[QGIS Commit] r15474 - in trunk/qgis/python/plugins/GdalTools: .
tools
svn_qgis at osgeo.org
Mon Mar 14 12:01:10 EDT 2011
Author: brushtyler
Date: 2011-03-14 09:01:10 -0700 (Mon, 14 Mar 2011)
New Revision: 15474
trunk/qgis/python/plugins/GdalTools/GdalTools.py
trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py
trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py
trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
trunk/qgis/python/plugins/GdalTools/tools/doContour.py
trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
trunk/qgis/python/plugins/GdalTools/tools/doInfo.py
trunk/qgis/python/plugins/GdalTools/tools/doNearBlack.py
trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
trunk/qgis/python/plugins/GdalTools/tools/doPctRgb.py
trunk/qgis/python/plugins/GdalTools/tools/doPolygonize.py
trunk/qgis/python/plugins/GdalTools/tools/doProximity.py
trunk/qgis/python/plugins/GdalTools/tools/doRasterize.py
trunk/qgis/python/plugins/GdalTools/tools/doRgbPct.py
trunk/qgis/python/plugins/GdalTools/tools/doSettings.py
trunk/qgis/python/plugins/GdalTools/tools/doSieve.py
trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py
trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py
refresh list of layers when layers in TOC change
Modified: trunk/qgis/python/plugins/GdalTools/GdalTools.py
--- trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -78,8 +78,9 @@
+ QCoreApplication.translate( "GdalTools", "This version of Gdal Tools requires at least QGIS version 1.0.0\nPlugin will not be enabled." ) )
return None
- from tools.GdalTools_utils import Version, GdalConfig
+ from tools.GdalTools_utils import Version, GdalConfig, LayerRegistry
self.GdalVersion = Version( GdalConfig.version() )
+ LayerRegistry.setIface( self.iface )
# find the Raster menu
rasterMenu = None
Modified: trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py
--- trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -8,8 +8,10 @@
from PyQt4.QtCore import *
from PyQt4.QtGui import *
from qgis.core import *
from qgis.gui import *
from osgeo import gdal
from osgeo.gdalconst import *
from osgeo import ogr
@@ -90,35 +92,73 @@
extensions << FileFilter.getFilterExtensions( f )
return extensions
-def getRasterLayers():
- # mantein the reference between combobox indexes and canvas layers
- layers = dict()
- count = 0
- names = []
- layerMap = QgsMapLayerRegistry.instance().mapLayers()
- for name, layer in layerMap.iteritems():
- # only raster layers, but not WMS ones
- if layer.type() == layer.RasterLayer:
- if layer.usesProvider() and layer.providerKey() != 'gdal':
- continue
- layers[count] = layer
- names.append(layer.name())
- count = count +1
- return (layers, names)
+class LayerRegistry(QObject):
-def getVectorLayers():
- layers = dict()
- count = 0
- names = []
- if layer.type() == layer.VectorLayer:
- count = count +1
+ _instance = None
+ _iface = None
+ @staticmethod
+ def instance():
+ if LayerRegistry._instance == None:
+ LayerRegistry._instance = LayerRegistry()
+ return LayerRegistry._instance
+ @staticmethod
+ def setIface(iface):
+ LayerRegistry._iface = iface
+ layers = []
+ def __init__(self):
+ QObject.__init__(self)
+ if LayerRegistry._instance != None:
+ return
+ LayerRegistry.layers = self.getAllLayers()
+ LayerRegistry._instance = self
+ self.connect(QgsMapLayerRegistry.instance(), SIGNAL("removedAll()"), self.removeAllLayers)
+ self.connect(QgsMapLayerRegistry.instance(), SIGNAL("layerWasAdded(QgsMapLayer *)"), self.layerAdded)
+ self.connect(QgsMapLayerRegistry.instance(), SIGNAL("layerWillBeRemoved(QString)"), self.removeLayer)
+ def getAllLayers(self):
+ if LayerRegistry._iface and hasattr(LayerRegistry._iface, 'legendInterface'):
+ return LayerRegistry._iface.legendInterface().layers()
+ return QgsMapLayerRegistry.instance().mapLayers().values()
+ def layerAdded(self, layer):
+ LayerRegistry.layers.append( layer )
+ self.emit( SIGNAL( "layersChanged" ) )
+ def removeLayer(self, layerId):
+ LayerRegistry.layers = filter( lambda x: x.getLayerID() != layerId, LayerRegistry.layers)
+ def removeAllLayers(self):
+ LayerRegistry.layers = []
+ def getRasterLayers(self):
+ layers = []
+ names = []
+ for layer in LayerRegistry.layers:
+ # only gdal raster layers
+ if layer.type() == layer.RasterLayer:
+ if layer.usesProvider() and layer.providerKey() != 'gdal':
+ continue
+ layers.append(layer)
+ names.append(layer.name())
+ return (layers, names)
+ def getVectorLayers(self):
+ layers = []
+ names = []
+ if layer.type() == layer.VectorLayer:
def getRasterFiles(path, recursive=False):
rasters = QStringList()
if not QFileInfo(path).exists():
Modified: trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py
--- trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -17,6 +17,7 @@
def __init__(self, parent, iface, pluginBase, pluginName, pluginCommand):
QDialog.__init__(self, parent)
+ self.setAttribute(Qt.WA_DeleteOnClose)
self.iface = iface
self.process = QProcess(self)
Modified: trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
--- trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -13,6 +13,7 @@
def __init__(self, iface):
QDialog.__init__(self, iface.mainWindow())
self.iface = iface
self.setupUi(self)
Modified: trunk/qgis/python/plugins/GdalTools/tools/doContour.py
--- trunk/qgis/python/plugins/GdalTools/tools/doContour.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doContour.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -33,11 +33,12 @@
self.connect(self.selectOutputDirButton, SIGNAL("clicked()"), self.fillOutputDirEdit)
# fill layers combo
+ self.connect(Utils.LayerRegistry.instance(), SIGNAL("layersChanged"), self.fillInputLayerCombo)
self.fillInputLayerCombo()
def fillInputLayerCombo( self ):
self.inputLayerCombo.clear()
- ( self.layers, names ) = Utils.getRasterLayers()
+ ( self.layers, names ) = Utils.LayerRegistry.instance().getRasterLayers()
self.inputLayerCombo.addItems( names )
def fillInputFileEdit(self):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doGrid.py
--- trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doGrid.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -58,8 +58,6 @@
self.connect(self.inputLayerCombo, SIGNAL("currentIndexChanged(int)"), self.fillFieldsCombo)
self.connect(self.extentGroup, SIGNAL("toggled(bool)"), self.onExtentCheckedChenged)
- # fill layers combo
- self.fillInputLayerCombo()
def onClosing(self):
self.extentSelector.stop()
@@ -68,9 +66,12 @@
def onExtentCheckedChenged(self, enabled):
self.extentSelector.start() if enabled else self.extentSelector.stop()
+ def onLayersChanged(self):
+ self.fillInputLayerCombo()
def fillInputLayerCombo(self):
- ( self.layers, names ) = Utils.getVectorLayers()
+ ( self.layers, names ) = Utils.LayerRegistry.instance().getVectorLayers()
def fillFieldsCombo(self):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doInfo.py
--- trunk/qgis/python/plugins/GdalTools/tools/doInfo.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doInfo.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -40,8 +40,6 @@
self.copyAll = QAction( self.tr( "Copy all" ), self )
QObject.connect( self.copyAll, SIGNAL( "triggered()" ), self.doCopyAll )
def doCopyLine( self ):
output = QString()
@@ -71,9 +69,12 @@
else:
QWidget.keyPressEvent( self, e )
def finished( self ):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doNearBlack.py
--- trunk/qgis/python/plugins/GdalTools/tools/doNearBlack.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doNearBlack.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -33,12 +33,12 @@
self.connect(self.selectInputFileButton, SIGNAL("clicked()"), self.fillInputFileEdit)
self.connect(self.selectOutputFileButton, SIGNAL("clicked()"), self.fillOutputFileEdit)
Modified: trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
--- trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -44,8 +44,6 @@
self.connect( self.selectInputFileButton, SIGNAL( "clicked()" ), self.fillInputFile )
self.connect( self.batchCheck, SIGNAL( "stateChanged( int )" ), self.switchToolMode )
# switch to batch or normal mode
def switchToolMode( self ):
@@ -71,9 +69,12 @@
QObject.disconnect( self.selectInputFileButton, SIGNAL( "clicked()" ), self.fillInputDir )
QObject.connect( self.selectInputFileButton, SIGNAL( "clicked()" ), self.fillInputFile )
def fillInputFile( self ):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doPctRgb.py
--- trunk/qgis/python/plugins/GdalTools/tools/doPctRgb.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doPctRgb.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -39,7 +39,6 @@
@@ -77,9 +76,12 @@
QObject.connect( self.selectOutputFileButton, SIGNAL( "clicked()" ), self.fillOutputFileEdit )
def fillInputFile(self):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doPolygonize.py
--- trunk/qgis/python/plugins/GdalTools/tools/doPolygonize.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doPolygonize.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -31,12 +31,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/doProximity.py
--- trunk/qgis/python/plugins/GdalTools/tools/doProximity.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doProximity.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -37,12 +37,12 @@
+ ( self.layers, names ) = Utils.LayerRegistry().getRasterLayers()
Modified: trunk/qgis/python/plugins/GdalTools/tools/doRasterize.py
--- trunk/qgis/python/plugins/GdalTools/tools/doRasterize.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doRasterize.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -37,12 +37,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/doRgbPct.py
--- trunk/qgis/python/plugins/GdalTools/tools/doRgbPct.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doRgbPct.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -37,7 +37,6 @@
@@ -75,9 +74,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/doSettings.py
--- trunk/qgis/python/plugins/GdalTools/tools/doSettings.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doSettings.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -11,6 +11,7 @@
class GdalToolsSettingsDialog( QDialog, Ui_Dialog ):
def __init__( self, iface ):
QDialog.__init__( self, iface.mainWindow() )
self.iface = iface
self.setupUi( self )
Modified: trunk/qgis/python/plugins/GdalTools/tools/doSieve.py
--- trunk/qgis/python/plugins/GdalTools/tools/doSieve.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doSieve.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -32,12 +32,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py
--- trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doTranslate.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -61,8 +61,6 @@
# add raster filters to combo
self.formatCombo.addItems( Utils.FileFilter.allRastersFilter().split( ";;" ) )
- # add layers to combo
self.setCommandViewerEnabled( not self.batchCheck.isChecked() )
@@ -103,9 +101,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/doWarp.py
--- trunk/qgis/python/plugins/GdalTools/tools/doWarp.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/doWarp.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -51,7 +51,6 @@
self.connect(self.selectTargetSRSButton, SIGNAL("clicked()"), self.fillTargetSRSEdit)
@@ -89,9 +88,12 @@
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py
--- trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py 2011-03-14 12:48:50 UTC (rev 15473)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py 2011-03-14 16:01:10 UTC (rev 15474)
@@ -24,11 +24,18 @@
def someValueChanged(self):
self.emit(SIGNAL("valuesChanged(const QStringList &)"), self.getArguments())
+ pass
def exec_(self):
+ self.connect(Utils.LayerRegistry.instance(), SIGNAL("layersChanged"), self.onLayersChanged)
+ self.layersChanged()
self.someValueChanged()
return self.base.exec_()
def show_(self):
+ self.onLayersChanged()
return self.base.show()
@@ -40,6 +47,7 @@
self.base.onRun()
+ self.disconnect(Utils.LayerRegistry.instance(), SIGNAL("layersChanged"), self.onLayersChanged)
self.base.onClosing()
def onHelp(self):
