[QGIS Commit] r15547 - in trunk/qgis/src/core: . symbology-ng
svn_qgis at osgeo.org
Mon Mar 21 04:08:43 EDT 2011
Author: mhugent
Date: 2011-03-21 01:08:43 -0700 (Mon, 21 Mar 2011)
New Revision: 15547
trunk/qgis/src/core/qgsclipper.h
trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
Modify polygon clipping to clip close to the drawing rectangle. Should now solve the clipping for print composer too
Modified: trunk/qgis/src/core/qgsclipper.h
--- trunk/qgis/src/core/qgsclipper.h 2011-03-20 22:47:02 UTC (rev 15546)
+++ trunk/qgis/src/core/qgsclipper.h 2011-03-21 08:08:43 UTC (rev 15547)
@@ -79,7 +79,7 @@
std::vector<double>& y,
bool shapeOpen );
- static void trimFeature( QPolygonF& pts, bool shapeOpen );
+ static void trimPolygon( QPolygonF& pts, const QgsRectangle& clipRect );
/**Reads a polyline from WKB and clips it to clipExtent
@param wkb pointer to the start of the line wkb
@@ -101,15 +101,12 @@
Boundary b,
bool shapeOpen );
- static void trimFeatureToBoundary( const QPolygonF& inPts,
- QPolygonF& outPts,
- Boundary b,
- bool shapeOpen );
+ static void trimPolygonToBoundary( const QPolygonF& inPts, QPolygonF& outPts, const QgsRectangle& rect, Boundary b, double boundaryValue );
// Determines if a point is inside or outside the given boundary
static bool inside( const double x, const double y, Boundary b );
- static bool inside( const QPointF& pt, Boundary b );
+ static bool inside( const QPointF& pt, Boundary b, double val );
// Calculates the intersection point between a line defined by a
// (x1, y1), and (x2, y2) and the given boundary
@@ -117,9 +114,9 @@
const double x2, const double y2,
Boundary b );
- static QPointF intersect( const QPointF& pt1,
- const QPointF& pt2,
- Boundary b );
+ static QPointF intersectRect( const QPointF& pt1,
+ const QPointF& pt2,
+ Boundary b, const QgsRectangle& rect );
//Implementation of 'Fast clipping' algorithm (Sobkow et al. 1987, Computers & Graphics Vol.11, 4, p.459-467)
static bool clipLineSegment( double xLeft, double xRight, double yBottom, double yTop, double& x0, double& y0, double& x1, double& y1 );
@@ -179,34 +176,18 @@
trimFeatureToBoundary( tmpX, tmpY, x, y, YMin, shapeOpen );
-inline void QgsClipper::trimFeature( QPolygonF& pts, bool shapeOpen )
+inline void QgsClipper::trimPolygon( QPolygonF& pts, const QgsRectangle& clipRect )
- bool needs_clipping = false;
- const QPointF* ptsData = pts.constData();
- for ( int i = 0; i < pts.count(); i++, ptsData++ )
- if ( ptsData->x() < MIN_X || ptsData->x() > MAX_X
- || ptsData->y() < MIN_Y || ptsData->y() > MAX_Y )
- needs_clipping = true;
- break;
- if ( !needs_clipping )
- return;
QPolygonF tmpPts;
tmpPts.reserve( pts.size() );
- trimFeatureToBoundary( pts, tmpPts, XMax, shapeOpen );
+ trimPolygonToBoundary( pts, tmpPts, clipRect, XMax, clipRect.xMaximum() );
pts.clear();
- trimFeatureToBoundary( tmpPts, pts, YMax, shapeOpen );
+ trimPolygonToBoundary( tmpPts, pts, clipRect, YMax, clipRect.yMaximum() );
tmpPts.clear();
- trimFeatureToBoundary( pts, tmpPts, XMin, shapeOpen );
+ trimPolygonToBoundary( pts, tmpPts, clipRect, XMin, clipRect.xMinimum() );
pts.clear();
- trimFeatureToBoundary( tmpPts, pts, YMin, shapeOpen );
+ trimPolygonToBoundary( tmpPts, pts, clipRect, YMin, clipRect.yMinimum() );
// An auxilary function that is part of the polygon trimming
@@ -280,22 +261,16 @@
-inline void QgsClipper::trimFeatureToBoundary(
- const QPolygonF& inPts, QPolygonF& outPts,
- Boundary b, bool shapeOpen )
+inline void QgsClipper::trimPolygonToBoundary( const QPolygonF& inPts, QPolygonF& outPts, const QgsRectangle& rect, Boundary b, double boundaryValue )
- // The shapeOpen parameter selects whether this function treats the
- // shape as open or closed. False is appropriate for polygons and
- // true for polylines.
unsigned int i1 = inPts.size() - 1; // start with last point
// and compare to the first point initially.
for ( int i2 = 0; i2 < inPts.size() ; ++i2 )
{ // look at each edge of the polygon in turn
- if ( inside( inPts[i2], b ) ) // end point of edge is inside boundary
+ if ( inside( inPts[i2], b, boundaryValue ) ) // end point of edge is inside boundary
- if ( inside( inPts[i1], b ) )
+ if ( inside( inPts[i1], b, boundaryValue ) )
outPts.append( inPts[i2] );
@@ -303,23 +278,16 @@
// edge crosses into the boundary, so trim back to the boundary, and
// store both ends of the new edge
- if ( !( i2 == 0 && shapeOpen ) )
- outPts.append( intersect( inPts[i1], inPts[i2], b ) );
+ outPts.append( intersectRect( inPts[i1], inPts[i2], b, rect ) );
else // end point of edge is outside boundary
// start point is in boundary, so need to trim back
i1 = i2;
@@ -353,18 +321,18 @@
return false;
-inline bool QgsClipper::inside( const QPointF& pt, Boundary b )
+inline bool QgsClipper::inside( const QPointF& pt, Boundary b, double val )
switch ( b )
case XMax: // x < MAX_X is inside
- return ( pt.x() < MAX_X );
+ return ( pt.x() < val );
case XMin: // x > MIN_X is inside
- return ( pt.x() > MIN_X );
+ return ( pt.x() > val );
case YMax: // y < MAX_Y is inside
- return ( pt.y() < MAX_Y );
+ return ( pt.y() < val );
case YMin: // y > MIN_Y is inside
- return ( pt.y() > MIN_Y );
+ return ( pt.y() > val );
return false;
@@ -421,9 +389,9 @@
return p;
-inline QPointF QgsClipper::intersect( const QPointF& pt1,
- Boundary b )
+inline QPointF QgsClipper::intersectRect( const QPointF& pt1,
// This function assumes that the two given points (x1, y1), and
// (x2, y2) cross the given boundary. Making this assumption allows
@@ -436,20 +404,20 @@
switch ( b )
case XMax: // x = MAX_X boundary
- r_n = -( x1 - MAX_X ) * ( MAX_Y - MIN_Y );
- r_d = ( x2 - x1 ) * ( MAX_Y - MIN_Y );
+ r_n = -( x1 - rect.xMaximum() ) * ( rect.yMaximum() - rect.yMinimum() );
+ r_d = ( x2 - x1 ) * ( rect.yMaximum() - rect.yMinimum() );
break;
case XMin: // x = MIN_X boundary
- r_n = -( x1 - MIN_X ) * ( MAX_Y - MIN_Y );
+ r_n = -( x1 - rect.xMinimum() ) * ( rect.yMaximum() - rect.yMinimum() );
break;
case YMax: // y = MAX_Y boundary
- r_n = ( y1 - MAX_Y ) * ( MAX_X - MIN_X );
- r_d = -( y2 - y1 ) * ( MAX_X - MIN_X );
+ r_n = ( y1 - rect.yMaximum() ) * ( rect.xMaximum() - rect.xMinimum() );
+ r_d = -( y2 - y1 ) * ( rect.xMaximum() - rect.xMinimum() );
break;
case YMin: // y = MIN_Y boundary
- r_n = ( y1 - MIN_Y ) * ( MAX_X - MIN_X );
+ r_n = ( y1 - rect.yMinimum() ) * ( rect.xMaximum() - rect.xMinimum() );
break;
Modified: trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp 2011-03-20 22:47:02 UTC (rev 15546)
+++ trunk/qgis/src/core/symbology-ng/qgsrendererv2.cpp 2011-03-21 08:08:43 UTC (rev 15547)
@@ -118,6 +118,10 @@
const QgsMapToPixel& mtp = context.mapToPixel();
double z = 0; // dummy variable for coordiante transform
+ const QgsRectangle& e = context.extent();
+ double cw = e.width() / 10; double ch = e.height() / 10;
+ QgsRectangle clipRect( e.xMinimum() - cw, e.yMinimum() - ch, e.xMaximum() + cw, e.yMaximum() + ch );
for ( unsigned int idx = 0; idx < numRings; idx++ )
unsigned int nPoints = *(( int* )wkb );
@@ -131,14 +135,6 @@
x = *(( double * ) wkb ); wkb += sizeof( double );
y = *(( double * ) wkb ); wkb += sizeof( double );
- // TODO: maybe to the transform at once (faster?)
- if ( ct )
- z = 0;
- ct->transformInPlace( x, y, z );
- mtp.transformInPlace( x, y );
poly[jdx] = QPointF( x, y );
if ( hasZValue )
@@ -148,6 +144,20 @@
if ( nPoints < 1 )
continue;
+ //clip close to view extent
+ QgsClipper::trimPolygon( poly, clipRect );
+ //transform the QPolygonF to screen coordinates
+ for ( int i = 0; i < poly.size(); ++i )
+ if ( ct )
+ z = 0;
+ ct->transformInPlace( poly[i].rx(), poly[i].ry(), z );
+ mtp.transformInPlace( poly[i].rx(), poly[i].ry() );
if ( idx == 0 )
pts = poly;
else
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2011-03-20 22:47:02 UTC (rev 15546)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.cpp 2011-03-21 08:08:43 UTC (rev 15547)
@@ -74,27 +74,19 @@
if ( rings == NULL )
// simple polygon without holes
- // clip polygon rings! Qt (as of version 4.6) has a slow algorithm for
- // clipping painter paths: we will clip the rings by ourselves, so
- // the clipping in Qt will not be triggered.
- QPolygonF ring = points;
- QgsClipper::trimFeature( ring, false );
- p->drawPolygon( ring );
+ p->drawPolygon( points );
else
// polygon with holes must be drawn using painter path
QPainterPath path;
QPolygonF outerRing = points;
- QgsClipper::trimFeature( outerRing, false );
path.addPolygon( outerRing );
QList<QPolygonF>::const_iterator it = rings->constBegin();
for ( ; it != rings->constEnd(); ++it )
QPolygonF ring = *it;
path.addPolygon( ring );
