[QGIS Commit] r15538 - in trunk/qgis/src: core core/raster
providers/gdal
svn_qgis at osgeo.org
Sat Mar 19 13:40:19 EDT 2011
Author: rblazek
Date: 2011-03-19 10:40:19 -0700 (Sat, 19 Mar 2011)
New Revision: 15538
trunk/qgis/src/core/qgsrasterdataprovider.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
trunk/qgis/src/providers/gdal/qgsgdalprovider.h
progress signals
Modified: trunk/qgis/src/core/qgsrasterdataprovider.h
--- trunk/qgis/src/core/qgsrasterdataprovider.h 2011-03-19 13:26:00 UTC (rev 15537)
+++ trunk/qgis/src/core/qgsrasterdataprovider.h 2011-03-19 17:40:19 UTC (rev 15538)
@@ -107,6 +107,13 @@
/*! Max current value */ ColorInterpretationMax = 16
+ // Progress types
+ enum Progress
+ ProgressHistogram = 0,
+ ProgressPyramids = 1
QgsRasterDataProvider();
QgsRasterDataProvider( QString const & uri );
@@ -460,6 +467,11 @@
/** \brief Set null value in char */
QByteArray noValueBytes( int theBandNo );
+ signals:
+ /** Emit a signal to notify of the progress event.
+ * Emited theProgress is in percents (0.0-100.0) */
+ void progress( int theType, double theProgress, QString theMessage );
protected:
/**Dots per intch. Extended WMS (e.g. QGIS mapserver) support DPI dependent output and therefore
are suited for printing. A value of -1 means it has not been set
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-03-19 13:26:00 UTC (rev 15537)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-03-19 17:40:19 UTC (rev 15538)
@@ -2483,6 +2483,12 @@
mRasterTransparency.initializeTransparentPixelList( mNoDataValue );
+ // Connect provider signals
+ connect(
+ mDataProvider, SIGNAL( progress( int, double, QString ) ),
+ this, SLOT( onProgress( int, double, QString ) )
//mark the layer as valid
mValid = true;
@@ -2945,6 +2951,12 @@
emit drawingProgress( theProgress, theMax );
+void QgsRasterLayer::onProgress( int theType, double theProgress, QString theMesssage )
+ QgsDebugMsg( QString( "theProgress = %1" ).arg( theProgress ) );
+ emit progressUpdate(( int )theProgress );
// Protected methods
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2011-03-19 13:26:00 UTC (rev 15537)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2011-03-19 17:40:19 UTC (rev 15538)
@@ -674,6 +674,9 @@
/** \brief Propagate progress updates from GDAL up to the parent app */
void updateProgress( int, int );
+ /** \brief recieve progress signal from provider */
+ void onProgress( int, double, QString );
signals:
/** \brief Signal for notifying listeners of long running processes */
void progressUpdate( int theValue );
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-19 13:26:00 UTC (rev 15537)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp 2011-03-19 17:40:19 UTC (rev 15538)
@@ -55,6 +55,11 @@
static QString PROVIDER_KEY = "gdal";
static QString PROVIDER_DESCRIPTION = "GDAL provider";
+struct QgsGdalProgress
+ int type;
+ QgsGdalProvider *provider;
// global callback function
@@ -62,9 +67,11 @@
const char * pszMessage,
void * pProgressArg )
- // TODO: add signals to providers
static double dfLastComplete = -1.0;
+ QgsGdalProgress *prog = static_cast<QgsGdalProgress *>( pProgressArg );
+ QgsGdalProvider *mypProvider = prog->provider;
if ( dfLastComplete > dfComplete )
if ( dfLastComplete >= 1.0 )
@@ -84,16 +91,18 @@
if ( nPercent == 100 )
- fprintf( stdout, "%d - done.\n", ( int ) floor( dfComplete*100 ) );
+ //fprintf( stdout, "%d - done.\n", ( int ) floor( dfComplete*100 ) );
//mypLayer->showProgress( 100 );
else
int myProgress = ( int ) floor( dfComplete * 100 );
- fprintf( stdout, "%d.", myProgress );
+ //fprintf( stdout, "%d.", myProgress );
//mypLayer->showProgress( myProgress );
- fflush( stdout );
+ //fflush( stdout );
+ mypProvider->emitProgress( prog->type, dfComplete * 100, QString( pszMessage ) );
dfLastComplete = dfComplete;
@@ -547,9 +556,9 @@
// TODO!!!: Check data alignment!!! May it happen that nearest value which
// is not nearest is assigned to an output cell???
- QgsDebugMsg( "Entered" );
+ //QgsDebugMsg( "Entered" );
- QgsDebugMsg( "yBlock = " + QString::number( yBlock ) );
+ //QgsDebugMsg( "yBlock = " + QString::number( yBlock ) );
GDALRasterBandH myGdalBand = GDALGetRasterBand( mGdalDataset, theBandNo );
//GDALReadBlock( myGdalBand, xBlock, yBlock, block );
@@ -1312,11 +1321,15 @@
* void * pProgressData
+ QgsGdalProgress myProg;
+ myProg.type = ProgressHistogram;
+ myProg.provider = this;
double myerval = ( theBandStats.maximumValue - theBandStats.minimumValue ) / theBinCount;
GDALGetRasterHistogram( myGdalBand, theBandStats.minimumValue - 0.1*myerval,
theBandStats.maximumValue + 0.1*myerval, theBinCount, myHistogramArray,
theIgnoreOutOfRangeFlag, theHistogramEstimatedFlag, progressCallback,
- this ); //this is the arg for our custome gdal progress callback
+ &myProg ); //this is the arg for our custome gdal progress callback
for ( int myBin = 0; myBin < theBinCount; myBin++ )
@@ -1443,21 +1456,24 @@
//to create corrupted images. The images can be repaired
//by running one of the other resampling strategies below.
//see ticket #284
+ myProg.type = ProgressPyramids;
if ( theResamplingMethod == tr( "Average Magphase" ) )
myError = GDALBuildOverviews( mGdalBaseDataset, "MODE", 1, myOverviewLevelsArray, 0, NULL,
- progressCallback, this ); //this is the arg for the gdal progress callback
+ progressCallback, &myProg ); //this is the arg for the gdal progress callback
else if ( theResamplingMethod == tr( "Average" ) )
myError = GDALBuildOverviews( mGdalBaseDataset, "AVERAGE", 1, myOverviewLevelsArray, 0, NULL,
else // fall back to nearest neighbor
myError = GDALBuildOverviews( mGdalBaseDataset, "NEAREST", 1, myOverviewLevelsArray, 0, NULL,
if ( myError == CE_Failure || CPLGetLastErrorNo() == CPLE_NotSupported )
@@ -1587,6 +1603,10 @@
return subLayers_( mGdalDataset );
+void QgsGdalProvider::emitProgress( int theType, double theProgress, QString theMessage )
+ emit progress( theType, theProgress, theMessage );
* Class factory to return a pointer to a newly created
Modified: trunk/qgis/src/providers/gdal/qgsgdalprovider.h
--- trunk/qgis/src/providers/gdal/qgsgdalprovider.h 2011-03-19 13:26:00 UTC (rev 15537)
+++ trunk/qgis/src/providers/gdal/qgsgdalprovider.h 2011-03-19 17:40:19 UTC (rev 15538)
@@ -247,6 +247,8 @@
/** \brief Close data set and release related data */
void closeDataset();
+ /** Emit a signal to notify of the progress event. */
+ void emitProgress( int theType, double theProgress, QString theMessage );
private:
// initialize CRS from wkt
