[QGIS Commit] r15500 - in trunk/qgis/src/core: . symbology-ng
svn_qgis at osgeo.org
Tue Mar 15 12:03:50 EDT 2011
Author: mhugent
Date: 2011-03-15 09:03:50 -0700 (Tue, 15 Mar 2011)
New Revision: 15500
trunk/qgis/src/core/qgsclipper.h
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
Port polygon clip for symbology-ng from threading branch. Fixes freezes when zooming in
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h 2011-03-15 15:00:52 UTC (rev 15499)
+++ trunk/qgis/src/core/qgsclipper.h 2011-03-15 16:03:50 UTC (rev 15500)
@@ -79,6 +79,8 @@
std::vector<double>& y,
bool shapeOpen );
+ static void trimFeature( QPolygonF& pts, bool shapeOpen );
/**Reads a polyline from WKB and clips it to clipExtent
@param wkb pointer to the start of the line wkb
@param clipExtent clipping bounds
@@ -99,15 +101,26 @@
Boundary b,
bool shapeOpen );
+ static void trimFeatureToBoundary( const QPolygonF& inPts,
+ QPolygonF& outPts,
+ Boundary b,
+ bool shapeOpen );
// Determines if a point is inside or outside the given boundary
static bool inside( const double x, const double y, Boundary b );
+ static bool inside( const QPointF& pt, Boundary b );
// Calculates the intersection point between a line defined by a
// (x1, y1), and (x2, y2) and the given boundary
static QgsPoint intersect( const double x1, const double y1,
const double x2, const double y2,
Boundary b );
+ static QPointF intersect( const QPointF& pt1,
+ const QPointF& pt2,
+ Boundary b );
//Implementation of 'Fast clipping' algorithm (Sobkow et al. 1987, Computers & Graphics Vol.11, 4, p.459-467)
static bool clipLineSegment( double xLeft, double xRight, double yBottom, double yTop, double& x0, double& y0, double& x1, double& y1 );
@@ -166,6 +179,36 @@
trimFeatureToBoundary( tmpX, tmpY, x, y, YMin, shapeOpen );
+inline void QgsClipper::trimFeature( QPolygonF& pts, bool shapeOpen )
+ bool needs_clipping = false;
+ const QPointF* ptsData = pts.constData();
+ for ( int i = 0; i < pts.count(); i++, ptsData++ )
+ if ( ptsData->x() < MIN_X || ptsData->x() > MAX_X
+ || ptsData->y() < MIN_Y || ptsData->y() > MAX_Y )
+ needs_clipping = true;
+ break;
+ if ( !needs_clipping )
+ return;
+ QPolygonF tmpPts;
+ tmpPts.reserve( pts.size() );
+ trimFeatureToBoundary( pts, tmpPts, XMax, shapeOpen );
+ pts.clear();
+ trimFeatureToBoundary( tmpPts, pts, YMax, shapeOpen );
+ tmpPts.clear();
+ trimFeatureToBoundary( pts, tmpPts, XMin, shapeOpen );
+ pts.clear();
+ trimFeatureToBoundary( tmpPts, pts, YMin, shapeOpen );
// An auxilary function that is part of the polygon trimming
// code. Will trim the given polygon to the given boundary and return
// the trimmed polygon in the out pointer. Uses Sutherland and
@@ -237,6 +280,52 @@
+inline void QgsClipper::trimFeatureToBoundary(
+ const QPolygonF& inPts, QPolygonF& outPts,
+ Boundary b, bool shapeOpen )
+ // The shapeOpen parameter selects whether this function treats the
+ // shape as open or closed. False is appropriate for polygons and
+ // true for polylines.
+ unsigned int i1 = inPts.size() - 1; // start with last point
+ // and compare to the first point initially.
+ for ( unsigned int i2 = 0; i2 < inPts.size() ; ++i2 )
+ { // look at each edge of the polygon in turn
+ if ( inside( inPts[i2], b ) ) // end point of edge is inside boundary
+ if ( inside( inPts[i1], b ) )
+ outPts.append( inPts[i2] );
+ else
+ // edge crosses into the boundary, so trim back to the boundary, and
+ // store both ends of the new edge
+ if ( !( i2 == 0 && shapeOpen ) )
+ outPts.append( intersect( inPts[i1], inPts[i2], b ) );
+ else // end point of edge is outside boundary
+ // start point is in boundary, so need to trim back
+ i1 = i2;
// An auxilary function to trimPolygonToBoundarY() that returns
// whether a point is inside or outside the given boundary.
@@ -264,7 +353,23 @@
return false;
+inline bool QgsClipper::inside( const QPointF& pt, Boundary b )
+ switch ( b )
+ case XMax: // x < MAX_X is inside
+ return ( pt.x() < MAX_X );
+ case XMin: // x > MIN_X is inside
+ return ( pt.x() > MIN_X );
+ case YMax: // y < MAX_Y is inside
+ return ( pt.y() < MAX_Y );
+ case YMin: // y > MIN_Y is inside
+ return ( pt.y() > MIN_Y );
+ return false;
// An auxilary function to trimPolygonToBoundarY() that calculates and
// returns the intersection of the line defined by the given points
// and the given boundary.
@@ -316,6 +421,52 @@
return p;
+inline QPointF QgsClipper::intersect( const QPointF& pt1,
+ Boundary b )
+ // This function assumes that the two given points (x1, y1), and
+ // (x2, y2) cross the given boundary. Making this assumption allows
+ // some optimisations.
+ double r_n = SMALL_NUM, r_d = SMALL_NUM;
+ const double x1 = pt1.x(), x2 = pt2.x();
+ const double y1 = pt1.y(), y2 = pt2.y();
+ switch ( b )
+ case XMax: // x = MAX_X boundary
+ r_n = -( x1 - MAX_X ) * ( MAX_Y - MIN_Y );
+ r_d = ( x2 - x1 ) * ( MAX_Y - MIN_Y );
+ break;
+ case XMin: // x = MIN_X boundary
+ r_n = -( x1 - MIN_X ) * ( MAX_Y - MIN_Y );
+ break;
+ case YMax: // y = MAX_Y boundary
+ r_n = ( y1 - MAX_Y ) * ( MAX_X - MIN_X );
+ r_d = -( y2 - y1 ) * ( MAX_X - MIN_X );
+ break;
+ case YMin: // y = MIN_Y boundary
+ r_n = ( y1 - MIN_Y ) * ( MAX_X - MIN_X );
+ break;
+ if ( std::abs( r_d ) > SMALL_NUM && std::abs( r_n ) > SMALL_NUM )
+ { // they cross
+ double r = r_n / r_d;
+ return QPointF( x1 + r*( x2 - x1 ), y1 + r*( y2 - y1 ) );
+ else
+ // Should never get here, but if we do for some reason, cause a
+ // clunk because something else is wrong if we do.
+ Q_ASSERT( std::abs( r_d ) > SMALL_NUM && std::abs( r_n ) > SMALL_NUM );
+ return QPointF();
inline void QgsClipper::clipStartTop( double& x0, double& y0, const double& x1, const double& y1, double yMax )
x0 += ( x1 - x0 ) * ( yMax - y0 ) / ( y1 - y0 );
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2011-03-15 15:00:52 UTC (rev 15499)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2011-03-15 16:03:50 UTC (rev 15500)
@@ -1,6 +1,6 @@
#include "qgssymbollayerv2.h"
+#include "qgsclipper.h"
#include "qgsrenderer.h"
#include "qgsrendercontext.h"
@@ -74,17 +74,28 @@
if ( rings == NULL )
// simple polygon without holes
- p->drawPolygon( points );
+ // clip polygon rings! Qt (as of version 4.6) has a slow algorithm for
+ // clipping painter paths: we will clip the rings by ourselves, so
+ // the clipping in Qt will not be triggered.
+ QPolygonF ring = points;
+ QgsClipper::trimFeature( ring, false );
+ p->drawPolygon( ring );
else
// polygon with holes must be drawn using painter path
QPainterPath path;
- path.addPolygon( points );
+ QPolygonF outerRing = points;
+ QgsClipper::trimFeature( outerRing, false );
+ path.addPolygon( outerRing );
QList<QPolygonF>::const_iterator it = rings->constBegin();
for ( ; it != rings->constEnd(); ++it )
- path.addPolygon( *it );
+ QPolygonF ring = *it;
+ path.addPolygon( ring );
p->drawPath( path );
