[QGIS Commit] r15562 - trunk/qgis/python/plugins/GdalTools/tools
svn_qgis at osgeo.org
Tue Mar 22 12:45:30 EDT 2011
Author: brushtyler
Date: 2011-03-22 09:45:30 -0700 (Tue, 22 Mar 2011)
New Revision: 15562
trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py
trunk/qgis/python/plugins/GdalTools/tools/extentSelector.py
remove the clipping rectangle closing clipper, to fix #3664
Modified: trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py
--- trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py 2011-03-22 15:39:10 UTC (rev 15561)
+++ trunk/qgis/python/plugins/GdalTools/tools/dialogBase.py 2011-03-22 16:45:30 UTC (rev 15562)
@@ -66,6 +66,14 @@
self.arguments = QStringList()
def reject(self):
+ if self.process.state() != QProcess.NotRunning:
+ ret = QMessageBox.warning(self, self.tr( "Warning" ), self.tr( "The command is still running. \nDo you want terminate it anyway?" ), QMessageBox.Yes | QMessageBox.No)
+ if ret == QMessageBox.No:
+ return
+ self.disconnect(self.process, SIGNAL("error(QProcess::ProcessError)"), self.processError)
+ self.disconnect(self.process, SIGNAL("finished(int, QProcess::ExitStatus)"), self.processFinished)
self.emit( SIGNAL("closeClicked()") )
def accept(self):
@@ -129,16 +137,6 @@
# called on closing the dialog, stop the process if it's running
def onClosing(self):
- if self.process.state() != QProcess.NotRunning:
- ret = QMessageBox.warning(self, self.tr( "Warning" ), self.tr( "The command is still running. \nDo you want terminate it anyway?" ), QMessageBox.Yes | QMessageBox.No)
- if ret == QMessageBox.No:
- return
- self.disconnect(self.process, SIGNAL("error(QProcess::ProcessError)"), self.processError)
- self.disconnect(self.process, SIGNAL("finished(int, QProcess::ExitStatus)"), self.processFinished)
- #self.process.kill()
- #print "Debug: " + self.command + " terminated by user"
self.stop()
QDialog.reject(self)
Modified: trunk/qgis/python/plugins/GdalTools/tools/extentSelector.py
--- trunk/qgis/python/plugins/GdalTools/tools/extentSelector.py 2011-03-22 15:39:10 UTC (rev 15561)
+++ trunk/qgis/python/plugins/GdalTools/tools/extentSelector.py 2011-03-22 16:45:30 UTC (rev 15562)
@@ -32,16 +32,21 @@
self.connect(self.tool, SIGNAL("deactivated()"), self.pause)
def stop(self):
+ if not self.isStarted:
+ return
self.isStarted = False
self.btnEnable.setVisible(False)
self.tool.reset()
self.canvas.unsetMapTool(self.tool)
- self.canvas.setMapTool(self.previousMapTool)
+ if self.previousMapTool != self.tool:
+ self.canvas.setMapTool(self.previousMapTool)
#self.coordsChanged()
self.emit( SIGNAL( "selectionStopped()" ) )
def start(self):
- self.previousMapTool = self.canvas.mapTool()
+ prevMapTool = self.canvas.mapTool()
+ if prevMapTool != self.tool:
+ self.previousMapTool = prevMapTool
self.canvas.setMapTool(self.tool)
self.isStarted = True
