[QGIS Commit] r15644 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Wed Mar 30 14:53:03 EDT 2011
Author: sholl
Date: 2011-03-30 11:53:03 -0700 (Wed, 30 Mar 2011)
New Revision: 15644
docs/trunk/english_us/user_guide/qgis_mapserver.tex
docs/trunk/english_us/user_guide/working_with_ogc.tex
QGIS-Mapserver-part ripped off from working_with_ogc.tex and stuffed into qgis_mapserver.tex
Modified: docs/trunk/english_us/user_guide/qgis_mapserver.tex
--- docs/trunk/english_us/user_guide/qgis_mapserver.tex 2011-03-30 14:43:18 UTC (rev 15643)
+++ docs/trunk/english_us/user_guide/qgis_mapserver.tex 2011-03-30 18:53:03 UTC (rev 15644)
@@ -1,11 +1,42 @@
% !TeX root = user_guide.tex
\chapter{QGIS Mapserver}\label{label_qgismapserver}
+\index{WMS!QGISmapserver}
% when the revision of a section has been finalized,
% comment out the following line:
-% \updatedisclaimer
+\updatedisclaimer
-Please add text here...
+% Ripped off working_with_ogc.tex (SH: 20110330)
+QGIS mapserver is an open source WMS 1.3 implementation which, in addition,
+implements advanced cartographic features for thematic mapping. The QGIS
+mapserver is a FastCGI/CGI (Common Gateway Interface) application written in
+C++ that works together with a webserver (e.g. Apache, Lighttpd).
+It uses QGIS as backend for the GIS logic and for map rendering. Furthermore the
+Qt library is used for graphics and for platform independent
+C++ programming. In contrast to other WMS software, the QGIS mapserver uses
+cartographic rules in SLD/SE as a configuration language, both for the server
+configuration and for the user-defined cartographic rules.
+Moreover, the QGIS mapserver project provides the “Publish to Web” plugin, a
+plugin for QGIS desktop which exports the current layers and symbology as a
+web project for QGIS mapserver (containing cartographic visualisation rules
+expressed in SLD).
+As QGIS desktop and QGIS mapserver use the same visualization libraries, the
+maps that are published on the web look the same as in desktop GIS. The
+Publish to Web plugin currently supports basic symbolization, with more complex
+cartographic visualisation rules introduced manually. As the configuration is
+performed with the SLD standard and its documented extensions, there is only
+one standardised language to learn, which greatly simplifies the complexity
+of creating maps for the Web.
+Further information is available at: \\
+\url{http://karlinapp.ethz.ch/qgis\_wms/} \\
+\url{http://www.qgis.org/wiki/QGIS\_mapserver\_tutorial} \\
+\url{http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/}
\FloatBarrier
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2011-03-30 14:43:18 UTC (rev 15643)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2011-03-30 18:53:03 UTC (rev 15644)
@@ -449,46 +449,15 @@
\index{WMS!secured layers!}\index{OGC!Authentication}
\end{Tip}
+\begin{Tip}[ht]\caption{\textsc{QGIS WMS Mapserver}}
+Note that with the Version 1.7.0 QGIS brings its own implementation of a
+WMS 1.3.0 Mapserver. Read more about this at chapter
+\ref{label_qgismapserver}.
+\index{WMS!QGISmapserver}\index{OGC!WMS1.3.0}
+\end{Tip}
-% WMS-server
-\section{WMS Server}\label{sec:ogc-wmsserver}
-\index{WMS!server}
-QGIS mapserver is an open source WMS 1.3 implementation which, in addition,
-implements advanced cartographic features for thematic mapping. The QGIS
-mapserver is a FastCGI/CGI (Common Gateway Interface) application written in
-C++ that works together with a webserver (e.g. Apache, Lighttpd).
-It uses QGIS as backend for the GIS logic and for map rendering. Furthermore the
-Qt library is used for graphics and for platform independent
-C++ programming. In contrast to other WMS software, the QGIS mapserver uses
-cartographic rules in SLD/SE as a configuration language, both for the server
-configuration and for the user-defined cartographic rules.
-Moreover, the QGIS mapserver project provides the “Publish to Web” plugin, a
-plugin for QGIS desktop which exports the current layers and symbology as a
-web project for QGIS mapserver (containing cartographic visualisation rules
-expressed in SLD).
-As QGIS desktop and QGIS mapserver use the same visualization libraries, the
-maps that are published on the web look the same as in desktop GIS. The
-Publish to Web plugin currently supports basic symbolization, with more complex
-cartographic visualisation rules introduced manually. As the configuration is
-performed with the SLD standard and its documented extensions, there is only
-one standardised language to learn, which greatly simplifies the complexity
-of creating maps for the Web.
-Further information is available at: \\
-\url{http://karlinapp.ethz.ch/qgis\_wms/} \\
-\url{http://www.qgis.org/wiki/QGIS\_mapserver\_tutorial} \\
-\url{http://linfiniti.com/2010/08/qgis-mapserver-a-wms-server-for-the-masses/}
% WFS-client
