[QGIS Commit] [qgis/Quantum-GIS] 3df1c4: Fix to get unit tests working again on Mac.
GitHub
noreply at github.com
Thu Jun 21 03:29:13 PDT 2012
Branch: refs/heads/master
Home: https://github.com/qgis/Quantum-GIS
Commit: 3df1c4e668fc7535c988493f956e48c682a77496
https://github.com/qgis/Quantum-GIS/commit/3df1c4e668fc7535c988493f956e48c682a77496
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2012-06-21 (Thu, 21 Jun 2012)
Changed paths:
M CMakeLists.txt
Log Message:
make 'check', 'test' and 'Experimental' work from build directory to run tests.
Current caveats:
- Build will not install. Re-build with ENABLE_TESTS=FALSE to produce a build a functioning bundled .app.
- Temp QGIS.app in build/output/bin directory will start, but also needs a different symlink for finding providers. Even then, the app doesn' work right. It appears to be unnecessary for running tests, so there is no advantage to running it from the build directory.
Commit: 9dc561dcb25b2d5c528ab777b162d731682379d5
https://github.com/qgis/Quantum-GIS/commit/9dc561dcb25b2d5c528ab777b162d731682379d5
Author: Tim Sutton <tim at linfiniti.com>
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #182 from dakcarto/fix-unittests-mac
Compare: https://github.com/qgis/Quantum-GIS/compare/fcb86cf513d0...9dc561dcb25b
