[QGIS Commit] r15555 - in trunk/qgis/python/plugins/GdalTools: .
tools
svn_qgis at osgeo.org
Mon Mar 21 19:54:27 EDT 2011
Author: brushtyler
Date: 2011-03-21 16:54:27 -0700 (Mon, 21 Mar 2011)
New Revision: 15555
trunk/qgis/python/plugins/GdalTools/GdalTools.py
trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py
trying to avoid strange closing of the tools
Modified: trunk/qgis/python/plugins/GdalTools/GdalTools.py
--- trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-21 20:35:02 UTC (rev 15554)
+++ trunk/qgis/python/plugins/GdalTools/GdalTools.py 2011-03-21 23:54:27 UTC (rev 15555)
@@ -230,98 +230,103 @@
def doBuildVRT( self ):
from tools.doBuildVRT import GdalToolsDialog as BuildVRT
d = BuildVRT( self.iface )
- d.show_()
+ self.runToolDialog( d )
def doContour( self ):
from tools.doContour import GdalToolsDialog as Contour
d = Contour( self.iface )
- d.show_()
def doRasterize( self ):
from tools.doRasterize import GdalToolsDialog as Rasterize
d = Rasterize( self.iface )
- d.show_()
def doPolygonize( self ):
from tools.doPolygonize import GdalToolsDialog as Polygonize
d = Polygonize( self.iface )
- d.show_()
def doMerge( self ):
from tools.doMerge import GdalToolsDialog as Merge
d = Merge( self.iface )
- d.show_()
def doSieve( self ):
from tools.doSieve import GdalToolsDialog as Sieve
d = Sieve( self.iface )
- d.show_()
def doProximity( self ):
from tools.doProximity import GdalToolsDialog as Proximity
d = Proximity( self.iface )
- d.show_()
def doNearBlack( self ):
from tools.doNearBlack import GdalToolsDialog as NearBlack
d = NearBlack( self.iface )
- d.show_()
def doWarp( self ):
from tools.doWarp import GdalToolsDialog as Warp
d = Warp( self.iface )
- d.show_()
def doGrid( self ):
from tools.doGrid import GdalToolsDialog as Grid
d = Grid( self.iface )
- d.show_()
def doTranslate( self ):
from tools.doTranslate import GdalToolsDialog as Translate
d = Translate( self.iface )
- d.show_()
def doInfo( self ):
from tools.doInfo import GdalToolsDialog as Info
d = Info( self.iface )
- d.show_()
def doProjection( self ):
from tools.doProjection import GdalToolsDialog as Projection
d = Projection( self.iface )
- d.show_()
def doOverview( self ):
from tools.doOverview import GdalToolsDialog as Overview
d = Overview( self.iface )
- d.show_()
def doClipper( self ):
from tools.doClipper import GdalToolsDialog as Clipper
d = Clipper( self.iface )
- d.show_()
def doPaletted( self ):
from tools.doRgbPct import GdalToolsDialog as RgbPct
d = RgbPct( self.iface )
- d.show_()
def doRGB( self ):
from tools.doPctRgb import GdalToolsDialog as PctRgb
d = PctRgb( self.iface )
- d.show_()
def doTileIndex( self ):
from tools.doTileIndex import GdalToolsDialog as TileIndex
d = TileIndex( self.iface )
- d.show_()
def doDEM( self ):
from tools.doDEM import GdalToolsDialog as DEM
d = DEM( self.iface )
- d.show_()
+ def runToolDialog( self, dlg ):
+ dlg.show_()
+ dlg.exec_()
+ del dlg
def doSettings( self ):
from tools.doSettings import GdalToolsSettingsDialog as Settings
d = Settings( self.iface )
Modified: trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
--- trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2011-03-21 20:35:02 UTC (rev 15554)
+++ trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2011-03-21 23:54:27 UTC (rev 15555)
@@ -22,6 +22,7 @@
# set the default QSpinBoxes and QProgressBar value
self.progressBar.setValue(0)
+ self.jpegQualitySpin.setValue(80)
self.progressBar.hide()
# we don't need load to canvas functionality
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2011-03-21 20:35:02 UTC (rev 15554)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2011-03-21 23:54:27 UTC (rev 15555)
@@ -205,9 +205,6 @@
<property name="maximum">
<number>100</number>
</property>
- <property name="value">
- <number>80</number>
- </property>
</widget>
</item>
</layout>
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py
--- trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py 2011-03-21 20:35:02 UTC (rev 15554)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py 2011-03-21 23:54:27 UTC (rev 15555)
@@ -11,7 +11,9 @@
def __init__(self, iface, commandName, helpFileBaseName = None, parent = None):
self.iface = iface
+ self.initialized = False
self.base = BaseDialog(parent, iface, self, self.windowTitle(), commandName)
self.connect(self.base, SIGNAL("processError(QProcess::ProcessError)"), self.onError)
self.connect(self.base, SIGNAL("processFinished(int, QProcess::ExitStatus)"), self.onFinished)
@@ -28,15 +30,19 @@
pass
def exec_(self):
- self.connect(Utils.LayerRegistry.instance(), SIGNAL("layersChanged"), self.onLayersChanged)
- self.layersChanged()
- self.someValueChanged()
+ if not self.initialized:
+ self.connect(Utils.LayerRegistry.instance(), SIGNAL("layersChanged"), self.onLayersChanged)
+ self.onLayersChanged()
+ self.someValueChanged()
+ self.initialized = True
return self.base.exec_()
def show_(self):
- self.onLayersChanged()
return self.base.show()
def setCommandViewerEnabled(self, enable):
