[QGIS Commit] [qgis/Quantum-GIS] f7a3af: Fix and update to Freeze/Thaw, Move, and Rotate La...
GitHub
noreply at github.com
Thu Aug 2 00:09:08 PDT 2012
Branch: refs/heads/master
Home: https://github.com/qgis/Quantum-GIS
Commit: f7a3af36733891ac84281e562d5505ce32c69f6f
https://github.com/qgis/Quantum-GIS/commit/f7a3af36733891ac84281e562d5505ce32c69f6f
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2012-08-02 (Thu, 02 Aug 2012)
Changed paths:
M src/app/qgsmaptoolfreezelabels.cpp
M src/app/qgsmaptoollabel.cpp
M src/app/qgsmaptoollabel.h
M src/app/qgsmaptoolmovelabel.cpp
M src/app/qgsmaptoolrotatelabel.cpp
M src/app/qgsmaptoolrotatelabel.h
M src/core/qgspallabeling.cpp
M src/ui/qgisapp.ui
Log Message:
Fix and update to Freeze/Thaw, Move, and Rotate Label tools
Updates
- Move tool now preserves calculated x, y offset for upside-down labels, when initially moved and data-defined fields have no previous data.
- Move tool now stores the label's PAL solution for rotation on initial move, if rotation is data-defined with no previous data.
- Freeze/Thaw and Move tools now support all variations of previously data-defined halign and valign options on initial freeze.
- Freeze/Thaw tool has updated key modifiers that should work across major platforms.
- Tests for whether layer labels support data-defined rotation moved to base QgsMapToolLabel class.
Fixes
- Fix bug where labels defined in map units causing font to show as pointsize of same integer at small map scales.
- Half of a fix for rotation point of labels with data-defined size of map units actually being based off of point size.
(still references the layer-defined font size somewhere in the rotation point calculation)
- Valign settings of Base and Half now more accurately key off of inverse of font ascent (instead of descent). No discernible shift occurs now on initial freeze.
