[QGIS Commit] r15504 - in trunk/qgis/src: app core mapserver
plugins/dxf2shp_converter plugins/sqlanywhere
svn_qgis at osgeo.org
Tue Mar 15 13:38:26 EDT 2011
Author: jef
Date: 2011-03-15 10:38:26 -0700 (Tue, 15 Mar 2011)
New Revision: 15504
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/qgsclipper.h
trunk/qgis/src/core/qgsdiagram.h
trunk/qgis/src/core/qgsdiagramrendererv2.h
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/core/qgspallabeling.cpp
trunk/qgis/src/mapserver/qgsfilter.cpp
trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
trunk/qgis/src/plugins/sqlanywhere/CMakeLists.txt
fix warnings and windows build
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-03-15 17:38:26 UTC (rev 15504)
@@ -735,7 +735,6 @@
ds.maxScaleDenominator = -1;
- QgsDiagramRendererV2* r = 0;
if ( mFixedSizeCheckBox->isChecked() )
QgsSingleCategoryDiagramRenderer* dr = new QgsSingleCategoryDiagramRenderer();
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/core/qgsclipper.h 2011-03-15 17:38:26 UTC (rev 15504)
@@ -291,7 +291,7 @@
unsigned int i1 = inPts.size() - 1; // start with last point
// and compare to the first point initially.
- for ( unsigned int i2 = 0; i2 < inPts.size() ; ++i2 )
+ for ( int i2 = 0; i2 < inPts.size() ; ++i2 )
{ // look at each edge of the polygon in turn
if ( inside( inPts[i2], b ) ) // end point of edge is inside boundary
Modified: trunk/qgis/src/core/qgsdiagram.h
--- trunk/qgis/src/core/qgsdiagram.h 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/core/qgsdiagram.h 2011-03-15 17:38:26 UTC (rev 15504)
@@ -11,7 +11,7 @@
class QgsRenderContext;
/**Base class for all diagram types*/
-class QgsDiagram
+class CORE_EXPORT QgsDiagram
public:
/**Draws the diagram at the given position (in pixel coordinates)*/
@@ -24,7 +24,7 @@
QFont scaledFont( const QgsDiagramSettings& s, const QgsRenderContext& c );
-class QgsTextDiagram: public QgsDiagram
+class CORE_EXPORT QgsTextDiagram: public QgsDiagram
public:
enum Shape
@@ -57,7 +57,7 @@
void lineEllipseIntersection( const QPointF& lineStart, const QPointF& lineEnd, const QPointF& ellipseMid, double r1, double r2, QList<QPointF>& result ) const;
-class QgsPieDiagram: public QgsDiagram
+class CORE_EXPORT QgsPieDiagram: public QgsDiagram
public:
QgsPieDiagram();
Modified: trunk/qgis/src/core/qgsdiagramrendererv2.h
--- trunk/qgis/src/core/qgsdiagramrendererv2.h 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/core/qgsdiagramrendererv2.h 2011-03-15 17:38:26 UTC (rev 15504)
@@ -92,7 +92,7 @@
/**Returns diagram settings for a feature*/
-class QgsDiagramRendererV2
+class CORE_EXPORT QgsDiagramRendererV2
public:
@@ -142,7 +142,7 @@
/**Renders the diagrams for all features with the same settings*/
-class QgsSingleCategoryDiagramRenderer: public QgsDiagramRendererV2
+class CORE_EXPORT QgsSingleCategoryDiagramRenderer: public QgsDiagramRendererV2
public:
@@ -168,7 +168,7 @@
QgsDiagramSettings mSettings;
-class QgsLinearlyInterpolatedDiagramRenderer: public QgsDiagramRendererV2
+class CORE_EXPORT QgsLinearlyInterpolatedDiagramRenderer: public QgsDiagramRendererV2
public:
QgsLinearlyInterpolatedDiagramRenderer();
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2011-03-15 17:38:26 UTC (rev 15504)
@@ -74,7 +74,7 @@
//! @note: this method was added in version 1.6
virtual int prepareLayer( QgsVectorLayer* layer, QSet<int>& attrIndices, QgsRenderContext& ctx ) = 0;
//! adds a diagram layer to the labeling engine
- virtual int addDiagramLayer( QgsVectorLayer* layer, QgsDiagramLayerSettings& s ) {};
+ virtual int addDiagramLayer( QgsVectorLayer* layer, QgsDiagramLayerSettings& s ) { return 0; };
//! called for every feature
virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat, const QgsRenderContext& context = QgsRenderContext() ) = 0;
//! called for every diagram feature
Modified: trunk/qgis/src/core/qgspallabeling.cpp
--- trunk/qgis/src/core/qgspallabeling.cpp 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/core/qgspallabeling.cpp 2011-03-15 17:38:26 UTC (rev 15504)
@@ -760,7 +760,7 @@
s.palLayer = l;
if ( mMapRenderer->hasCrsTransformEnabled() )
- s.ct = new QgsCoordinateTransform( layer->srs(), mMapRenderer->destinationSrs() );
+ s.ct = new QgsCoordinateTransform( layer->crs(), mMapRenderer->destinationCrs() );
else
s.ct = NULL;
s.xform = mMapRenderer->coordinateTransform();
Modified: trunk/qgis/src/mapserver/qgsfilter.cpp
--- trunk/qgis/src/mapserver/qgsfilter.cpp 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/mapserver/qgsfilter.cpp 2011-03-15 17:38:26 UTC (rev 15504)
@@ -22,6 +22,7 @@
#include "qgsvectordataprovider.h"
#include <QDomElement>
#include <QStringList>
+#include "qgsvectorlayer.h"
QgsFilter::QgsFilter(): mPropertyIndex( -1 )
Modified: trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt
--- trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/plugins/dxf2shp_converter/CMakeLists.txt 2011-03-15 17:38:26 UTC (rev 15504)
@@ -39,6 +39,7 @@
../../core/symbology
../../gui
+ ${GEOS_INCLUDE_DIR}
TARGET_LINK_LIBRARIES(dxf2shpconverterplugin
Modified: trunk/qgis/src/plugins/sqlanywhere/CMakeLists.txt
--- trunk/qgis/src/plugins/sqlanywhere/CMakeLists.txt 2011-03-15 16:43:23 UTC (rev 15503)
+++ trunk/qgis/src/plugins/sqlanywhere/CMakeLists.txt 2011-03-15 17:38:26 UTC (rev 15504)
@@ -59,6 +59,7 @@
../../app
../../providers/sqlanywhere/sqlanyconnection
TARGET_LINK_LIBRARIES(sqlanywhereplugin
