[QGIS Commit] r15484 - trunk/qgis/src/plugins/spatialquery
svn_qgis at osgeo.org
Mon Mar 14 17:42:40 EDT 2011
Author: timlinux
Date: 2011-03-14 14:42:40 -0700 (Mon, 14 Mar 2011)
New Revision: 15484
trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
Updates for spatial query plugin from Luiz.
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp 2011-03-14 21:36:02 UTC (rev 15483)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquery.cpp 2011-03-14 21:42:40 UTC (rev 15484)
@@ -15,7 +15,7 @@
* (at your option) any later version. *
-/* $Id: qgsspatialquery.cpp 15141 2011-02-08 13:34:43Z jef $ */
+/* $Id: qgsspatialquery.cpp 15302 2011-03-01 08:00:54Z timlinux $ */
#include <QMessageBox>
@@ -99,7 +99,7 @@
QMap<QString, int> * operations = new QMap<QString, int>;
operations->insert( QObject::tr( "Intersects" ), Intersects );
- operations->insert( QObject::tr( "Disjoint" ), Disjoint );
+ operations->insert( QObject::tr( "Is disjoint" ), Disjoint );
short int dimTarget = 0, dimReference = 0;
dimTarget = dimensionGeometry( lyrTarget->geometryType() );
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2011-03-14 21:36:02 UTC (rev 15483)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp 2011-03-14 21:42:40 UTC (rev 15484)
@@ -15,7 +15,7 @@
-/* $Id$ */
+/* $Id: qgsspatialquerydialog.cpp 15448 2011-03-12 10:17:05Z jef $ */
#include <QDateTime>
@@ -44,8 +44,6 @@
initGui();
connectAll();
- mMsgLayersLessTwo = tr( "The spatial query requires at least two layers" );
} // QgsSpatialQueryDialog::QgsSpatialQueryDialog( QWidget* parent, QgisInterface* iface )
QgsSpatialQueryDialog::~QgsSpatialQueryDialog()
@@ -59,12 +57,40 @@
} // QgsSpatialQueryDialog::~QgsSpatialQueryDialog()
-void QgsSpatialQueryDialog::messageLayersLessTwo()
+bool QgsSpatialQueryDialog::hasPossibleQuery( QString &msg )
- QString msgLayersLessTwo = tr( "The spatial query requires at least two layers" );
- QMessageBox::warning( 0, tr( "Insufficient number of layers" ), msgLayersLessTwo, QMessageBox::Ok );
-} // void QgsSpatialQueryDialog::messageLayersLessTwo()
+ // Count the number of vector layer
+ QMap <QString, QgsMapLayer*> layers = QgsMapLayerRegistry::instance()->mapLayers();
+ QMapIterator <QString, QgsMapLayer*> item( layers );
+ QgsMapLayer * mapLayer = NULL;
+ QgsVectorLayer * lyr = NULL;
+ unsigned int totalVector = 0;
+ while ( item.hasNext() )
+ item.next();
+ mapLayer = item.value();
+ if ( mapLayer->type() != QgsMapLayer::VectorLayer )
+ continue;
+ lyr = qobject_cast<QgsVectorLayer *>( mapLayer );
+ if ( !lyr )
+ continue;
+ totalVector++;
+ // check is possible query
+ if( totalVector < 2 ) {
+ msg = tr( "The spatial query requires at least two vector layers" );
+ return false;
+ else {
+ return true;
+} // bool QgsSpatialQueryDialog::hasPossibleQuery( QString &msg )
void QgsSpatialQueryDialog::initGui()
mRubberSelectId->setStyle( 250, 0, 0, 2 ); // Same identify
@@ -515,8 +541,8 @@
cbTargetLayer->blockSignals( true );
- QMap <QString, QgsMapLayer*> map = QgsMapLayerRegistry::instance()->mapLayers();
- QMapIterator <QString, QgsMapLayer*> item( map );
QString layerId;
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h 2011-03-14 21:36:02 UTC (rev 15483)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.h 2011-03-14 21:42:40 UTC (rev 15484)
@@ -15,7 +15,7 @@
-/* $Id$ */
+/* $Id: qgsspatialquerydialog.h 15303 2011-03-01 08:10:18Z jef $ */
#ifndef SPATIALQUERYDIALOG_H
#define SPATIALQUERYDIALOG_H
@@ -44,8 +44,8 @@
//! Destructor
~QgsSpatialQueryDialog();
- //! Message about number layers less Two
- static void messageLayersLessTwo();
+ //! Verify is possible execute the query
+ static bool hasPossibleQuery( QString &msg );
private slots:
//! Slots for signs of Dialog
@@ -157,9 +157,6 @@
QString mSourceSelected;
bool mIsSelectedOperator;
- // Message
- QString mMsgLayersLessTwo;
void MsgDEBUG( QString sMSg );
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp 2011-03-14 21:36:02 UTC (rev 15483)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialqueryplugin.cpp 2011-03-14 21:42:40 UTC (rev 15484)
@@ -16,7 +16,7 @@
-/* $Id: qgsspatialqueryplugin.cpp 14897 2010-12-12 19:19:54Z wonder $ */
+/* $Id: qgsspatialqueryplugin.cpp 15302 2011-03-01 08:00:54Z timlinux $ */
@@ -107,9 +107,10 @@
if ( !mDialog )
- if ( QgsMapLayerRegistry::instance()->mapLayers().size() < 2 )
+ QString msg;
+ if ( ! QgsSpatialQueryDialog::hasPossibleQuery( msg ) )
- QgsSpatialQueryDialog::messageLayersLessTwo();
+ QMessageBox::warning( mIface->mainWindow(), tr( "Not possible execute the query" ), msg, QMessageBox::Ok );
return;
mDialog = new QgsSpatialQueryDialog( mIface->mainWindow(), mIface );
