[QGIS Commit] [qgis/Quantum-GIS] 6055c1: android goodies (pull
request #94):
GitHub
noreply at github.com
Wed Feb 8 16:27:56 EST 2012
Branch: refs/heads/master
Home: https://github.com/qgis/Quantum-GIS
Commit: 6055c11fe4e04b4e719a9d58a80c20677ffb488b
https://github.com/qgis/Quantum-GIS/commit/6055c11fe4e04b4e719a9d58a80c20677ffb488b
Author: Marco Bernasocchi <marco at bernawebdesign.ch>
Date: 2012-02-08 (Wed, 08 Feb 2012)
Changed paths:
M CMakeLists.txt
A cmake/FindQtMobility.cmake
M src/app/gps/qgsgpsinformationwidget.cpp
M src/core/CMakeLists.txt
M src/core/gps/qgsgpsconnection.cpp
M src/core/gps/qgsgpsconnection.h
M src/core/gps/qgsgpsdetector.cpp
A src/core/gps/qgsqtlocationconnection.cpp
A src/core/gps/qgsqtlocationconnection.h
M src/plugins/CMakeLists.txt
A src/plugins/compass/CMakeLists.txt
A src/plugins/compass/compass.cpp
A src/plugins/compass/compass.h
A src/plugins/compass/compass.qrc
A src/plugins/compass/icons/mCompassRun.png
A src/plugins/compass/qgscompassplugin.cpp
A src/plugins/compass/qgscompassplugin.h
A src/plugins/compass/qgscompassplugingui.cpp
A src/plugins/compass/qgscompassplugingui.h
A src/plugins/compass/qgscompasspluginguibase.ui
M src/ui/qgsgpsinformationwidgetbase.ui
M src/ui/qgsrasterlayerpropertiesbase.ui
M src/ui/qgsvectorlayerpropertiesbase.ui
Log Message:
android goodies (pull request #94):
[Marco Bernasocchi]
- adding needed files to support internal GPS via QtMobility, implementation of QgsQtLocationConnection is only a stub
- cleaning up methods names
- adding mobility to CMakeLists
- testing
- added hack to test parseData()
- adding more parsing stuff
- Adding debugging info and making connection fail if no QtSatellite datasource available
- Initial working GPS with coordinates bug (values shifted)
- Adding Initial GPS support to android using QtLocation
- Adding Ground speed and direction
- put ok button on top of widget to make it usable until scroll area is added (HACK to be Reverted later)
- added vertical and horizontal accurancy
- Removing test values qtlocationconnection
- refactor debug messages
- adding compass plugin
- trying NathanW suggestion
- adding new compass plugin
- Fixed satellitesUpdated signals
- removing setDataRate
- temporarely removed calibrationLevel display to be reverted when https://sourceforge.net/p/necessitas/tickets/153/ is fixed
- addin comment
- making QLineEdits readonly
- added calibration level support
[Jürgen E. Fischer]
- squashed, reindented and skipped some already addressed changes to qgisapp and vector layer provider
