[QGIS Commit] r15593 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Mar 24 16:06:14 EDT 2011
Author: macho
Date: 2011-03-24 13:06:14 -0700 (Thu, 24 Mar 2011)
New Revision: 15593
   trunk/qgis/i18n/qgis_hr_HR.ts
translation update: hr_HR by Zoran
Modified: trunk/qgis/i18n/qgis_hr_HR.ts
--- trunk/qgis/i18n/qgis_hr_HR.ts	2011-03-24 17:03:27 UTC (rev 15592)
+++ trunk/qgis/i18n/qgis_hr_HR.ts	2011-03-24 20:06:14 UTC (rev 15593)
@@ -1607,35 +1607,35 @@
     </message>
     <message>
         <source>Build Virtual Raster (Catalog)</source>
-        <translation type="unfinished"></translation>
+        <translation>Izgradi virtualni raster (katalog)</translation>
     </message>
     <message>
         <source>Rasterize (Vector to raster)</source>
+        <translation>Konvertiraj raster u vektor</translation>
     </message>
     <message>
         <source>Polygonize (Raster to vector)</source>
+        <translation>Poligonizacija (raster u vektor)</translation>
     </message>
     <message>
         <source>Proximity (Raster distance)</source>
+        <translation>Bliskost (Raster udaljenosti)</translation>
     </message>
     <message>
         <source>Warp (Reproject)</source>
+        <translation>Reprojekcija</translation>
     </message>
     <message>
         <source>Grid (Interpolation)</source>
+        <translation>Grid (interpolacija)</translation>
     </message>
     <message>
         <source>Translate (Convert format)</source>
+        <translation>Prijevod (Izmjena formata)</translation>
     </message>
     <message>
         <source>Build overviews (Pyramids)</source>
+        <translation>Izgradi preglede (Piramide)</translation>
     </message>
     <message>
         <source>Builds or rebuilds overview images</source>
@@ -1671,11 +1671,11 @@
     </message>
     <message>
         <source>DEM (Terrain models)</source>
+        <translation>DEM (modeli terena)</translation>
     </message>
     <message>
         <source>Tool to analyze and visualize DEMs</source>
+        <translation>Alat za analizu i vizualizaciju DEM-a</translation>
     </message>
     <message>
         <source>GdalTools settings</source>
@@ -1971,7 +1971,7 @@
     </message>
     <message>
         <source>Select the cutline file</source>
+        <translation>Izaberite &quot;cutline&quot; datoteku</translation>
     </message>
     <message>
         <source>Select the input file for Grid</source>
@@ -1987,11 +1987,11 @@
     </message>
     <message>
         <source>Select the file for DEM</source>
+        <translation>Odaberite datoteku za DEM</translation>
     </message>
     <message>
         <source>Select the color configuration file</source>
+        <translation>Odaberite datoteku s konfiguracijom boja</translation>
     </message>
     <message>
         <source>Translate - srcwin</source>
@@ -2015,11 +2015,11 @@
     </message>
     <message>
         <source>Output size required</source>
+        <translation>Potrebna izlazna veličina</translation>
     </message>
     <message>
         <source>The output file doesn&apos;t exist. You must set up the output size to create it.</source>
+        <translation>Izlazna datoteka ne postoji. Morate postaviti izlaznu veličinu kako bi je kreirali.</translation>
     </message>
     <message>
         <source>Select the input file for Proximity</source>
@@ -2027,15 +2027,15 @@
     </message>
     <message>
         <source>Select the input directory with files for VRT</source>
+        <translation>Odaberite ulaznu mapu datoteka s dateotekama za VRT</translation>
     </message>
     <message>
         <source>Select the input directory with raster files</source>
+        <translation>Odaberite ulaznu mapu datoteka s rasterima</translation>
     </message>
     <message>
         <source>Select where to save the TileIndex output</source>
+        <translation>Izaberite odredište za spremanje TileIndex izlaza</translation>
     </message>
     <message>
         <source>Error retrieving the extent</source>
@@ -2083,7 +2083,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/extentSelector.ui" line="20"/>
         <source>Select the extent by drag on canvas</source>
+        <translation>Odabir raspona vučenjem po prikazu</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/extentSelector.ui" line="27"/>
@@ -2250,12 +2250,12 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="31"/>
         <source>Choose input directory instead of files</source>
+        <translation>Odaberite ulaznu mapu datoteka umjesto pojedinačnih</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="38"/>
@@ -2306,7 +2306,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetBuildVRT.ui" line="156"/>
         <source>Se&amp;parate</source>
+        <translation>Raz&amp;dvoji</translation>
     </message>
     <message>
         <source>&amp;Resolution:</source>
@@ -2325,7 +2325,7 @@
         <location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="75"/>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="843"/>
         <source>Extent</source>
+        <translation>Raspon</translation>
     </message>
     <message>
         <source>&amp;No data value:</source>
@@ -2569,7 +2569,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="267"/>
@@ -2681,47 +2681,47 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="28"/>
         <source>&amp;Input file (DEM raster)</source>
+        <translation>&amp;Ulazna datoteka (DEM raster)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="96"/>
         <source>&amp;Band</source>
+        <translation>&amp;Kanal</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="110"/>
         <source>Compute &amp;edges</source>
+        <translation>Računaj rubov&amp;e</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="117"/>
         <source>&amp;Mode</source>
+        <translation>&amp;Mod</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="137"/>
         <source>Hillshade</source>
+        <translation>Sjenčenje</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="142"/>
         <source>Slop</source>
+        <translation>Nagib</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="147"/>
         <source>Aspect</source>
-        <translation type="unfinished">Aspekt</translation>
+        <translation>Aspekt</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="152"/>
         <source>Color relief</source>
+        <translation>Bojani reljef</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="157"/>
@@ -2736,7 +2736,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="167"/>
         <source>Roughness</source>
+        <translation>Grubost</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="175"/>
@@ -2746,63 +2746,63 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="191"/>
         <source>Z factor (vertical exaggeration)</source>
+        <translation>Z faktor (vertikalno karikiranje)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="214"/>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="294"/>
         <source>Scale (ratio of vert. units to horiz.)</source>
+        <translation>Mjerilo (odnos vert. prema horiz. jedinicama)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="237"/>
         <source>Azimuth of the light</source>
+        <translation>Azimut svjetla</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="260"/>
         <source>Altitude of the light</source>
+        <translation>Visina svjetla</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="287"/>
         <source>Slope expressed as percent (instead of as degrees)</source>
+        <translation>Nagib u postocima (umjesto stupnjeva)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="334"/>
         <source>Return trigonometric angle (instead of azimuth)</source>
+        <translation>Vrati trigonometrijski kut (umjesto azimuta)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="341"/>
         <source>Return 0 for flat (instead of -9999)</source>
+        <translation>Vrati 0 za ravno (umjesto -9999)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="365"/>
         <source>Color configuration file</source>
+        <translation>Datoteka s konfiguracijom boje</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="393"/>
         <source>Matching mode</source>
+        <translation>Mod uparivanja</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="405"/>
         <source>Exact color (otherwise &quot;0,0,0,0&quot; RGBA)</source>
+        <translation>Točna boja (inače &quot;0,0,0,0&quot; RGBA)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="418"/>
         <source>Nearest color</source>
+        <translation>Najbliža boja</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="428"/>
         <source>Add alpha channel</source>
+        <translation>Dodaj alpha kanal</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="455"/>
@@ -2841,7 +2841,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="72"/>
@@ -2936,7 +2936,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetOverview.ui" line="221"/>
         <source>Use Imagine format (.aux file)</source>
+        <translation>Koristi Imagine oblik (.aux datoteka)</translation>
     </message>
     <message>
         <source>Polygonize</source>
@@ -2945,7 +2945,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetPolygonize.ui" line="65"/>
@@ -3020,7 +3020,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetProximity.ui" line="89"/>
@@ -3082,7 +3082,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="28"/>
@@ -3097,12 +3097,12 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="85"/>
         <source>&amp;Output file for rasterized vectors (raster)</source>
+        <translation>&amp;Izlazna datoteka za rasterizirane vektore (raster, mora postojati)</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetRasterize.ui" line="118"/>
         <source>New size (required if output file doens&apos;t exist)</source>
+        <translation>Nova veličina (potrebno ako ne postoji izlazna datoteka)</translation>
     </message>
     <message>
         <source>&amp;Output file for rasterized vectors (raster, must exists)</source>
@@ -3197,7 +3197,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetTranslate.ui" line="35"/>
@@ -3295,7 +3295,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="20"/>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="167"/>
@@ -5487,13 +5487,14 @@
         <location filename="../src/app/qgspluginregistry.cpp" line="278"/>
         <source>Library name is %1
 </source>
+        <translation>Naziv biblioteke je %1
+</translation>
     </message>
     <message>
         <location filename="../src/app/qgspluginregistry.cpp" line="287"/>
         <source>Attempting to resolve the classFactory function
 </source>
+        <translation></translation>
     </message>
     <message>
         <location filename="../src/app/qgspluginregistry.cpp" line="339"/>
@@ -5559,7 +5560,7 @@
     <message>
         <location filename="../src/core/qgsdistancearea.cpp" line="480"/>
         <source>Caught a coordinate system exception while trying to transform a point. Unable to calculate polygon area or perimeter.</source>
     </message>
     <message>
         <location filename="../src/core/qgsdistancearea.cpp" line="782"/>
@@ -5689,7 +5690,7 @@
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="472"/>
         <source>Could not retrieve value of list value</source>
+        <translation>Ne može se povući popis vrijednosti</translation>
     </message>
     <message>
         <location filename="../src/core/qgssearchtreenode.cpp" line="503"/>
@@ -6432,12 +6433,12 @@
     <message>
         <location filename="../src/providers/grass/qgsgrass.cpp" line="1225"/>
         <source>Cannot get map info</source>
+        <translation>Nema dostupnih informacija o mapi</translation>
     </message>
     <message>
         <location filename="../src/providers/grass/qgsgrass.cpp" line="1254"/>
         <source>Cannot get colors</source>
+        <translation>Nema dostupnih boja</translation>
     </message>
     <message>
         <location filename="../src/providers/grass/qgsgrass.cpp" line="1277"/>
@@ -6643,13 +6644,13 @@
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="818"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1342"/>
         <source>Arc/Info ASCII Coverage</source>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="825"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1346"/>
         <source>Atlas BNA</source>
+        <translation>Atlas BNA</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="832"/>
@@ -6673,13 +6674,13 @@
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="853"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1378"/>
         <source>GeoJSON</source>
+        <translation>GeoJSON</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="860"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1382"/>
         <source>GeoRSS</source>
+        <translation>GeoRSS</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="867"/>
@@ -6715,13 +6716,13 @@
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="888"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1406"/>
         <source>INTERLIS 1</source>
+        <translation>INTERLIS 1</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="895"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1410"/>
         <source>INTERLIS 2</source>
+        <translation>INTERLIS 2</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="909"/>
@@ -6733,7 +6734,7 @@
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="916"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1426"/>
         <source>Microstation DGN</source>
+        <translation>Microstation DGN</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="923"/>
@@ -6745,19 +6746,19 @@
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="937"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1460"/>
         <source>SQLite</source>
+        <translation>SQLite</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="944"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1487"/>
         <source>AutoCAD DXF</source>
+        <translation>AutoCAD DXF</translation>
     </message>
     <message>
         <location filename="../src/core/qgsvectorfilewriter.cpp" line="951"/>
         <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="1483"/>
         <source>Geoconcept</source>
+        <translation>Geoconcept</translation>
     </message>
     <message>
         <location filename="../src/providers/grass/qgsgrassrasterprovider.cpp" line="60"/>
@@ -6804,7 +6805,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="365"/>
         <source>CRS undefined - defaulting to default CRS: %1</source>
+        <translation>CRS nije definirana - povratak an azdani CRS: %1</translation>
     </message>
     <message>
         <source>CRS undefined - defaulting to default CRS</source>
@@ -7733,7 +7734,7 @@
         <translation type="obsolete">Ctrl+B</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6523"/>
+        <location filename="../src/app/qgisapp.cpp" line="6525"/>
         <source>New Bookmark</source>
         <translation>Nova zabilješka</translation>
     </message>
@@ -8289,7 +8290,7 @@
         <translation>Prekinuta operacija unije</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6795"/>
+        <location filename="../src/app/qgisapp.cpp" line="6797"/>
         <source>SSL errors occured accessing URL %1:</source>
         <translation>Dogodile su se SSL greške pri pristupanju URL-u %1:</translation>
     </message>
@@ -8358,7 +8359,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2042"/>
         <source>Plugins</source>
-        <translation type="unfinished">Dodaci</translation>
+        <translation>Dodaci</translation>
     </message>
     <message>
         <source>Help</source>
@@ -8556,22 +8557,22 @@
         <translation>Mjerilo pločice</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6737"/>
+        <location filename="../src/app/qgisapp.cpp" line="6739"/>
         <source>Warning</source>
         <translation>Upozorenje</translation>
     </message>
     <message>
         <source>This layer doesn&apos;t have a properties dialog.</source>
         <translation>Ovaj sloj nema dijalog s osobinama.</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6768"/>
+        <location filename="../src/app/qgisapp.cpp" line="6770"/>
         <source>Authentication required</source>
         <translation>Zahtjeva se autentikacija</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6784"/>
+        <location filename="../src/app/qgisapp.cpp" line="6786"/>
         <source>Proxy authentication required</source>
         <translation>Potrebna proxy autentikacija</translation>
     </message>
@@ -8655,7 +8656,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="2170"/>
         <location filename="../src/app/qgisapp.cpp" line="2177"/>
-        <location filename="../src/app/qgisapp.cpp" line="6227"/>
+        <location filename="../src/app/qgisapp.cpp" line="6229"/>
         <source>Invalid Data Source</source>
         <translation>Nevaljani izvor podataka</translation>
     </message>
@@ -8978,14 +8979,14 @@
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6808"/>
+        <location filename="../src/app/qgisapp.cpp" line="6810"/>
         <source>
 Always ignore these errors?</source>
     </message>
     <message numerus="yes">
-        <location filename="../src/app/qgisapp.cpp" line="6812"/>
+        <location filename="../src/app/qgisapp.cpp" line="6814"/>
         <source>%n SSL errors occured</source>
         <comment>number of errors</comment>
@@ -8999,7 +9000,7 @@
         <location filename="../src/app/qgisapp.cpp" line="4270"/>
         <location filename="../src/app/qgisapp.cpp" line="4352"/>
         <location filename="../src/app/qgisapp.cpp" line="4366"/>
-        <location filename="../src/app/qgisapp.cpp" line="6541"/>
+        <location filename="../src/app/qgisapp.cpp" line="6543"/>
         <source>Error</source>
         <translation>Pogreška</translation>
     </message>
@@ -9496,7 +9497,7 @@
     <message>
         <location filename="../src/app/qgisapp.cpp" line="5091"/>
         <location filename="../src/app/qgisapp.cpp" line="5133"/>
-        <location filename="../src/app/qgisapp.cpp" line="6308"/>
+        <location filename="../src/app/qgisapp.cpp" line="6310"/>
         <source>Layer is not valid</source>
         <translation>Sloj nije valjan</translation>
     </message>
@@ -9507,7 +9508,7 @@
     </message>
     <message>
         <location filename="../src/app/qgisapp.cpp" line="5134"/>
-        <location filename="../src/app/qgisapp.cpp" line="6309"/>
+        <location filename="../src/app/qgisapp.cpp" line="6311"/>
         <source>The layer is not a valid layer and can not be added to the map</source>
         <translation>Sloj nije valjan i ne može se dodati na mapu</translation>
     </message>
@@ -9562,53 +9563,53 @@
         </translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6139"/>
+        <location filename="../src/app/qgisapp.cpp" line="6141"/>
         <source>Open a GDAL Supported Raster Data Source</source>
         <translation>Otvorite GDAL podržani rasterski izvor podataka</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6226"/>
+        <location filename="../src/app/qgisapp.cpp" line="6228"/>
         <source>%1 is not a valid or recognized raster data source</source>
         <translation>%1 nije valjani ili prepoznati rasterski izvor podataka</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6402"/>
+        <location filename="../src/app/qgisapp.cpp" line="6404"/>
         <source>%1 is not a supported raster data source</source>
         <translation>%1 nije podržani rasterski izvor podataka</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6407"/>
+        <location filename="../src/app/qgisapp.cpp" line="6409"/>
         <source>Unsupported Data Source</source>
         <translation>Nepodržani izvor podataka</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6524"/>
+        <location filename="../src/app/qgisapp.cpp" line="6526"/>
         <source>Enter a name for the new bookmark:</source>
         <translation>Upišite naziv za novu zabilješku:</translation>
     </message>
     <message>
         <source>Unable to create the bookmark. Your user database may be missing or corrupted</source>
         <translation>Nemoguće kreirati zabilješku. Vaša korisnička baza podataka možda ne postoji ili je pokvarena</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6556"/>
+        <location filename="../src/app/qgisapp.cpp" line="6558"/>
         <source>Project file is older</source>
         <translation>Datoteka projekta je starija</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6557"/>
+        <location filename="../src/app/qgisapp.cpp" line="6559"/>
         <source>&lt;p&gt;This project file was saved by an older version of QGIS. When saving this project file, QGIS will update it to the latest version, possibly rendering it useless for older versions of QGIS.&lt;p&gt;Even though QGIS developers try to maintain backwards compatibility, some of the information from the old project file might be lost. To improve the quality of QGIS, we appreciate if you file a bug report at %3. Be sure to include the old project file, and state the version of QGIS you used to discover the error.&lt;p&gt;To remove this warning when opening an older project file, uncheck the box &apos;%5&apos; in the %4 menu.&lt;p&gt;Version of the project file: %1&lt;br&gt;Current version of QGIS: %2</source>
         <translation>&lt;p&gt;Ova datoteka projekta snimljena je starijom verzijom QGIS-a. Pri snimanju QGIS će ju osvježiti na najnoviju verziju, i moguće je da neće biti čitljiva za starije verzije.&lt;p&gt;Iako razvojni inženjeri pokušavaju održati kompatibilnost neke informacije iz starije datoteke mogu se izgubiti. Kako bismo unaprijedili kvalitetu QGIS-a molimo da ispuniti izvješće o bugu na %3. Priložite staru projektnu datoteku i navedite verziju QGIS-a s kojom ste otkrili pogrešku.&lt;p&gt;Kako biste uklonili ovo upozorenje prilikom otvaranja starije datoteke uklonite oznaku iz kvadratića &apos;%5&apos; u izborniku %4.&lt;p&gt;Verzija projektne datoteke: %1&lt;br&gt;Trenutna verzija QGIS-a: %2</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6573"/>
+        <location filename="../src/app/qgisapp.cpp" line="6575"/>
         <source>&lt;tt&gt;Settings:Options:General&lt;/tt&gt;</source>
         <comment>Menu path to setting options</comment>
         <translation>&lt;tt&gt;Postavke:Opcije:Općenito&lt;/tt&gt;</translation>
     </message>
     <message>
-        <location filename="../src/app/qgisapp.cpp" line="6574"/>
+        <location filename="../src/app/qgisapp.cpp" line="6576"/>
         <source>Warn me when opening a project file saved with an older version of QGIS</source>
         <translation>Upozori me pri otvaranju projektne datoteke spremljene starijom verzijom QGIS-a</translation>
     </message>
@@ -9829,7 +9830,7 @@
     <message>
         <location filename="../src/ui/qgsaddjoindialogbase.ui" line="20"/>
         <source>Join layer</source>
-        <translation type="unfinished">Spoji sloj</translation>
+        <translation>Spoji sloj</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsaddjoindialogbase.ui" line="30"/>
@@ -13667,7 +13668,7 @@
     <message>
         <location filename="../src/app/qgsconfigureshortcutsdialog.cpp" line="184"/>
         <source>The file contains shortcuts created with different locale, so you can&apos;t use it.</source>
-        <translation>Daoteka sadrži prečice stvorene s različitim regionanim postavkama, pa ju ne možete koristiti.</translation>
+        <translation>Datoteka sadrži prečice stvorene s različitim regionanim postavkama, pa ju ne možete koristiti.</translation>
     </message>
     <message>
         <location filename="../src/app/qgsconfigureshortcutsdialog.cpp" line="248"/>
@@ -14700,7 +14701,7 @@
     <message>
         <location filename="../src/ui/qgsdisplayanglebase.ui" line="50"/>
         <source>Ellipsoidal</source>
-        <translation type="unfinished">Elipsoidalni</translation>
+        <translation>Elipsoidalni</translation>
     </message>
 </context>
 <context>
@@ -16238,7 +16239,7 @@
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="139"/>
         <source>Paper size</source>
+        <translation>Veličina papira</translation>
     </message>
     <message>
         <location filename="../src/plugins/georeferencer/qgsgeorefconfigdialogbase.ui" line="43"/>
@@ -19281,7 +19282,8 @@
         <location filename="../src/plugins/grass/qgsgrassregionbase.ui" line="96"/>
         <source>Select the extent by dragging on canvas
 or change the following values</source>
+        <translation>Odaberite raspon vučenejm po prikazu
+ili izmjienite slijedeće vrijednosti</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/qgsgrassregionbase.ui" line="107"/>
@@ -24918,7 +24920,7 @@
     <message>
         <location filename="../src/ui/qgspgnewconnectionbase.ui" line="271"/>
         <source>Also list tables with no geometry</source>
-        <translation type="unfinished">Također prikaži tablice bez geometrije</translation>
+        <translation>Također prikaži tablice bez geometrije</translation>
     </message>
 </context>
 <context>
@@ -26914,37 +26916,37 @@
         <translation>Sve</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="590"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="594"/>
         <source>User Defined Coordinate Systems</source>
         <translation>Korisnički definirani koordinatni sustavi</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="665"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="669"/>
         <source>Geographic Coordinate Systems</source>
         <translation>Geografski koordinatni sustavi</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="674"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="678"/>
         <source>Projected Coordinate Systems</source>
         <translation>Projicirani koordinatni sustavi</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="968"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="972"/>
         <source>Find projection</source>
         <translation>Pronađi projekciju</translation>
     </message>
     <message>
         <source>No matching projection found.</source>
         <translation>Nema odgovarajućih projekcija.</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="1107"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="1111"/>
         <source>Resource Location Error</source>
         <translation>Pogreška u lociranju resursa</translation>
     </message>
     <message>
-        <location filename="../src/gui/qgsprojectionselector.cpp" line="1108"/>
+        <location filename="../src/gui/qgsprojectionselector.cpp" line="1112"/>
         <source>Error reading database file from:
  %1
 Because of this the projection selector will not work...</source>
@@ -27778,7 +27780,7 @@
     <message>
         <location filename="../src/core/raster/qgsrasterlayer.cpp" line="2335"/>
         <source>Specify CRS for layer %1</source>
-        <translation type="unfinished">Odredi CRS za sloj %1</translation>
+        <translation>Odredi CRS za sloj %1</translation>
     </message>
 </context>
 <context>
@@ -29687,7 +29689,7 @@
     <message>
         <location filename="../src/gui/qgssearchquerybuilder.cpp" line="425"/>
         <source>File is not a valid xml document</source>
-        <translation>Daoteka nije valjani xml dokumet</translation>
+        <translation>Datoteka nije valjani xml dokumet</translation>
     </message>
     <message>
         <location filename="../src/gui/qgssearchquerybuilder.cpp" line="432"/>
@@ -32688,7 +32690,7 @@
     <message>
         <location filename="../src/core/qgsvectorlayer.cpp" line="4317"/>
     </message>
 </context>
 <context>
@@ -32882,13 +32884,13 @@
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1590"/>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1720"/>
         <source>Pie chart</source>
-        <translation type="unfinished">Graf s kružnim isječcima</translation>
+        <translation>Graf s kružnim isječcima</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="716"/>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1551"/>
         <source>Map units</source>
-        <translation type="unfinished">Jedinice mape</translation>
+        <translation>Jedinice mape</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="823"/>
@@ -32991,7 +32993,7 @@
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1516"/>
         <source>Background color</source>
-        <translation type="unfinished">Boja pozadine</translation>
+        <translation>Boja pozadine</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1529"/>
@@ -33017,12 +33019,12 @@
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1569"/>
         <source>Line</source>
-        <translation type="unfinished">Linija</translation>
+        <translation>Linija</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1570"/>
         <source>Horizontal</source>
-        <translation type="unfinished">Horizontalno</translation>
+        <translation>Horizontalno</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1575"/>
@@ -33053,7 +33055,7 @@
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1605"/>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="1610"/>
         <source>None</source>
-        <translation type="unfinished">Nijedan</translation>
+        <translation>Nijedan</translation>
     </message>
     <message>
         <location filename="../src/app/qgsvectorlayerproperties.cpp" line="184"/>
@@ -33177,12 +33179,12 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="694"/>
         <source>Display diagrams</source>
-        <translation type="unfinished">Prikaži dijagrame</translation>
+        <translation>Prikaži dijagrame</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="709"/>
         <source>Diagram type</source>
-        <translation type="unfinished">Tip dijagrama</translation>
+        <translation>Tip dijagrama</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="723"/>
@@ -33192,12 +33194,12 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="730"/>
         <source>Low</source>
-        <translation type="unfinished">Nisko</translation>
+        <translation>Nisko</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="759"/>
         <source>High</source>
-        <translation type="unfinished">Visoko</translation>
+        <translation>Visoko</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="768"/>
@@ -33207,12 +33209,12 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="776"/>
         <source>Scale dependent visibility</source>
-        <translation type="unfinished">Vidljivost ovisna o mjerilu</translation>
+        <translation>Vidljivost ovisna o mjerilu</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="809"/>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="841"/>
@@ -33222,18 +33224,18 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="871"/>
         <source>Pen width</source>
-        <translation type="unfinished">Širina pera </translation>
+        <translation>Širina pera </translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="893"/>
         <source>Font...</source>
-        <translation type="unfinished">Font...</translation>
+        <translation>Font...</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="910"/>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="975"/>
         <source>Size</source>
-        <translation type="unfinished">Veličina</translation>
+        <translation>Veličina</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="916"/>
@@ -33243,33 +33245,33 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="943"/>
         <source>Scale linearly between 0 and the following attribute value / diagram size:</source>
-        <translation type="unfinished">Skaliraj linearno između 0 i slijedeće vrijednosti atributa / veličine dijagrama:</translation>
+        <translation>Skaliraj linearno između 0 i slijedeće vrijednosti atributa / veličine dijagrama:</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="955"/>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1174"/>
         <source>Attribute</source>
-        <translation type="unfinished">Atribut</translation>
+        <translation>Atribut</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="965"/>
         <source>Find maximum value</source>
-        <translation type="unfinished">Pronađi maksimalnu vrijednost</translation>
+        <translation>Pronađi maksimalnu vrijednost</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="993"/>
         <source>Size units</source>
-        <translation type="unfinished">Jedinice veličine</translation>
+        <translation>Jedinice veličine</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1008"/>
         <source>Position</source>
-        <translation type="unfinished">Pozicija</translation>
+        <translation>Pozicija</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1016"/>
         <source>Placement</source>
-        <translation type="unfinished">Postavljanje</translation>
+        <translation>Postavljanje</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1030"/>
@@ -33289,17 +33291,17 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1071"/>
         <source>x</source>
-        <translation type="unfinished">x</translation>
+        <translation>x</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1091"/>
         <source>y</source>
-        <translation type="unfinished">y</translation>
+        <translation>y</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1106"/>
         <source>Attributes</source>
-        <translation type="unfinished">Atributi</translation>
+        <translation>Atributi</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="353"/>
@@ -35084,7 +35086,7 @@
     <message>
         <location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="128"/>
-        <translation type="unfinished">Pomoć</translation>
+        <translation>Pomoć</translation>
     </message>
     <message>
         <location filename="../src/plugins/roadgraph/shortestpathwidget.cpp" line="235"/>
@@ -38209,7 +38211,7 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="173"/>
         <source>Export</source>
-        <translation type="unfinished">Izvoz</translation>
+        <translation>Izvoz</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="174"/>
@@ -38539,7 +38541,7 @@
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="239"/>
         <source>Import</source>
-        <translation type="unfinished">Uvoz</translation>
+        <translation>Uvoz</translation>
     </message>
     <message>
         <location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="240"/>
More information about the QGIS-commit mailing list
