[QGIS Commit] r15467 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Mar 13 18:15:29 EDT 2011
Author: jef
Date: 2011-03-13 15:15:29 -0700 (Sun, 13 Mar 2011)
New Revision: 15467
   trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2011-03-13 21:53:53 UTC (rev 15466)
+++ trunk/qgis/i18n/qgis_de.ts	2011-03-13 22:15:29 UTC (rev 15467)
@@ -3676,7 +3676,7 @@
     </message>
     <message>
         <location filename="../src/ui/qgisapp.ui" line="1214"/>
-        <source>Assign layer CRS to project</source>
+        <source>Set project CRS from layer</source>
         <translation>Layer-KBS dem Projekt zuweisen</translation>
     </message>
     <message>
@@ -16206,153 +16206,153 @@
         <translation>Die Location existiert!</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="474"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="468"/>
         <source>Selected projection is not supported by GRASS!</source>
         <translation>Ausgewählte Projektion wird nicht von GRASS unterstützt!</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="509"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="557"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="503"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="551"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="726"/>
         <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="732"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="738"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="752"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="843"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="853"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="880"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="966"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1054"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1063"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="746"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="837"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="847"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="874"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="960"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1048"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1057"/>
         <source>Warning</source>
         <translation>Warnung</translation>
     </message>
     <message>
         <source>Cannot create projection.</source>
         <translation>Kann Projektion nicht erzeugen.</translation>
     </message>
     <message>
         <source>Cannot reproject previously set region, default region set.</source>
         <translation>Kann Region nicht reprojizieren. Voreingestellte Projektion gesetzt.</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="684"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="678"/>
         <source>North must be greater than south</source>
         <translation>Nord muss größer als Süd sein</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="689"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="683"/>
         <source>East must be greater than west</source>
         <translation>Ost muss größer als West sein</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="881"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="875"/>
         <source>Cannot reproject selected region.</source>
         <translation>Kann ausgewählte &apos;region&apos; nicht reprojizieren.</translation>
     </message>
     <message>
         <source>Cannot reproject region</source>
         <translation>Kann &apos;region&apos; nicht reprojizieren</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1184"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1178"/>
         <source>Enter mapset name.</source>
         <translation>Mapset angeben.</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1194"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1188"/>
         <source>The mapset already exists</source>
         <translation>Die Mapset existiert bereits</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1212"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1206"/>
         <source>Database: </source>
         <translation>Datenbank: </translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1223"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1217"/>
         <source>Location: </source>
         <translation>Location: </translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1225"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1219"/>
         <source>Mapset: </source>
         <translation>Mapset: </translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1264"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1258"/>
         <source>Create location</source>
         <translation>Location anlegen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1291"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1301"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1308"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1285"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1295"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1302"/>
         <source>Create mapset</source>
         <translation>Mapset anlegen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1292"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1286"/>
         <source>Cannot create new mapset directory</source>
         <translation>Kann Mapset-Verzeichnis nicht anlegen</translation>
     </message>
     <message>
         <source>Cannot open DEFAULT_WIND</source>
         <translation>Kann DEFAULT_WIND nicht öffnen</translation>
     </message>
     <message>
         <source>Cannot open WIND</source>
         <translation>Kann WIND nicht öffnen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1330"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1335"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1324"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1329"/>
         <source>New mapset</source>
         <translation>Neue Location/Mapset</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1336"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1330"/>
         <source>New mapset successfully created and set as current working mapset.</source>
         <translation>Mapset erfolgreich erzeugt und als aktuelle Arbeitsumgebung eingestellt.</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="844"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="854"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1055"/>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1064"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="838"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="848"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1049"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1058"/>
         <source>Cannot create QgsCoordinateReferenceSystem</source>
         <translation>Kann QgsCoordinateReferenceSystem nicht erzeugen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="733"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="727"/>
         <source>Regions file (%1) not found.</source>
         <translation>Region-Datei (%1) nicht gefunden.</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="739"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="733"/>
         <source>Cannot open locations file (%1)</source>
         <translation>Kann Location-Datei (%1) nicht öffnen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1265"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1259"/>
         <source>Cannot create new location: %1</source>
         <translation>Kann neue Location nicht erzeugen: %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1331"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="1325"/>
         <source>New mapset successfully created, but cannot be opened: %1</source>
         <translation>Neues Mapset wurde erfolgreich erzeugt, kann aber nicht geöffnet werden: %1</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="749"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="743"/>
         <source>Cannot read locations file (%1):</source>
         <translation>Kann Location-Datei nicht lesen (%1):</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="750"/>
+        <location filename="../src/plugins/grass/qgsgrassnewmapset.cpp" line="744"/>
         <source>
 %1
 at line %2 column %3</source>
@@ -18625,7 +18625,7 @@
     </message>
     <message>
         <location filename="../src/app/legend/qgslegendlayer.cpp" line="438"/>
-        <source>Assign layer CRS to &amp;project</source>
+        <source>Set &amp;project CRS from layer</source>
         <translation>Layer-KBS dem &amp;Projekt zuweisen</translation>
     </message>
     <message>
More information about the QGIS-commit mailing list
