[QGIS Commit] r15514 - trunk/qgis/src/providers/gdal
svn_qgis at osgeo.org
Wed Mar 16 04:24:08 EDT 2011
Author: rblazek
Date: 2011-03-16 01:24:08 -0700 (Wed, 16 Mar 2011)
New Revision: 15514
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
better resampling alignment
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-16 08:00:22 UTC (rev 15513)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-16 08:24:08 UTC (rev 15514)
@@ -348,13 +348,13 @@
void *hCRS = OSRNewSpatialReference( NULL );
- if ( OSRImportFromWkt( hCRS, (char **) &wkt ) == OGRERR_NONE )
+ if ( OSRImportFromWkt( hCRS, ( char ** ) &wkt ) == OGRERR_NONE )
if ( OSRAutoIdentifyEPSG( hCRS ) == OGRERR_NONE )
QString authid = QString( "%1:%2" )
- .arg( OSRGetAuthorityName( hCRS, NULL ) )
- .arg( OSRGetAuthorityCode( hCRS, NULL ) );
+ .arg( OSRGetAuthorityName( hCRS, NULL ) )
+ .arg( OSRGetAuthorityCode( hCRS, NULL ) );
QgsDebugMsg( "authid recognized as " + authid );
mCrs.createFromOgcWmsCrs( authid );
@@ -570,14 +570,25 @@
QgsDebugMsg( QString( "transform : %1" ).arg( mGeoTransform[i] ) );
- // TODO: fill block with no data values
+ int dataSize = dataTypeSize( theBandNo ) / 8;
+ // fill with null values
+ QByteArray ba = noValueBytes( theBandNo );
+ char *nodata = ba.data();
+ char *block = ( char * ) theBlock;
+ for ( int i = 0; i < thePixelWidth * thePixelHeight; i++ )
+ memcpy( block, nodata, dataSize );
+ block += dataSize;
QgsRectangle myRasterExtent = theExtent.intersect( &mExtent );
if ( myRasterExtent.isEmpty() )
QgsDebugMsg( "draw request outside view extent." );
return;
+ QgsDebugMsg( "mExtent: " + mExtent.toString() );
QgsDebugMsg( "myRasterExtent: " + myRasterExtent.toString() );
double xRes = theExtent.width() / thePixelWidth;
@@ -614,167 +625,243 @@
// Calculate rows/cols limits in raster grid space
- // IMHO, we cannot align target grid to raster grid using target grid edges
- // and finding the nearest raster grid because it could lead to cell center
- // getting outside the right cell when doing resampling, example
- // Raster width is 30m and it has 3 columns and we want to read xrange 5.1-30
- // to 3 columns, the nearest edge for beginning in raster grid is 10.0
- // reading cols 1-2, we get raster[1] value in target[0], but the center of
- // target[0] is 5.1 + ((30-5.1)/3)/2 = 9.25 so it falls to raster[0]. Is it right?
- // => We are looking for such alignment with which the center of first/last cell
- // alls to the right raster cell
+ // Set readable names
+ double srcXRes = mGeoTransform[1];
+ double srcYRes = mGeoTransform[5]; // may be negative?
+ QgsDebugMsg( QString( "xRes = %1 yRes = %2 srcXRes = %3 srcYRes = %4" ).arg( xRes ).arg( yRes ).arg( srcXRes ).arg( srcYRes ) );
double center, centerRaster;
- int rasterTop, rasterBottom, rasterLeft, rasterRight;
+ // target size in pizels
+ int width = right - left + 1;
+ int height = bottom - top + 1;
+ int srcWidth, srcHeight; // source size in pixels
+ int srcLeft = 0; // source raster x offset
+ int srcTop = 0; // source raster x offset
+ int srcBottom = ySize() - 1;
+ int srcRight = xSize() - 1;
// We have to extend destination grid for GDALRasterIO to keep resolution:
- double topSpace, bottomSpace, leftSpace, rightSpace;
+ double topSpace = 0;
+ double bottomSpace = 0;
+ double leftSpace = 0;
+ double rightSpace = 0;
- // top
- center = myRasterExtent.yMaximum() - yRes / 2;
- // center in raster space
- // GDAL states that mGeoTransform[3] is top, but probably it can be also bottom
- // if mGeoTransform[5] is negative ??? No, mGeoTransform[5] is negative normaly
- // - vice versa?
- //if ( mGeoTransform[5] > 0 )
- if ( mGeoTransform[5] < 0 )
+ // It is easier to think separately about 3 cases for each axe: xRes = srcXRes, xRes > srcXRes, xRes < srcXRes, yRes = srcYRes, yRes > srcYRes, yRes < srcYRes
+ // Some expressions may be duplicated but it is better for keeping clear ideas
+ // *** CASE 1: xRes = srcXRes, yRes = srcYRes
+ // This is not that rare because of 'Zoom to best resolution' tool
+ // We just need to align the first cell
+ if ( xRes == srcXRes )
- centerRaster = -1. * ( mGeoTransform[3] - center ) / mGeoTransform[5];
+ if ( mExtent.xMinimum() < myRasterExtent.xMinimum() ) // raster runs outside to left, calc offset
+ srcLeft = qRound(( myRasterExtent.xMinimum() - mExtent.xMinimum() ) / srcXRes );
+ if ( mExtent.xMaximum() > myRasterExtent.xMaximum() )
+ srcRight = qRound(( myRasterExtent.xMaximum() - mExtent.xMinimum() ) / srcXRes ) - 1 ;
- else
+ if ( yRes == qAbs( srcYRes ) )
- centerRaster = ( center - mGeoTransform[3] ) / mGeoTransform[5];
+ // GDAL states that mGeoTransform[3] is top, may it also be bottom and mGeoTransform[5] positive?
+ if ( mExtent.yMaximum() > myRasterExtent.yMaximum() ) // raster runs outside up, calc offset
+ //QgsDebugMsg( QString( "mExtent.yMaximum() - myRasterExtent.yMaximum() = %1 ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes = %2 srcTop = %3" ).arg( mExtent.yMaximum() - myRasterExtent.yMaximum() ).arg( ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes ).arg( srcTop ) );
+ srcTop = qRound( -1. * ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes );
+ if ( mExtent.yMinimum() < myRasterExtent.yMinimum() )
+ srcBottom = qRound( -1. * ( mExtent.yMaximum() - myRasterExtent.yMinimum() ) / srcYRes ) - 1 ;
- rasterTop = static_cast<int>( floor( centerRaster ) );
- topSpace = ( mGeoTransform[3] + rasterTop * mGeoTransform[5] ) - myRasterExtent.yMaximum();
- // bottom
- center = myRasterExtent.yMinimum() + yRes / 2;
+ // *** CASE 2: xRes > srcXRes, yRes > srcYRes
+ // If the edge of the source is greater than the edge of destination:
+ // src: | | | | | | | | |
+ // dst: | | | |
+ // We have 2 options for resampling:
+ // a) 'Stretch' the src and align the start edge of src to the start edge of dst.
+ // That means however, that to the target cells may be assigned values of source
+ // which are not nearest to the center of dst cells. Usualy probably not a problem
+ // but we are not precise. The shift is in maximum ... TODO
+ // b) We could cut the first destination column and left only the second one which is
+ // completely covered by src. No (significant) stretching is applied in that
+ // case, but the first column may be rendered as without values event if its center
+ // is covered by src column. That could result in wrongly rendered (missing) edges
+ // which could be easily noticed by user
+ // Conclusion: Both are incorrect, but the b) is probably worse because it can be easily
+ // noticed. Missing data are worse than slightly shifted nearest src cells.
+ if ( xRes > srcXRes )
- else
+ if ( yRes > qAbs( srcYRes ) )
- rasterBottom = static_cast<int>( floor( centerRaster ) );
- bottomSpace = myRasterExtent.yMinimum() - ( mGeoTransform[3] + ( rasterBottom + 1 ) * mGeoTransform[5] );
- // left
- center = myRasterExtent.xMinimum() + xRes / 2;
- centerRaster = ( center - mGeoTransform[0] ) / mGeoTransform[1];
- rasterLeft = static_cast<int>( floor( centerRaster ) );
- leftSpace = myRasterExtent.xMinimum() - ( mGeoTransform[0] + rasterLeft * mGeoTransform[1] );
+ // *** CASE 3: xRes < srcXRes, yRes < srcYRes
+ // IMHO, we cannot align target grid to raster grid using target grid edges
+ // and finding the nearest raster grid because it could lead to cell center
+ // getting outside the right cell when doing resampling, example
+ // src: | | | |
+ // dst: | | | |
+ // Raster width is 30m and it has 3 columns and we want to read xrange 5.1-30
+ // to 3 columns, the nearest edge for beginning in raster grid is 10.0
+ // reading cols 1-2, we get raster[1] value in target[0], but the center of
+ // target[0] is 5.1 + ((30-5.1)/3)/2 = 9.25 so it falls to raster[0]. Is it right?
+ // => We are looking for such alignment with which the center of first/last cell
+ // falls to the right raster cell
+ int xAddPixels = 0;
+ int leftAddPixels = 0;
+ if ( xRes < srcXRes )
+ center = myRasterExtent.xMinimum() + xRes / 2;
+ centerRaster = ( center - mExtent.xMinimum() ) / srcXRes;
+ srcLeft = static_cast<int>( floor( centerRaster ) );
- // right
- center = myRasterExtent.xMaximum() - xRes / 2;
- rasterRight = static_cast<int>( floor( centerRaster ) );
- rightSpace = ( mGeoTransform[0] + ( rasterRight + 1 ) * mGeoTransform[1] ) - myRasterExtent.xMaximum();
+ // Space which has to be added to destination to fit better source
+ // Warning - TODO: if xRes is much smaller than srcXRes, adding space and pixels to dst may
+ // result in very large dst grids!!! E.g.
+ // src: | | |
+ // dst: | | |
+ // Solution could be vector rendering of rectangles.
- QgsDebugMsg( QString( "rasterTop = %1 rasterBottom = %2 rasterLeft = %3 rasterRight = %4" ).arg( rasterTop ).arg( rasterBottom ).arg( rasterLeft ).arg( rasterRight ) );
+ leftSpace = myRasterExtent.xMinimum() - ( mExtent.xMinimum() + srcLeft * srcXRes );
+ leftSpace = leftSpace > 0 ? leftSpace : 0; // makes only sense for positive
+ center = myRasterExtent.xMaximum() - xRes / 2;
+ srcRight = static_cast<int>( floor( centerRaster ) );
- QgsDebugMsg( QString( "topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4" ).arg( topSpace ).arg( bottomSpace ).arg( leftSpace ).arg( rightSpace ) );
+ rightSpace = ( mExtent.xMinimum() + ( srcRight + 1 ) * srcXRes ) - myRasterExtent.xMaximum();
+ rightSpace = rightSpace > 0 ? rightSpace : 0;
+ QgsDebugMsg( QString( "center = %1 centerRaster = %2 srcRight = %3 rightSpace = %4" ).arg( center ).arg( centerRaster ).arg( srcRight ).arg( rightSpace ) );
- int width = right - left + 1;
- int height = bottom - top + 1;
+ double xAdd = leftSpace + rightSpace;
+ xAddPixels = qRound( xAdd / xRes );
+ leftAddPixels = qRound( leftSpace / xRes );
- int rasterWidth = rasterRight - rasterLeft + 1;
- int rasterHeight = rasterBottom - rasterTop + 1;
+ int yAddPixels = 0;
+ int topAddPixels = 0;
+ if ( yRes < qAbs( srcYRes ) )
+ center = myRasterExtent.yMaximum() - yRes / 2;
+ centerRaster = -1. * ( mExtent.yMaximum() - center ) / srcYRes;
+ srcTop = static_cast<int>( floor( centerRaster ) );
+ topSpace = ( mExtent.yMaximum() + srcTop * srcYRes ) - myRasterExtent.yMaximum();
+ topSpace = topSpace > 0 ? topSpace : 0;
+ center = myRasterExtent.yMinimum() + yRes / 2;
- QgsDebugMsg( QString( "width = %1 height = %2 rasterWidth = %3 rasterHeight = %4" ).arg( width ).arg( height ).arg( rasterWidth ).arg( rasterHeight ) );
+ srcBottom = static_cast<int>( floor( centerRaster ) );
+ QgsDebugMsg( QString( "myRasterExtent.yMinimum() = %1 myRasterExtent.yMaximum() = %2" ).arg( myRasterExtent.yMinimum() ).arg( myRasterExtent.yMaximum() ) );
+ bottomSpace = myRasterExtent.yMinimum() - ( mExtent.yMaximum() + ( srcBottom + 1 ) * srcYRes );
+ bottomSpace = bottomSpace > 0 ? bottomSpace : 0;
+ QgsDebugMsg( QString( "center = %1 centerRaster = %2 srcBottom = %3 bottomSpace = %4" ).arg( center ).arg( centerRaster ).arg( srcBottom ).arg( bottomSpace ) );
- // TODO: what is better floor/ceil, can be negative?
- // should be similar
- //double xAdd = rasterWidth*rasterXRes - width*xRes;
- double xAdd = leftSpace + rightSpace;
- int xAddPixels = qRound( xAdd / xRes );
- int leftAddPixels = qRound( leftSpace / xRes );
+ double yAdd = topSpace + bottomSpace;
+ yAddPixels = qRound( yAdd / yRes );
+ topAddPixels = qRound( topSpace / yRes );
- //double leftAdd = rasterWidth*rasterXRes - width*xRes;
- double yAdd = topSpace + bottomSpace;
- int yAddPixels = qRound( yAdd / yRes );
- int topAddPixels = qRound( topSpace / yRes );
+ srcWidth = srcRight - srcLeft + 1;
+ srcHeight = srcBottom - srcTop + 1;
+ QgsDebugMsg( QString( "srcTop = %1 srcBottom = %2 srcLeft = %3 srcRight = %4" ).arg( srcTop ).arg( srcBottom ).arg( srcLeft ).arg( srcRight ) );
+ QgsDebugMsg( QString( "topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4" ).arg( topSpace ).arg( bottomSpace ).arg( leftSpace ).arg( rightSpace ) );
+ QgsDebugMsg( QString( "width = %1 height = %2 srcWidth = %3 srcHeight = %4" ).arg( width ).arg( height ).arg( srcWidth ).arg( srcHeight ) );
QgsDebugMsg( QString( "xAddPixels = %1 yAddPixels = %2 leftAddPixels = %3 topAddPixels = %4" ).arg( xAddPixels ).arg( yAddPixels ).arg( leftAddPixels ).arg( topAddPixels ) );
- // Currently only positive allowed, verify if negative has sense and check following use
- xAddPixels = xAddPixels > 0 ? xAddPixels : 0;
- yAddPixels = yAddPixels > 0 ? yAddPixels : 0;
- leftAddPixels = leftAddPixels > 0 ? leftAddPixels : 0;
- topAddPixels = topAddPixels > 0 ? topAddPixels : 0;
int totalWidth = width + xAddPixels;
int totalHeight = height + yAddPixels;
QgsDebugMsg( QString( "totalWidth = %1 totalHeight = %2" ).arg( totalWidth ).arg( totalHeight ) );
- int size = dataTypeSize( theBandNo ) / 8;
- // fill with null values
- QByteArray ba = noValueBytes( theBandNo );
- char *nodata = ba.data();
- char *block = ( char * ) theBlock;
- for ( int i = 0; i < thePixelWidth * thePixelHeight; i++ )
- memcpy( block, nodata, size );
- block += size;
GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
GDALDataType type = ( GDALDataType )mGdalDataType[theBandNo-1];
CPLErrorReset();
-// This can be probably used if xAddPixels and yAddPixels are 0 to avoid memcpy
-#if 0
- // Calc beginnig of data if raster does not start at top
- block = ( char * ) theBlock;
- if ( top != 0 )
+ if ( xAddPixels == 0 && yAddPixels == 0 )
- block += size * thePixelWidth * top;
+ // Calc beginnig of data if raster does not start at top
+ block = ( char * ) theBlock;
+ if ( top != 0 )
+ block += dataSize * thePixelWidth * top;
+ // Cal nLineSpace if raster does not cover whole extent
+ int nLineSpace = dataSize * thePixelWidth;
+ if ( left != 0 )
+ block += dataSize * left;
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read,
+ srcLeft, srcTop, srcWidth, srcHeight,
+ ( void * )block,
+ width, height, type,
+ 0, nLineSpace );
- // Cal nLineSpace if raster does not cover whole extent
- int nLineSpace = size * thePixelWidth;
- if ( left != 0 )
+ else
- block += size * left;
- CPLErr err = GDALRasterIO( gdalBand, GF_Read,
- rasterLeft, rasterTop, rasterWidth, rasterHeight,
- ( void * )block,
- width, height, type,
- 0, nLineSpace );
-#endif
+ // Allocate temporary block
+ void *tmpBlock = malloc( dataSize * totalWidth * totalHeight );
- // Allocate temporary block
- void *tmpBlock = malloc( size * totalWidth * totalHeight );
+ CPLErrorReset();
+ ( void * )tmpBlock,
+ totalWidth, totalHeight, type,
+ 0, 0 );
- CPLErrorReset();
- ( void * )tmpBlock,
- totalWidth, totalHeight, type,
- 0, 0 );
+ if ( err != CPLE_None )
+ QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ QgsDebugMsg( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ free( tmpBlock );
+ return;
- if ( err != CPLE_None )
- QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
- QgsDebugMsg( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ for ( int i = 0; i < height; i++ )
+ int r = i + topAddPixels;
+ char *src = ( char * )tmpBlock + dataSize * r * totalWidth + dataSize * leftAddPixels;
+ char *dst = ( char * )theBlock + dataSize * ( top + i ) * thePixelWidth + dataSize * ( left );
+ memcpy( dst, src, dataSize*width );
free( tmpBlock );
- return;
- for ( int i = 0; i < height; i++ )
- int r = i + topAddPixels;
- char *src = ( char * )tmpBlock + size * r * totalWidth + size * leftAddPixels;
- char *dst = ( char * )theBlock + size * ( top + i ) * thePixelWidth + size * ( left );
- memcpy( dst, src, size*width );
- free( tmpBlock );
return;
