.yMinimum() - ( mGeoTransform[3] + (rasterBottom+1)*mGeoTransform[5] );
// left
center = myRasterExtent.xMinimum() + xRes/2;
centerRaster = ( center - mGeoTransform[0] ) / mGeoTransform[1];
rasterLeft = static_cast<int> ( floor ( centerRaster ) );
+ leftSpace = myRasterExtent.xMinimum() - (mGeoTransform[0] + rasterLeft * mGeoTransform[1] );
// right
center = myRasterExtent.xMaximum() - xRes/2;
rasterRight = static_cast<int> ( floor ( centerRaster ) );
+ rightSpace = (mGeoTransform[0] + (rasterRight+1)*mGeoTransform[1]) - myRasterExtent.xMaximum();
QgsDebugMsg( QString("rasterTop = %1 rasterBottom = %2 rasterLeft = %3 rasterRight = %4").arg(rasterTop).arg(rasterBottom).arg(rasterLeft).arg(rasterRight) );
- // Allocate temporary block
+ QgsDebugMsg( QString("topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4").arg(topSpace).arg(bottomSpace).arg(leftSpace).arg(rightSpace) );
int width = right - left + 1;
int height = bottom - top + 1;
@@ -637,6 +653,29 @@
QgsDebugMsg( QString("width = %1 height = %2 rasterWidth = %3 rasterHeight = %4").arg(width).arg(height).arg(rasterWidth).arg(rasterHeight) );
+ double rasterXRes = extent().width() / xSize();
+ double rasterYRes = extent().height() / ySize();
+ // TODO: what is better floor/ceil, can be negative?
+ // should be similar
+ //double xAdd = rasterWidth*rasterXRes - width*xRes;
+ double xAdd = leftSpace + rightSpace;
+ int xAddPixels = static_cast<int> ( round( xAdd / xRes ) );
+ int leftAddPixels = static_cast<int> ( round( leftSpace / xRes ) );
+ //double leftAdd = rasterWidth*rasterXRes - width*xRes;
+ double yAdd = topSpace + bottomSpace;
+ int yAddPixels = static_cast<int> ( round( yAdd / yRes ) );
+ int topAddPixels = static_cast<int> ( round( topSpace / yRes ) );
+ QgsDebugMsg( QString("xAddPixels = %1 yAddPixels = %2 leftAddPixels = %3 topAddPixels = %4").arg(xAddPixels).arg(yAddPixels).arg(leftAddPixels).arg(topAddPixels) );
+ int totalWidth = width + xAddPixels;
+ int totalHeight = height + yAddPixels;
+ QgsDebugMsg( QString("totalWidth = %1 totalHeight = %2").arg(totalWidth).arg(totalHeight) );
int size = dataTypeSize(theBandNo) / 8;
// fill with null values
@@ -650,7 +689,11 @@
GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
+ GDALDataType type = ( GDALDataType )mGdalDataType[theBandNo-1];
+ CPLErrorReset();
+// This can be probably used if xAddPixels and yAddPixels are 0 to avoid memcpy
+#if 0
// Calc beginnig of data if raster does not start at top
block = (char *) theBlock;
if ( top != 0 )
@@ -663,23 +706,40 @@
if ( left != 0 ) {
block += size * left;
- GDALDataType type = ( GDALDataType )mGdalDataType[theBandNo-1];
- CPLErrorReset();
CPLErr err = GDALRasterIO( gdalBand, GF_Read,
rasterLeft, rasterTop, rasterWidth, rasterHeight,
(void *)block,
width, height, type,
0, nLineSpace );
+#endif
+ // Allocate temporary block
+ void *tmpBlock = malloc( size * totalWidth * totalHeight );
+ CPLErrorReset();
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read,
+ rasterLeft, rasterTop, rasterWidth, rasterHeight,
+ (void *)tmpBlock,
+ totalWidth, totalHeight, type,
+ 0, 0 );
if ( err != CPLE_None )
QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
QgsDebugMsg ( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ free ( tmpBlock );
+ return;
+ for ( int i = 0; i < height; i++ ) {
+ int r = i + topAddPixels;
+ char *src = (char *)tmpBlock + size*r*totalWidth + size*leftAddPixels;
+ char *dst = (char *)theBlock + size*(top+i)*thePixelWidth + size*(left);
+ memcpy ( dst, src, size*width );
+ return;
// this is old version which was using GDALWarpOperation, unfortunately
