[QGIS Commit] [qgis/Quantum-GIS] 07e3c1: Fix Mac path to resources and grass and sqlanywher...
GitHub
noreply at github.com
Fri Aug 17 14:49:40 PDT 2012
Branch: refs/heads/master
Home: https://github.com/qgis/Quantum-GIS
Commit: 07e3c16c634866eb8186cc156f74771cf057fe86
https://github.com/qgis/Quantum-GIS/commit/07e3c16c634866eb8186cc156f74771cf057fe86
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2012-08-17 (Fri, 17 Aug 2012)
Changed paths:
M CMakeLists.txt
M tests/CMakeLists.txt
Log Message:
Fix Mac path to resources and grass and sqlanywhere provider frameworks for tests
- Any test needing access to QGIS_DATA_SUBDIR (srs.db, svg, etc.) was looking for Resources in the bundled app instead
- This included failure for any call to qgscoordinatereferencesystem.cpp using srs.db and when locating svg icons
- Does not fix QGIS_DATA_SUBDIR in Python tests
- Subtests that were failing, as above, within a given test are still not triggering a fail for the test
- Symlink to grass and sqlanywhere frameworks created just for testing
