[QGIS Commit] r15530 - trunk/qgis/src/providers/gdal
svn_qgis at osgeo.org
Thu Mar 17 17:42:27 EDT 2011
Author: rblazek
Date: 2011-03-17 14:42:27 -0700 (Thu, 17 Mar 2011)
New Revision: 15530
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
throw away all the tricks and do second resampling, it is quite fast
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-17 16:13:50 UTC (rev 15529)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-17 21:42:27 UTC (rev 15530)
@@ -38,6 +38,7 @@
#include <QFileInfo>
#include <QFile>
#include <QHash>
+#include <QTime>
#include "gdalwarper.h"
#include "ogr_spatialref.h"
@@ -630,58 +631,26 @@
double srcYRes = mGeoTransform[5]; // may be negative?
QgsDebugMsg( QString( "xRes = %1 yRes = %2 srcXRes = %3 srcYRes = %4" ).arg( xRes ).arg( yRes ).arg( srcXRes ).arg( srcYRes ) );
- double center, centerRaster;
// target size in pizels
int width = right - left + 1;
int height = bottom - top + 1;
- int srcWidth, srcHeight; // source size in pixels
int srcLeft = 0; // source raster x offset
int srcTop = 0; // source raster x offset
int srcBottom = ySize() - 1;
int srcRight = xSize() - 1;
- // We have to extend destination grid for GDALRasterIO to keep resolution:
- double topSpace = 0;
- double bottomSpace = 0;
- double leftSpace = 0;
- double rightSpace = 0;
+ QTime time;
+ time.start();
+ // Note: original approach for xRes < srcXRes || yRes < qAbs( srcYRes ) was to avoid
+ // second resampling and read with GDALRasterIO to another temporary data block
+ // extended to fit src grid. The problem was that with src resolution much bigger
+ // than dst res, the target could become very large
+ // in theory it was going to infinity when zooming in ...
- // It is easier to think separately about 3 cases for each axe: xRes = srcXRes, xRes > srcXRes, xRes < srcXRes, yRes = srcYRes, yRes > srcYRes, yRes < srcYRes
- // Some expressions may be duplicated but it is better for keeping clear ideas
- // *** CASE 1: xRes = srcXRes, yRes = srcYRes
- // This is not that rare because of 'Zoom to best resolution' tool
- // We just need to align the first cell
- if ( xRes == srcXRes )
- if ( mExtent.xMinimum() < myRasterExtent.xMinimum() ) // raster runs outside to left, calc offset
- srcLeft = qRound(( myRasterExtent.xMinimum() - mExtent.xMinimum() ) / srcXRes );
- if ( mExtent.xMaximum() > myRasterExtent.xMaximum() )
- srcRight = qRound(( myRasterExtent.xMaximum() - mExtent.xMinimum() ) / srcXRes ) - 1 ;
- if ( yRes == qAbs( srcYRes ) )
- // GDAL states that mGeoTransform[3] is top, may it also be bottom and mGeoTransform[5] positive?
- if ( mExtent.yMaximum() > myRasterExtent.yMaximum() ) // raster runs outside up, calc offset
- //QgsDebugMsg( QString( "mExtent.yMaximum() - myRasterExtent.yMaximum() = %1 ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes = %2 srcTop = %3" ).arg( mExtent.yMaximum() - myRasterExtent.yMaximum() ).arg( ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes ).arg( srcTop ) );
- srcTop = qRound( -1. * ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes );
- if ( mExtent.yMinimum() < myRasterExtent.yMinimum() )
- srcBottom = qRound( -1. * ( mExtent.yMaximum() - myRasterExtent.yMinimum() ) / srcYRes ) - 1 ;
- // *** CASE 2: xRes > srcXRes, yRes > srcYRes
+ // Note: original approach for xRes > srcXRes, yRes > srcYRes was to read directly with GDALRasterIO
+ // but we would face this problem:
// If the edge of the source is greater than the edge of destination:
// src: | | | | | | | | |
// dst: | | | |
@@ -695,173 +664,97 @@
// case, but the first column may be rendered as without values event if its center
// is covered by src column. That could result in wrongly rendered (missing) edges
// which could be easily noticed by user
- // Conclusion: Both are incorrect, but the b) is probably worse because it can be easily
- // noticed. Missing data are worse than slightly shifted nearest src cells.
- if ( xRes > srcXRes )
+ // Because of problems mentioned above we read to another temporary block and do i
+ // another resampling here which appeares to be quite fast
+ // Get necessary src extent aligned to src resolution
+ if ( mExtent.xMinimum() < myRasterExtent.xMinimum() )
+ srcLeft = static_cast<int>( floor(( myRasterExtent.xMinimum() - mExtent.xMinimum() ) / srcXRes ) );
- if ( yRes > qAbs( srcYRes ) )
+ if ( mExtent.xMaximum() > myRasterExtent.xMaximum() )
+ srcRight = static_cast<int>( floor(( myRasterExtent.xMaximum() - mExtent.xMinimum() ) / srcXRes ) );
- // *** CASE 3: xRes < srcXRes, yRes < srcYRes
- // IMHO, we cannot align target grid to raster grid using target grid edges
- // and finding the nearest raster grid because it could lead to cell center
- // getting outside the right cell when doing resampling, example
- // src: | | | |
- // dst: | | | |
- // Raster width is 30m and it has 3 columns and we want to read xrange 5.1-30
- // to 3 columns, the nearest edge for beginning in raster grid is 10.0
- // reading cols 1-2, we get raster[1] value in target[0], but the center of
- // target[0] is 5.1 + ((30-5.1)/3)/2 = 9.25 so it falls to raster[0]. Is it right?
- // => We are looking for such alignment with which the center of first/last cell
- // falls to the right raster cell
- int xAddPixels = 0;
- int leftAddPixels = 0;
- if ( xRes < srcXRes )
+ // GDAL states that mGeoTransform[3] is top, may it also be bottom and mGeoTransform[5] positive?
+ if ( mExtent.yMaximum() > myRasterExtent.yMaximum() )
- center = myRasterExtent.xMinimum() + xRes / 2;
- centerRaster = ( center - mExtent.xMinimum() ) / srcXRes;
- srcLeft = static_cast<int>( floor( centerRaster ) );
- // Space which has to be added to destination to fit better source
- // Warning - TODO: if xRes is much smaller than srcXRes, adding space and pixels to dst may
- // result in very large dst grids!!! E.g.
- // src: | | |
- // dst: | | |
- // Solution could be vector rendering of rectangles.
- leftSpace = myRasterExtent.xMinimum() - ( mExtent.xMinimum() + srcLeft * srcXRes );
- leftSpace = leftSpace > 0 ? leftSpace : 0; // makes only sense for positive
- center = myRasterExtent.xMaximum() - xRes / 2;
- srcRight = static_cast<int>( floor( centerRaster ) );
- rightSpace = ( mExtent.xMinimum() + ( srcRight + 1 ) * srcXRes ) - myRasterExtent.xMaximum();
- rightSpace = rightSpace > 0 ? rightSpace : 0;
- QgsDebugMsg( QString( "center = %1 centerRaster = %2 srcRight = %3 rightSpace = %4" ).arg( center ).arg( centerRaster ).arg( srcRight ).arg( rightSpace ) );
- double xAdd = leftSpace + rightSpace;
- xAddPixels = qRound( xAdd / xRes );
- leftAddPixels = qRound( leftSpace / xRes );
+ srcTop = static_cast<int>( floor( -1. * ( mExtent.yMaximum() - myRasterExtent.yMaximum() ) / srcYRes ) );
- int yAddPixels = 0;
- int topAddPixels = 0;
- if ( yRes < qAbs( srcYRes ) )
+ if ( mExtent.yMinimum() < myRasterExtent.yMinimum() )
- center = myRasterExtent.yMaximum() - yRes / 2;
- centerRaster = -1. * ( mExtent.yMaximum() - center ) / srcYRes;
- srcTop = static_cast<int>( floor( centerRaster ) );
- topSpace = ( mExtent.yMaximum() + srcTop * srcYRes ) - myRasterExtent.yMaximum();
- topSpace = topSpace > 0 ? topSpace : 0;
- center = myRasterExtent.yMinimum() + yRes / 2;
- srcBottom = static_cast<int>( floor( centerRaster ) );
- QgsDebugMsg( QString( "myRasterExtent.yMinimum() = %1 myRasterExtent.yMaximum() = %2" ).arg( myRasterExtent.yMinimum() ).arg( myRasterExtent.yMaximum() ) );
- bottomSpace = myRasterExtent.yMinimum() - ( mExtent.yMaximum() + ( srcBottom + 1 ) * srcYRes );
- bottomSpace = bottomSpace > 0 ? bottomSpace : 0;
- QgsDebugMsg( QString( "center = %1 centerRaster = %2 srcBottom = %3 bottomSpace = %4" ).arg( center ).arg( centerRaster ).arg( srcBottom ).arg( bottomSpace ) );
- double yAdd = topSpace + bottomSpace;
- yAddPixels = qRound( yAdd / yRes );
- topAddPixels = qRound( topSpace / yRes );
+ srcBottom = static_cast<int>( floor( -1. * ( mExtent.yMaximum() - myRasterExtent.yMinimum() ) / srcYRes ) );
- srcWidth = srcRight - srcLeft + 1;
- srcHeight = srcBottom - srcTop + 1;
QgsDebugMsg( QString( "srcTop = %1 srcBottom = %2 srcLeft = %3 srcRight = %4" ).arg( srcTop ).arg( srcBottom ).arg( srcLeft ).arg( srcRight ) );
- QgsDebugMsg( QString( "topSpace = %1 bottomSpace = %2 leftSpace = %3 rightSpace = %4" ).arg( topSpace ).arg( bottomSpace ).arg( leftSpace ).arg( rightSpace ) );
+ int srcWidth = srcRight - srcLeft + 1;
+ int srcHeight = srcBottom - srcTop + 1;
QgsDebugMsg( QString( "width = %1 height = %2 srcWidth = %3 srcHeight = %4" ).arg( width ).arg( height ).arg( srcWidth ).arg( srcHeight ) );
+ int tmpWidth = srcWidth;
+ int tmpHeight = srcHeight;
- QgsDebugMsg( QString( "xAddPixels = %1 yAddPixels = %2 leftAddPixels = %3 topAddPixels = %4" ).arg( xAddPixels ).arg( yAddPixels ).arg( leftAddPixels ).arg( topAddPixels ) );
+ if ( xRes > srcXRes ) tmpWidth = width;
+ if ( yRes > srcYRes ) tmpHeight = height;
- int totalWidth = width + xAddPixels;
- int totalHeight = height + yAddPixels;
+ // Allocate temporary block
+ char *tmpBlock = ( char * )malloc( dataSize * tmpWidth * tmpHeight );
- QgsDebugMsg( QString( "totalWidth = %1 totalHeight = %2" ).arg( totalWidth ).arg( totalHeight ) );
GDALRasterBandH gdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
GDALDataType type = ( GDALDataType )mGdalDataType[theBandNo-1];
CPLErrorReset();
+ CPLErr err = GDALRasterIO( gdalBand, GF_Read,
+ srcLeft, srcTop, srcWidth, srcHeight,
+ ( void * )tmpBlock,
+ tmpWidth, tmpHeight, type,
+ 0, 0 );
- if ( xAddPixels == 0 && yAddPixels == 0 )
+ if ( err != CPLE_None )
- // Calc beginnig of data if raster does not start at top
- block = ( char * ) theBlock;
- if ( top != 0 )
- block += dataSize * thePixelWidth * top;
- // Cal nLineSpace if raster does not cover whole extent
- int nLineSpace = dataSize * thePixelWidth;
- if ( left != 0 )
- block += dataSize * left;
- CPLErr err = GDALRasterIO( gdalBand, GF_Read,
- srcLeft, srcTop, srcWidth, srcHeight,
- ( void * )block,
- width, height, type,
- 0, nLineSpace );
+ QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ QgsDebugMsg( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
+ free( tmpBlock );
+ return;
- else
- // Allocate temporary block
- void *tmpBlock = malloc( dataSize * totalWidth * totalHeight );
- CPLErrorReset();
- ( void * )tmpBlock,
- totalWidth, totalHeight, type,
- 0, 0 );
+ QgsDebugMsg( QString( "GDALRasterIO time (ms): %1" ).arg( time.elapsed() ) );
+ time.start();
- if ( err != CPLE_None )
- QgsLogger::warning( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
- QgsDebugMsg( "RasterIO error: " + QString::fromUtf8( CPLGetLastErrorMsg() ) );
- free( tmpBlock );
- return;
+ double tmpXMin = mExtent.xMinimum() + srcLeft * srcXRes;
+ double tmpYMax = mExtent.yMaximum() + srcTop * srcYRes;
+ double tmpXRes = srcWidth * srcXRes / tmpWidth;
+ double tmpYRes = srcHeight * srcYRes / tmpHeight; // negative
- for ( int i = 0; i < height; i++ )
+ QgsDebugMsg( QString( "tmpXMin = %1 tmpYMax = %2 tmpWidth = %3 tmpHeight = %4" ).arg( tmpXMin ).arg( tmpYMax ).arg( tmpWidth ).arg( tmpHeight ) );
+ for ( int row = 0; row < height; row++ )
+ double y = myRasterExtent.yMaximum() - ( row + 0.5 ) * yRes;
+ int tmpRow = static_cast<int>( floor( -1. * ( tmpYMax - y ) / tmpYRes ) );
+ char *srcRowBlock = tmpBlock + dataSize * tmpRow * tmpWidth;
+ char *dstRowBlock = ( char * )theBlock + dataSize * ( top + row ) * thePixelWidth;
+ for ( int col = 0; col < width; col++ )
- int r = i + topAddPixels;
- char *src = ( char * )tmpBlock + dataSize * r * totalWidth + dataSize * leftAddPixels;
- char *dst = ( char * )theBlock + dataSize * ( top + i ) * thePixelWidth + dataSize * ( left );
- memcpy( dst, src, dataSize*width );
+ // cell center
+ double x = myRasterExtent.xMinimum() + ( col + 0.5 ) * xRes;
+ // floor() is quite slow! Use just cast to int.
+ int tmpCol = static_cast<int>(( x - tmpXMin ) / tmpXRes ) ;
+ //QgsDebugMsg( QString( "row = %1 col = %2 tmpRow = %3 tmpCol = %4" ).arg(row).arg(col).arg(tmpRow).arg(tmpCol) );
- free( tmpBlock );
+ char *src = srcRowBlock + dataSize * tmpCol;
+ char *dst = dstRowBlock + dataSize * ( left + col );
+ memcpy( dst, src, dataSize );
+ free( tmpBlock );
+ QgsDebugMsg( QString( "resample time (ms): %1" ).arg( time.elapsed() ) );
return;
