[QGIS Commit] r15614 - trunk/qgis/src/providers/delimitedtext
svn_qgis at osgeo.org
Sun Mar 27 11:39:17 EDT 2011
Author: jef
Date: 2011-03-27 08:39:17 -0700 (Sun, 27 Mar 2011)
New Revision: 15614
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
fix #3682
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2011-03-27 14:09:00 UTC (rev 15613)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2011-03-27 15:39:17 UTC (rev 15614)
@@ -134,7 +134,6 @@
, mDelimiter( "," )
, mDelimiterRegexp()
, mDelimiterType( "plain" )
- , mHasWktField( false )
, mFieldCount( 0 )
, mXFieldIndex( -1 )
, mYFieldIndex( -1 )
@@ -146,18 +145,16 @@
, mFirstDataLine( 0 )
, mShowInvalidLines( true )
, mCrs()
- , mWkbType( QGis::WKBNoGeometry )
+ , mWkbType( QGis::WKBUnknown )
QUrl url = QUrl::fromEncoded( uri.toAscii() );
// Extract the provider definition from the url
mFileName = url.toLocalFile();
- QString wktField( "" );
- QString xField( "" );
- QString yField( "" );
+ QString wktField;
+ QString xField;
+ QString yField;
if ( url.hasQueryItem( "delimiter" ) ) mDelimiter = url.queryItemValue( "delimiter" );
if ( url.hasQueryItem( "delimiterType" ) ) mDelimiterType = url.queryItemValue( "delimiterType" );
@@ -167,13 +164,11 @@
if ( url.hasQueryItem( "skipLines" ) ) mSkipLines = url.queryItemValue( "skipLines" ).toInt();
if ( url.hasQueryItem( "crs" ) ) mCrs.createFromString( url.queryItemValue( "crs" ) );
- mHasWktField = wktField != "";
QgsDebugMsg( "Data source uri is " + uri );
QgsDebugMsg( "Delimited text file is: " + mFileName );
QgsDebugMsg( "Delimiter is: " + mDelimiter );
QgsDebugMsg( "Delimiter type is: " + mDelimiterType );
- QgsDebugMsg( "wktField is: " + xField );
+ QgsDebugMsg( "wktField is: " + wktField );
QgsDebugMsg( "xField is: " + xField );
QgsDebugMsg( "yField is: " + yField );
QgsDebugMsg( "skipLines is: " + QString::number( mSkipLines ) );
@@ -251,45 +246,54 @@
for ( int column = 0; column < mFieldCount; column++ )
QString field = fieldList[column];
- if ( field.length() > 0 )
- // check to see if this field matches either the x or y field
- if ( wktField == field )
- QgsDebugMsg( "Found wkt field: " + ( field ) );
- mWktFieldIndex = column;
- else if ( xField == field )
- QgsDebugMsg( "Found x field: " + ( field ) );
- mXFieldIndex = column;
- else if ( yField == field )
- QgsDebugMsg( "Found y field: " + ( field ) );
- mYFieldIndex = column;
+ if (( field.left( 1 ) == "'" || field.left( 1 ) == "\"" ) &&
+ field.left( 1 ) == field.right( 1 ) )
+ // eat quotes
+ field = field.mid( 1, field.length() - 2 );
- // WKT geometry field won't be displayed in attribute tables
- if ( column == mWktFieldIndex )
- continue;
+ if ( field.length() == 0 )
+ // skip empty field names
+ continue;
- QgsDebugMsg( "Adding field: " + ( field ) );
- // assume that the field could be integer or double
- // for now, let's set field type as text
- attributeColumns.append( column );
- attributeFields[fieldPos] = QgsField( field, QVariant::String, "Text" );
- couldBeInt.insert( fieldPos, true );
- couldBeDouble.insert( fieldPos, true );
- fieldPos++;
+ // check to see if this field matches either the x or y field
+ if ( !wktField.isEmpty() && wktField == field )
+ QgsDebugMsg( "Found wkt field: " + ( field ) );
+ mWktFieldIndex = column;
+ else if ( !xField.isEmpty() && xField == field )
+ QgsDebugMsg( "Found x field: " + ( field ) );
+ mXFieldIndex = column;
+ else if ( !yField.isEmpty() && yField == field )
+ QgsDebugMsg( "Found y field: " + ( field ) );
+ mYFieldIndex = column;
+ // WKT geometry field won't be displayed in attribute tables
+ if ( column == mWktFieldIndex )
+ continue;
+ QgsDebugMsg( "Adding field: " + ( field ) );
+ // assume that the field could be integer or double
+ // for now, let's set field type as text
+ attributeColumns.append( column );
+ attributeFields[fieldPos] = QgsField( field, QVariant::String, "Text" );
+ couldBeInt.insert( fieldPos, true );
+ couldBeDouble.insert( fieldPos, true );
+ fieldPos++;
if ( mWktFieldIndex >= 0 )
mXFieldIndex = -1;
mYFieldIndex = -1;
+ QgsDebugMsg( "wktfield index: " + QString::number( mWktFieldIndex ) );
+ QgsDebugMsg( "xfield index: " + QString::number( mXFieldIndex ) );
+ QgsDebugMsg( "yfield index: " + QString::number( mYFieldIndex ) );
QgsDebugMsg( "Field count for the delimited text file is " + QString::number( attributeFields.size() ) );
hasFields = true;
@@ -304,9 +308,9 @@
// Ensure that the input has at least the required number of fields (mainly to tolerate
// missed blank strings at end of row)
while ( parts.size() < mFieldCount )
- parts.append( "" );
+ parts.append( QString::null );
- if ( mHasWktField && mWktFieldIndex >= 0 )
+ if ( mWktFieldIndex >= 0 )
// Get the wkt - confirm it is valid, get the type, and
// if compatible with the rest of file, add to the extents
@@ -325,6 +329,7 @@
catch ( ... )
+ mInvalidLines << line;
geom = 0;
@@ -349,7 +354,7 @@
delete geom;
- else if ( !mHasWktField && mXFieldIndex >= 0 && mYFieldIndex >= 0 )
+ else if ( mWktFieldIndex == -1 && mXFieldIndex >= 0 && mYFieldIndex >= 0 )
// Get the x and y values, first checking to make sure they
// aren't null.
@@ -357,8 +362,8 @@
QString sX = parts[mXFieldIndex];
QString sY = parts[mYFieldIndex];
- bool xOk = true;
- bool yOk = true;
+ bool xOk = false;
+ bool yOk = false;
double x = sX.toDouble( &xOk );
double y = sY.toDouble( &yOk );
@@ -376,7 +381,16 @@
mNumberFeatures++;
+ else
+ else
+ mWkbType = QGis::WKBNoGeometry;
+ mNumberFeatures++;
for ( int i = 0; i < attributeFields.size(); i++ )
@@ -396,6 +410,9 @@
+ QgsDebugMsg( "geometry type is: " + QString::number( mWkbType ) );
+ QgsDebugMsg( "feature count is: " + QString::number( mNumberFeatures ) );
// now it's time to decide the types for the fields
for ( QgsFieldMap::iterator it = attributeFields.begin(); it != attributeFields.end(); ++it )
@@ -411,7 +428,7 @@
- mValid = true;
+ mValid = mWkbType != QGis::WKBUnknown;
QgsDelimitedTextProvider::~QgsDelimitedTextProvider()
@@ -443,11 +460,11 @@
QStringList tokens = splitLine( line );
while ( tokens.size() < mFieldCount )
- tokens.append( "" );
+ tokens.append( QString::null );
QgsGeometry *geom = 0;
try
@@ -478,7 +495,7 @@
geom = 0;
+ else if ( mXFieldIndex >= 0 && mYFieldIndex >= 0 )
bool xOk, yOk;
double x = tokens[mXFieldIndex].toDouble( &xOk );
@@ -493,10 +510,11 @@
- // If no valid geometry skip to the next line
- if ( !geom )
+ if ( !geom && mWkbType != QGis::WKBNoGeometry )
continue;
// At this point the current feature values are valid
@@ -504,7 +522,8 @@
feature.setFeatureId( mFid );
- feature.setGeometry( geom );
+ if ( geom )
+ feature.setGeometry( geom );
for ( QgsAttributeList::const_iterator i = mAttributesToFetch.begin();
i != mAttributesToFetch.end();
