[QGIS Commit] r15471 - trunk/qgis/python/plugins/GdalTools/tools
svn_qgis at osgeo.org
Mon Mar 14 04:51:11 EDT 2011
Author: brushtyler
Date: 2011-03-14 01:51:11 -0700 (Mon, 14 Mar 2011)
New Revision: 15471
trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
allow output size in grid tool to fix #2941
Modified: trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
--- trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-13 23:46:37 UTC (rev 15470)
+++ trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-14 08:51:11 UTC (rev 15471)
@@ -20,6 +20,10 @@
self.setupUi(self)
BasePluginWidget.__init__(self, self.iface, "gdal_grid")
+ # set the default QSpinBoxes and QProgressBar value
+ self.widthSpin.setValue(3000)
+ self.heightSpin.setValue(3000)
self.extentSelector.setCanvas(self.canvas)
#self.extentSelector.stop()
@@ -44,7 +48,8 @@
(self.datametricsCombo, SIGNAL("currentIndexChanged(int)")),
([self.datametricsRadius1Spin, self.datametricsRadius2Spin, self.datametricsAngleSpin, self.datametricsNoDataSpin], SIGNAL("valueChanged(double)")),
(self.datametricsMinPointsSpin, SIGNAL("valueChanged(int)")),
- (self.extentSelector, [SIGNAL("selectionStarted()"), SIGNAL("newExtentDefined()")], self.extentGroup)
+ (self.extentSelector, [SIGNAL("selectionStarted()"), SIGNAL("newExtentDefined()")], self.extentGroup),
+ ( [self.widthSpin, self.heightSpin], SIGNAL( "valueChanged(int)" ), self.resizeGroupBox )
@@ -122,6 +127,10 @@
if self.algorithmCheck.isChecked() and self.algorithmCombo.currentIndex() >= 0:
arguments << "-a"
arguments << self.algorithmArguments(self.algorithmCombo.currentIndex())
+ if self.resizeGroupBox.isChecked():
+ arguments << "-outsize"
+ arguments << str( self.widthSpin.value() )
+ arguments << str( self.heightSpin.value() )
if not self.outputFileEdit.text().isEmpty():
arguments << "-of"
arguments << self.outputFormat
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui 2011-03-13 23:46:37 UTC (rev 15470)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetGrid.ui 2011-03-14 08:51:11 UTC (rev 15471)
@@ -6,7 +6,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>494</width>
+ <width>777</width>
<height>366</height>
</rect>
</property>
@@ -19,8 +19,8 @@
<property name="windowTitle">
<string>Grid</string>
</property>
- <layout class="QGridLayout" name="gridLayout_7">
- <item row="0" column="0">
+ <layout class="QVBoxLayout" name="verticalLayout">
+ <item>
<layout class="QGridLayout" name="gridLayout">
<widget class="QLabel" name="label">
@@ -133,648 +133,711 @@
</item>
</layout>
</item>
- <item row="1" column="0">
- <layout class="QVBoxLayout" name="verticalLayout_2">
- <property name="leftMargin">
- <number>20</number>
+ <item>
+ <widget class="QStackedWidget" name="stackedWidget">
+ <property name="frameShape">
+ <enum>QFrame::NoFrame</enum>
</property>
- <property name="rightMargin">
+ <property name="currentIndex">
+ <number>0</number>
</property>
- <item>
- <widget class="QStackedWidget" name="stackedWidget">
- <property name="frameShape">
- <enum>QFrame::NoFrame</enum>
- </property>
- <property name="currentIndex">
- <number>0</number>
- </property>
- <widget class="QWidget" name="page">
- <layout class="QGridLayout" name="gridLayout_3">
- <widget class="QLabel" name="label_3">
- <property name="text">
- <string>Power</string>
- </property>
- </widget>
+ <widget class="QWidget" name="page">
+ <layout class="QGridLayout" name="gridLayout_3">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label_3">
+ <property name="text">
+ <string>Power</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QDoubleSpinBox" name="invdistPowerSpin">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="decimals">
+ <number>1</number>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2">
+ <widget class="QLabel" name="label_4">
+ <string>Smoothing</string>
+ </property>
+ <property name="indent">
+ <number>30</number>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3">
+ <widget class="QDoubleSpinBox" name="invdistSmothingSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ <property name="maximum">
+ <double>65000.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="4">
+ <widget class="QLabel" name="label_5">
+ <string>Radius1</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="5">
+ <widget class="QDoubleSpinBox" name="invdistRadius1Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="6">
+ <widget class="QLabel" name="label_6">
+ <string>Radius2</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="7">
+ <widget class="QDoubleSpinBox" name="invdistRadius2Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label_8">
+ <string>Max points</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QSpinBox" name="invdistMaxPointsSpin">
+ </sizepolicy>
+ </property>
+ <number>65000</number>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="2">
+ <widget class="QLabel" name="label_9">
+ <string>Min points</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="3">
+ <widget class="QSpinBox" name="invdistMinPointsSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="4">
+ <widget class="QLabel" name="label_7">
+ <string>Angle</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="5">
+ <widget class="QDoubleSpinBox" name="invdistAngleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ <double>359.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="6">
+ <widget class="QLabel" name="label_10">
+ <string>No data</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="7">
+ <widget class="QDoubleSpinBox" name="invdistNoDataSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
+ <spacer name="verticalSpacer_4">
+ <property name="orientation">
+ <enum>Qt::Vertical</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>0</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_2">
+ <layout class="QGridLayout" name="gridLayout_4">
+ <widget class="QLabel" name="label_21">
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="averageRadius1Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_19">
+ </property>
+ <number>40</number>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="averageRadius2Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_22">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="averageAngleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_20">
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="averageMinPointsSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_23">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="averageNoDataSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_5">
+ <layout class="QGridLayout" name="gridLayout_5">
+ <widget class="QLabel" name="label_26">
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="nearestRadius1Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_24">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="nearestRadius2Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_27">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="nearestAngleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_28">
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="nearestNoDataSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer_2">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="page_6">
+ <layout class="QGridLayout" name="gridLayout_6">
+ <widget class="QLabel" name="label_25">
+ <string>Metrics</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="datametricsCombo">
+ </sizepolicy>
+ </property>
+ <item>
+ <string>Minimum</string>
+ </property>
</item>
- <item row="0" column="1">
- <widget class="QDoubleSpinBox" name="invdistPowerSpin">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="decimals">
- <number>1</number>
- </property>
- </widget>
+ <item>
+ <string>Maximum</string>
+ </property>
</item>
- <item row="2" column="0">
- <widget class="QLabel" name="label_5">
- <string>Radius1</string>
- </property>
- </widget>
+ <item>
+ <string>Range</string>
+ </property>
</item>
- <item row="2" column="1">
- <widget class="QDoubleSpinBox" name="invdistRadius1Spin">
- </sizepolicy>
- </property>
- </property>
- <property name="maximum">
- <double>65000.000000000000000</double>
- </property>
- </widget>
- </item>
- <item row="4" column="0">
- <widget class="QLabel" name="label_7">
- <string>Angle</string>
- </property>
- </widget>
- </item>
- <item row="4" column="1">
- <widget class="QDoubleSpinBox" name="invdistAngleSpin">
- </sizepolicy>
- </property>
- </property>
- <double>359.000000000000000</double>
- </property>
- </widget>
- </item>
- <item row="8" column="0">
- <spacer name="verticalSpacer_4">
- <property name="orientation">
- <enum>Qt::Vertical</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>20</width>
- <height>0</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="5" column="1">
- <widget class="QSpinBox" name="invdistMaxPointsSpin">
- </sizepolicy>
- </property>
- <number>65000</number>
- </property>
- </widget>
- </item>
- <item row="5" column="0">
- <widget class="QLabel" name="label_8">
- <string>Max points</string>
- </property>
- </widget>
- </item>
- <item row="5" column="2">
- <widget class="QLabel" name="label_9">
- <string>Min points</string>
- </property>
- <property name="indent">
- <number>40</number>
- </property>
- </widget>
- </item>
- <item row="5" column="3">
- <widget class="QSpinBox" name="invdistMinPointsSpin">
- </sizepolicy>
- </property>
- </property>
- </widget>
- </item>
- <item row="2" column="2">
- <widget class="QLabel" name="label_6">
- <string>Radius2</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="2" column="3">
- <widget class="QDoubleSpinBox" name="invdistRadius2Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <item row="4" column="2">
- <widget class="QLabel" name="label_10">
- <string>No data</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="4" column="3">
- <widget class="QDoubleSpinBox" name="invdistNoDataSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="3">
- <widget class="QDoubleSpinBox" name="invdistSmothingSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <item row="0" column="2">
- <widget class="QLabel" name="label_4">
- <string>Smoothing</string>
- </property>
- </property>
- </widget>
- </item>
- </layout>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_31">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="datametricsRadius1Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_29">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="datametricsRadius2Spin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_32">
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="datametricsAngleSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_33">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QDoubleSpinBox" name="datametricsNoDataSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLabel" name="label_30">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <widget class="QSpinBox" name="datametricsMinPointsSpin">
+ </sizepolicy>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <spacer name="verticalSpacer_3">
+ </property>
+ <size>
+ <width>20</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ <item>
+ <widget class="QGroupBox" name="resizeGroupBox">
+ <property name="title">
+ <string>Resize</string>
+ </property>
+ <property name="checkable">
+ <bool>true</bool>
+ </property>
+ <property name="checked">
+ <bool>false</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_7">
+ <widget class="QLabel" name="label_11">
+ <sizepolicy hsizetype="Fixed" vsizetype="Preferred">
+ </sizepolicy>
+ </property>
+ <string>Width</string>
+ </property>
</widget>
- <widget class="QWidget" name="page_2">
- <layout class="QGridLayout" name="gridLayout_4">
- <widget class="QLabel" name="label_21">
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="averageRadius1Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_22">
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="averageAngleSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <item row="3" column="0">
- <widget class="QLabel" name="label_20">
- </property>
- </widget>
- </item>
- <item row="3" column="1">
- <widget class="QSpinBox" name="averageMinPointsSpin">
- </sizepolicy>
- </property>
- </property>
- </widget>
- </item>
- <spacer name="verticalSpacer">
- </property>
- <size>
- <width>20</width>
- </size>
- </property>
- </spacer>
- </item>
- <widget class="QLabel" name="label_19">
- </property>
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="averageRadius2Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_23">
- </property>
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="averageNoDataSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- </layout>
+ </item>
+ <widget class="QSpinBox" name="widthSpin">
+ <number>999999</number>
+ </property>
</widget>
- <widget class="QWidget" name="page_5">
- <layout class="QGridLayout" name="gridLayout_5">
- <widget class="QLabel" name="label_26">
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="nearestRadius1Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_27">
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="nearestAngleSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <spacer name="verticalSpacer_2">
- </property>
- <size>
- <width>20</width>
- </size>
- </property>
- </spacer>
- </item>
- <widget class="QLabel" name="label_24">
- </property>
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="nearestRadius2Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_28">
- </property>
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="nearestNoDataSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- </layout>
+ </item>
+ <widget class="QLabel" name="label_12">
+ </sizepolicy>
+ </property>
+ <string>Height</string>
+ </property>
+ </property>
</widget>
- <widget class="QWidget" name="page_6">
- <layout class="QGridLayout" name="gridLayout_6">
- <widget class="QLabel" name="label_25">
- <string>Metrics</string>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="datametricsCombo">
- </sizepolicy>
- </property>
- <item>
- <string>Minimum</string>
- </property>
- </item>
- <item>
- <string>Maximum</string>
- </property>
- </item>
- <item>
- <string>Range</string>
- </property>
- </item>
- </widget>
- </item>
- <widget class="QLabel" name="label_31">
- </property>
- </widget>
- </item>
- <item row="1" column="1">
- <widget class="QDoubleSpinBox" name="datametricsRadius1Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_32">
- </property>
- </widget>
- </item>
- <widget class="QDoubleSpinBox" name="datametricsAngleSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <widget class="QLabel" name="label_30">
- </property>
- </widget>
- </item>
- <widget class="QSpinBox" name="datametricsMinPointsSpin">
- </sizepolicy>
- </property>
- </property>
- </widget>
- </item>
- <item row="6" column="0">
- <spacer name="verticalSpacer_3">
- </property>
- <size>
- <width>20</width>
- </size>
- </property>
- </spacer>
- </item>
- <item row="1" column="2">
- <widget class="QLabel" name="label_29">
- </property>
- </property>
- </widget>
- </item>
- <item row="1" column="3">
- <widget class="QDoubleSpinBox" name="datametricsRadius2Spin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- <item row="3" column="2">
- <widget class="QLabel" name="label_33">
- </property>
- </property>
- </widget>
- </item>
- <item row="3" column="3">
- <widget class="QDoubleSpinBox" name="datametricsNoDataSpin">
- </sizepolicy>
- </property>
- </property>
- </property>
- </widget>
- </item>
- </layout>
+ </item>
+ <widget class="QSpinBox" name="heightSpin">
+ </property>
</widget>
- </widget>
- </item>
- </layout>
+ </item>
+ </layout>
+ </widget>
</item>
+ <item>
<widget class="QGroupBox" name="extentGroup">
<string>Extent</string>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui 2011-03-13 23:46:37 UTC (rev 15470)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetRasterize.ui 2011-03-14 08:51:11 UTC (rev 15471)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>509</width>
- <height>214</height>
+ <height>189</height>
</rect>
</property>
@@ -123,14 +123,17 @@
<bool>false</bool>
</property>
- <layout class="QGridLayout" name="gridLayout">
- <property name="bottomMargin">
- </property>
+ </sizepolicy>
+ </property>
- <string>Image width</string>
</property>
</widget>
</item>
@@ -141,14 +144,23 @@
</property>
</widget>
</item>
+ </sizepolicy>
+ </property>
- <string>Image height</string>
</property>
+ </property>
</widget>
</item>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2011-03-13 23:46:37 UTC (rev 15470)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetWarp.ui 2011-03-14 08:51:11 UTC (rev 15471)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>415</width>
- <height>442</height>
+ <height>417</height>
</rect>
</property>
@@ -236,14 +236,17 @@
<bool>false</bool>
</property>
- </property>
+ </sizepolicy>
+ </property>
</property>
</widget>
</item>
@@ -254,14 +257,23 @@
</property>
</widget>
</item>
+ </sizepolicy>
+ </property>
</property>
+ </property>
</widget>
</item>
