[QGIS Commit] r15607 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 26 02:33:59 EDT 2011
Author: macho
Date: 2011-03-25 23:33:59 -0700 (Fri, 25 Mar 2011)
New Revision: 15607
   trunk/qgis/i18n/qgis_ru.ts
translation update: ru by Artem
Modified: trunk/qgis/i18n/qgis_ru.ts
--- trunk/qgis/i18n/qgis_ru.ts	2011-03-25 22:41:39 UTC (rev 15606)
+++ trunk/qgis/i18n/qgis_ru.ts	2011-03-26 06:33:59 UTC (rev 15607)
@@ -2274,7 +2274,7 @@
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="142"/>
         <source>Slope</source>
-        <translation type="unfinished">Угол уклонов</translation>
+        <translation>Угол уклонов</translation>
     </message>
     <message>
         <location filename="../python/plugins/GdalTools/tools/widgetDEM.ui" line="147"/>
@@ -21642,92 +21642,91 @@
         <translation>Добавляемые на карту слои &amp;видимы по умолчанию</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="743"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="740"/>
         <source>Measure tool</source>
         <translation>Инструмент измерений</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="579"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="576"/>
         <source>Fix problems with incorrectly filled polygons</source>
         <translation>Исправлять ошибки заливки полигонов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="707"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="704"/>
         <source>%</source>
         <translation></translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="868"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="865"/>
         <source>Panning and zooming</source>
         <translation>Прокрутка и масштабирование</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="878"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="875"/>
         <source>Zoom</source>
         <translation>Увеличить</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="883"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="880"/>
         <source>Zoom and recenter</source>
         <translation>Увеличить и центрировать</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="893"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="890"/>
         <source>Nothing</source>
         <translation>Ничего</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1105"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1102"/>
         <source>Default snapping tolerance</source>
         <translation>Порог прилипания по умолчанию</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1122"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1119"/>
         <source>Search radius for vertex edits</source>
         <translation>Радиус поиска для редактирования вершин</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1513"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1510"/>
         <source>Locale</source>
         <translation>Язык</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1543"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1540"/>
         <source>Locale to use instead</source>
         <translation>Язык, используемый вместо системного</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1566"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1563"/>
         <source>Additional Info</source>
         <translation>Дополнительная информация</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1572"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1569"/>
         <source>Detected active locale on your system:</source>
         <translation>Обнаруженный системный язык:</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="576"/>
         <source>Selecting this will unselect the &apos;make lines less&apos; jagged toggle</source>
-        <translation>Активация этого параметра выключит флажок «Рисовать сглаженные линии»</translation>
+        <translation type="obsolete">Активация этого параметра выключит флажок «Рисовать сглаженные линии»</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1036"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1033"/>
         <source>Rubberband</source>
         <translation>Резиновая нить</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1049"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1046"/>
         <source>Line width in pixels</source>
         <translation>Толщина линии в пикселях</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1082"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1079"/>
         <source>Snapping</source>
         <translation>Прилипание</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="888"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="885"/>
         <source>Zoom to mouse cursor</source>
         <translation>Увеличить в положении курсора</translation>
     </message>
@@ -21737,7 +21736,7 @@
         <translation>Параметры</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1015"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1012"/>
         <source>Digitizing</source>
         <translation>Оцифровка</translation>
     </message>
@@ -21887,163 +21886,163 @@
         <translation>Качество отрисовки</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="813"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="810"/>
         <source>Preferred angle units</source>
         <translation>Единицы измерения углов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="820"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="817"/>
         <source>Degrees</source>
         <translation>Градусы</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="827"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="824"/>
         <source>Radians</source>
         <translation>Радианы</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="834"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="831"/>
         <source>Gon</source>
         <translation>Грады</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="841"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="838"/>
         <source>Decimal places</source>
         <translation>Десятичных знаков</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="851"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="848"/>
         <source>Keep base unit</source>
         <translation>Сохранять базовые единицы</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="901"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="898"/>
         <source>Zoom factor</source>
         <translation>Фактор увеличения</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="908"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="905"/>
         <source>Mouse wheel action</source>
         <translation>Действие при прокрутке колеса мыши</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="940"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="937"/>
         <source>Overlays</source>
         <translation>Совмещение</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="967"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="964"/>
         <source>Placement algorithm</source>
         <translation>Алгоритм размещения</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1300"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1297"/>
         <source>Reuse last entered attribute values</source>
         <translation>Использовать последние введённые значения</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1372"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1369"/>
         <source>Default Coordinate Reference System for new projects</source>
         <translation>Система координат для новых проектов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1388"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1385"/>
         <source>Enable &apos;on the &amp;fly&apos; reprojection by default</source>
         <translation>Включить преобразование координат «&amp;на лету»</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1395"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1478"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1392"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1475"/>
         <source>Select...</source>
         <translation>Выбрать...</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1415"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1412"/>
         <source>Always start new projects with this CRS</source>
         <translation>Создавать новые проекты в указанной системе координат</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1434"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1431"/>
         <source>Coordinate Reference System for new layers</source>
         <translation>Система координат для новых слоёв</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1440"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1437"/>
         <source>When a new layer is created, or when a layer is loaded that has no Coordinate Reference System (CRS)</source>
         <translation>При создании нового слоя или загрузке слоя без указанной системы координат</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1604"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1601"/>
         <source>Network</source>
         <translation>Сеть</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1711"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1708"/>
         <source>Exclude URLs (starting with)</source>
         <translation>Не использовать прокси-сервер для следующих адресов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1756"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1753"/>
         <source>Cache settings</source>
         <translation>Параметры кэширования</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1762"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1759"/>
         <source>Directory</source>
         <translation>Каталог</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1772"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1769"/>
         <source>...</source>
         <translation>...</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1779"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1776"/>
         <source>Size</source>
         <translation>Размер кэша</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1789"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1786"/>
         <source>Clear</source>
         <translation>Очистить</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1801"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1798"/>
         <source>WMS search address</source>
         <translation>Адрес поиска WMS-серверов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1815"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1812"/>
         <source>Timeout for network requests (ms)</source>
         <translation>Таймаут для сетевых запросов (мс)</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="759"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="756"/>
         <source>Rubberband color</source>
         <translation>Цвет линии</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="749"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="746"/>
         <source>Ellipsoid for distance calculations</source>
         <translation>Эллипсоид для вычисления расстояний</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="792"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="789"/>
         <source>Preferred measurements units</source>
         <translation>Единицы измерения по умолчанию</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="799"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="796"/>
         <source>Meters</source>
         <translation>Метры</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="806"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="803"/>
         <source>Feet</source>
         <translation>Футы</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="681"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="678"/>
         <source>Identify</source>
         <translation>Инструмент определения</translation>
     </message>
@@ -22053,154 +22052,154 @@
         <translation>Параметры приложения</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="690"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="687"/>
         <source>&lt;b&gt;Note:&lt;/b&gt; Specify the search radius as a percentage of the map width</source>
         <translation>&lt;b&gt;Внимание:&lt;/b&gt; радиус поиска задаётся в процентах от ширины видимой карты</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="700"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="697"/>
         <source>Search radius for identifying features and displaying map tips</source>
         <translation>Радиус поиска для определения объектов и всплывающих описаний</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="726"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="723"/>
         <source>Mode</source>
         <translation>Режим определения</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1042"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1039"/>
         <source>Line width</source>
         <translation>Толщина линии</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1088"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1085"/>
         <source>Default snap mode</source>
         <translation>Режим прилипания по умолчанию</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1215"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1212"/>
         <source>Vertex markers</source>
         <translation>Маркеры вершин</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1221"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1218"/>
         <source>Show markers only for selected features</source>
         <translation>Показывать маркеры только для выбранных объектов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1228"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1225"/>
         <source>Marker style</source>
         <translation>Стиль маркера</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1271"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1268"/>
         <source>Marker size</source>
         <translation>Размер маркера</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1534"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1531"/>
         <source>Override system locale</source>
         <translation>Переопределить системный язык</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1553"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1550"/>
         <source>&lt;b&gt;Note:&lt;/b&gt; Enabling / changing overide on local requires an application restart</source>
         <translation>&lt;b&gt;Внимание:&lt;/b&gt; для переопределения параметров языка необходимо перезапустить приложение</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1625"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1622"/>
         <source>Use proxy for web access</source>
         <translation>Использовать прокси-сервер для внешних соединений</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1637"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1634"/>
         <source>Host</source>
         <translation>Узел</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1647"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1644"/>
         <source>Port</source>
         <translation>Порт</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1657"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1654"/>
         <source>User</source>
         <translation>Пользователь</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1664"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1678"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1661"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1675"/>
         <source>Leave this blank if no proxy username / password are required</source>
         <translation>Оставьте это поле пустым, если для прокси-сервера не требуется имя пользователя и пароль</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1671"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1668"/>
         <source>Password</source>
         <translation>Пароль</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1345"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1342"/>
         <source>CRS</source>
         <translation>Система координат</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1294"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1291"/>
         <source>Enter attribute values</source>
         <translation>Ввод значений атрибутов</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1310"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1307"/>
         <source>Suppress attributes pop-up windows after each created feature</source>
         <translation>Отключить всплывающее окно ввода атрибутов для каждого создаваемого объекта</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1450"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1447"/>
         <source>Prompt for &amp;CRS</source>
         <translation>&amp;Запрашивать систему координат</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1457"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1454"/>
         <source>Use &amp;project CRS</source>
         <translation>&amp;Использовать систему координат проекта</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1464"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1461"/>
         <source>Use default CRS displa&amp;yed below</source>
         <translation>Использовать &amp;нижеприведённую систему координат по умолчанию</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1688"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1685"/>
         <source>Proxy type</source>
         <translation>Тип прокси</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="457"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="631"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1727"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="628"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1724"/>
         <source>Add</source>
         <translation>Добавить</translation>
     </message>
     <message>
         <location filename="../src/ui/qgsoptionsbase.ui" line="464"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="638"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1720"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="635"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1717"/>
         <source>Remove</source>
         <translation>Удалить</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="961"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="958"/>
         <source>Position</source>
         <translation>Позиционирование</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1146"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1160"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1143"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1157"/>
         <source>map units</source>
         <translation>единиц карты</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1151"/>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1165"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1148"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1162"/>
         <source>pixels</source>
         <translation>пикселей</translation>
     </message>
@@ -22210,32 +22209,32 @@
         <translation>Использовать кэш для ускорения перерисовки, там где это возможно</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="605"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="602"/>
         <source>SVG paths</source>
         <translation>Значки в формате SVG</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="611"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="608"/>
         <source>Path(s) to search for Scalable Vector Graphic (SVG) symbols</source>
         <translation>Пути поиска значков в формате SVG</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="589"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="586"/>
         <source>Compatibility</source>
         <translation>Совместимость</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="595"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="592"/>
         <source>Use new generation symbology for rendering</source>
         <translation>Использовать новую реализацию отрисовки условных знаков</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="733"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="730"/>
         <source>Open feature form, if a single feature is identified</source>
         <translation>Открывать форму, если найден один объект</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="1059"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="1056"/>
         <source>Line color</source>
     </message>
@@ -22245,7 +22244,7 @@
         <translation>Общие</translation>
     </message>
     <message>
-        <location filename="../src/ui/qgsoptionsbase.ui" line="660"/>
+        <location filename="../src/ui/qgsoptionsbase.ui" line="657"/>
         <source>Map tools</source>
         <translation>Инструменты</translation>
     </message>
@@ -30814,7 +30813,7 @@
     <message>
         <location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="1053"/>
         <source>Data defined position</source>
-        <translation type="unfinished">Данные положения</translation>
+        <translation>Данные положения</translation>
     </message>
 </context>
 <context>
More information about the QGIS-commit mailing list
