[QGIS Commit] r15450 - in trunk/qgis/src/core: . renderer
svn_qgis at osgeo.org
Sat Mar 12 10:45:52 EST 2011
Author: mhugent
Date: 2011-03-12 07:45:52 -0800 (Sat, 12 Mar 2011)
New Revision: 15450
trunk/qgis/src/core/qgsproject.cpp
trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp
trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
Fix loading of joined layers with old symbology, #121
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp 2011-03-12 10:37:02 UTC (rev 15449)
+++ trunk/qgis/src/core/qgsproject.cpp 2011-03-12 15:45:52 UTC (rev 15450)
@@ -675,8 +675,11 @@
bool returnStatus = true;
emit layerLoaded( 0, nl.count() );
- QList<QgsVectorLayer*> vLayerList; //collect
+ //Collect vector layers with joins.
+ //They need to refresh join caches and symbology infos after all layers are loaded
+ QList< QPair< QgsVectorLayer*, QDomElement > > vLayerList;
for ( int i = 0; i < nl.count(); i++ )
QDomNode node = nl.item( i );
@@ -716,9 +719,9 @@
mapLayer = QgsMapLayerRegistry::instance()->addMapLayer( mapLayer );
QgsVectorLayer* vLayer = qobject_cast<QgsVectorLayer*>( mapLayer );
- if ( vLayer )
+ if ( vLayer && vLayer->vectorJoins().size() > 0 )
- vLayerList.push_back( vLayer );
+ vLayerList.push_back( qMakePair( vLayer, element ) );
else
@@ -736,11 +739,17 @@
//Update field map of layers with joins and create join caches if necessary
//Needs to be done here once all dependent layers are loaded
- QList<QgsVectorLayer*>::iterator vIt = vLayerList.begin();
+ QString errorMessage;
+ QList< QPair< QgsVectorLayer*, QDomElement > >::iterator vIt = vLayerList.begin();
for ( ; vIt != vLayerList.end(); ++vIt )
- ( *vIt )->createJoinCaches();
- ( *vIt )->updateFieldMap();
+ vIt->first->createJoinCaches();
+ vIt->first->updateFieldMap();
+ //for old symbology, it is necessary to read the symbology again after having the complete field map
+ if( !vIt->first->isUsingRendererV2() )
+ vIt->first->readSymbology( vIt->second, errorMessage );
return qMakePair( returnStatus, brokenNodes );
Modified: trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp
--- trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp 2011-03-12 10:37:02 UTC (rev 15449)
+++ trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp 2011-03-12 15:45:52 UTC (rev 15450)
@@ -205,7 +205,7 @@
int classificationId = theProvider->fieldNameIndex( classificationField );
if ( classificationId == -1 )
- return 2; //@todo: handle gracefully in gui situation where user needs to nominate field
+ //go on. Because with joins, it might be the joined layer is not loaded yet
setClassificationField( classificationId );
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp 2011-03-12 10:37:02 UTC (rev 15449)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp 2011-03-12 15:45:52 UTC (rev 15450)
@@ -268,10 +268,10 @@
mMode = QgsGraduatedSymbolRenderer::EqualInterval;
- int classificationId = theProvider->fieldNameIndex( classificationField );
+ int classificationId = vl.fieldNameIndex( classificationField );
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp 2011-03-12 10:37:02 UTC (rev 15449)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp 2011-03-12 15:45:52 UTC (rev 15450)
@@ -228,7 +228,7 @@
