[QGIS Commit] [qgis/QGIS] 6dad30: [FEATURE]: Start implementation of native dxf expo...
GitHub noreply at github.com
Fri Dec 6 08:47:08 PST 2013
  Branch: refs/heads/master
  Home:   https://github.com/qgis/QGIS
  Commit: 6dad30c2662ffebb99c254e1207e8bc90e852468
      https://github.com/qgis/QGIS/commit/6dad30c2662ffebb99c254e1207e8bc90e852468
  Author: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
  Date:   2013-09-13 (Fri, 13 Sep 2013)
  Changed paths:
    M python/core/core.sip
    A python/core/qgsdxfexport.sip
    M src/core/CMakeLists.txt
    A src/core/qgsdxfexport.cpp
    A src/core/qgsdxfexport.h
  Log Message:
  [FEATURE]: Start implementation of native dxf export
  Commit: edc3b5ffaf67a879a39d01046d047edede316e57
      https://github.com/qgis/QGIS/commit/edc3b5ffaf67a879a39d01046d047edede316e57
  Changed paths:
    M src/core/qgsdxfexport.cpp
    M src/core/qgsdxfexport.h
  Log Message:
  Write dxf header and eof
  Commit: ddee21c0e39649f6fc51cf060ea0d51899364ecc
      https://github.com/qgis/QGIS/commit/ddee21c0e39649f6fc51cf060ea0d51899364ecc
  Changed paths:
  Log Message:
  First implementation of dxf feature writing (but it does not work yet)
  Commit: 06e933926d24e9265ab78a5b1411ff4d6c726fe8
      https://github.com/qgis/QGIS/commit/06e933926d24e9265ab78a5b1411ff4d6c726fe8
  Date:   2013-09-14 (Sat, 14 Sep 2013)
  Changed paths:
  Log Message:
  Write additional header field and table section
  Commit: 32221fdc3277d00bfdd856bcc1bb92846301b065
      https://github.com/qgis/QGIS/commit/32221fdc3277d00bfdd856bcc1bb92846301b065
  Date:   2013-09-15 (Sun, 15 Sep 2013)
  Changed paths:
  Log Message:
  Dxf: add more header fields, min/max extent and a test linestyle
  Commit: dc62376fd2e25b7dceaf511077f699053492e5f1
      https://github.com/qgis/QGIS/commit/dc62376fd2e25b7dceaf511077f699053492e5f1
  Changed paths:
  Log Message:
  More symbology updates for dxf
  Commit: 93122767e4e55e2dd3d943cbad7c07ed853e989a
      https://github.com/qgis/QGIS/commit/93122767e4e55e2dd3d943cbad7c07ed853e989a
  Date:   2013-09-16 (Mon, 16 Sep 2013)
  Changed paths:
  Log Message:
  Prepare color palette matching for dxf
  Commit: 523f1e1ca42fa193f2768310770092d932c7e546
      https://github.com/qgis/QGIS/commit/523f1e1ca42fa193f2768310770092d932c7e546
  Date:   2013-10-29 (Tue, 29 Oct 2013)
  Changed paths:
  Log Message:
  Fix TABLE sections
  Commit: f98ecf753fca68d81cd389a5a96cf2c7c3fb2bcf
      https://github.com/qgis/QGIS/commit/f98ecf753fca68d81cd389a5a96cf2c7c3fb2bcf
  Date:   2013-10-31 (Thu, 31 Oct 2013)
  Changed paths:
  Log Message:
  Dxf color palette
  Commit: eee9a4976dd39f5649559f73ec3bbaf44fd6ca67
      https://github.com/qgis/QGIS/commit/eee9a4976dd39f5649559f73ec3bbaf44fd6ca67
  Date:   2013-11-03 (Sun, 03 Nov 2013)
  Changed paths:
  Log Message:
  Try to find closest color in dxf palette
  Commit: d131b7ae77300d73c9717430357908007f71a5bf
      https://github.com/qgis/QGIS/commit/d131b7ae77300d73c9717430357908007f71a5bf
  Date:   2013-11-04 (Mon, 04 Nov 2013)
  Changed paths:
  Log Message:
  Support multilines / polygons / multipolygons (as closed linestrings for now)
  Commit: 446b6d632f1be00fcd2882048beb73a21e0e0c86
      https://github.com/qgis/QGIS/commit/446b6d632f1be00fcd2882048beb73a21e0e0c86
  Date:   2013-11-05 (Tue, 05 Nov 2013)
  Changed paths:
    M src/app/CMakeLists.txt
    M src/app/qgisapp.cpp
    M src/app/qgisapp.h
    A src/app/qgsdxfexportdialog.cpp
    A src/app/qgsdxfexportdialog.h
    M src/ui/qgisapp.ui
    A src/ui/qgsdxfexportdialogbase.ui
  Log Message:
  Add dxf export gui and menu entry in qgisapp
  Commit: 705ccf50c2fbe7e2bbbb276178244638386c11cb
      https://github.com/qgis/QGIS/commit/705ccf50c2fbe7e2bbbb276178244638386c11cb
  Date:   2013-11-06 (Wed, 06 Nov 2013)
  Changed paths:
  Log Message:
  Implement line width and symbol level support
  Commit: 4984ad6de9ac0f32cf3fe1d0a217a568d4e019a4
      https://github.com/qgis/QGIS/commit/4984ad6de9ac0f32cf3fe1d0a217a568d4e019a4
  Date:   2013-11-08 (Fri, 08 Nov 2013)
  Changed paths:
  Log Message:
  Use linetype 1 for polygons, check if iodevice is already open
  Commit: ae2b72b8f64bc8fa22173bf9de4691ed6ab36a4f
      https://github.com/qgis/QGIS/commit/ae2b72b8f64bc8fa22173bf9de4691ed6ab36a4f
  Changed paths:
  Log Message:
  Write linetypes for simple line with custom dash pattern
  Commit: 608b3ffeed3d423aa94b1d716a9f4f29819a4653
      https://github.com/qgis/QGIS/commit/608b3ffeed3d423aa94b1d716a9f4f29819a4653
  Date:   2013-11-11 (Mon, 11 Nov 2013)
  Changed paths:
  Log Message:
  Fix bug in linestyle export
  Commit: 421c030c27186b08faf41df9159b5681a945ffa6
      https://github.com/qgis/QGIS/commit/421c030c27186b08faf41df9159b5681a945ffa6
  Date:   2013-11-13 (Wed, 13 Nov 2013)
  Changed paths:
  Log Message:
  Move dxf dash writing into separated function
  Commit: 09103b58f0534e4c9cf3ed0ce502e545ef5e2378
      https://github.com/qgis/QGIS/commit/09103b58f0534e4c9cf3ed0ce502e545ef5e2378
  Changed paths:
  Log Message:
  First attempt to write AC1018
  Commit: e97db8c55cb16311f314ed36e5002a911090c219
      https://github.com/qgis/QGIS/commit/e97db8c55cb16311f314ed36e5002a911090c219
  Date:   2013-11-14 (Thu, 14 Nov 2013)
  Changed paths:
  Log Message:
  Use AC1009 only
  Commit: d5cfe23e5a3ff6edf4537915a7415e09b8d7641f
      https://github.com/qgis/QGIS/commit/d5cfe23e5a3ff6edf4537915a7415e09b8d7641f
  Date:   2013-11-20 (Wed, 20 Nov 2013)
  Changed paths:
    M src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
    M src/core/symbology-ng/qgsmarkersymbollayerv2.h
    M src/core/symbology-ng/qgssymbollayerv2.h
  Log Message:
  Write blocks for point symbols
  Commit: de6f83e08f662520eba67f9385bb97596d32f76f
      https://github.com/qgis/QGIS/commit/de6f83e08f662520eba67f9385bb97596d32f76f
  Date:   2013-11-21 (Thu, 21 Nov 2013)
  Changed paths:
    M src/ui/qgsdxfexportdialogbase.ui
  Log Message:
  Clean up dxf export sources
  Commit: 222946b36a63b573713a748288ea36f7f8565afc
      https://github.com/qgis/QGIS/commit/222946b36a63b573713a748288ea36f7f8565afc
  Changed paths:
  Log Message:
  Implement simple marker rect / square
  Commit: 5bd70838823c36e09e0b6b5dab184654a1b0e1d7
      https://github.com/qgis/QGIS/commit/5bd70838823c36e09e0b6b5dab184654a1b0e1d7
  Changed paths:
  Log Message:
  Implement diamond simple marker
  Commit: 78fbee39dbc3b818456ad9ecafb5e01c1919a5c8
      https://github.com/qgis/QGIS/commit/78fbee39dbc3b818456ad9ecafb5e01c1919a5c8
  Date:   2013-11-22 (Fri, 22 Nov 2013)
  Changed paths:
    A src/core/dxf/qgsdxfpaintdevice.cpp
    A src/core/dxf/qgsdxfpaintdevice.h
    A src/core/dxf/qgsdxfpaintengine.cpp
    A src/core/dxf/qgsdxfpaintengine.h
  Log Message:
  Start implementation of QgsDxfPaintDevice / Engine to export svg markers to dxf
  Commit: 34e1bd23775f8cb5ac26d31d67bfaa246f7fd41f
      https://github.com/qgis/QGIS/commit/34e1bd23775f8cb5ac26d31d67bfaa246f7fd41f
  Date:   2013-11-23 (Sat, 23 Nov 2013)
  Changed paths:
    A src/core/dxf/qgsdxfexport.cpp
    A src/core/dxf/qgsdxfexport.h
    R src/core/qgsdxfexport.cpp
    R src/core/qgsdxfexport.h
  Log Message:
  Move QgsDxfExport into dxf subdirectory
  Commit: a9d92cdcf47de6c669683bcd3688c0fc52ec10e2
      https://github.com/qgis/QGIS/commit/a9d92cdcf47de6c669683bcd3688c0fc52ec10e2
  Changed paths:
    M src/core/dxf/qgsdxfpaintdevice.cpp
    M src/core/dxf/qgsdxfpaintdevice.h
    M src/core/dxf/qgsdxfpaintengine.cpp
  Log Message:
  Convert painterpath to polygons for dxf
  Commit: 78672056bcff201ca121af98338cf6e00d00b0d3
      https://github.com/qgis/QGIS/commit/78672056bcff201ca121af98338cf6e00d00b0d3
  Changed paths:
  Log Message:
  Merge branch 'dxf_export' of github.com:mhugent/Quantum-GIS into dxf_export
  Commit: a10d67545a1ab1e0dad719f0f15ce8063026f749
      https://github.com/qgis/QGIS/commit/a10d67545a1ab1e0dad719f0f15ce8063026f749
  Date:   2013-11-25 (Mon, 25 Nov 2013)
  Changed paths:
    M src/core/dxf/qgsdxfexport.cpp
    M src/core/dxf/qgsdxfexport.h
    M src/core/dxf/qgsdxfpaintengine.h
  Log Message:
  Cleanup code structure, move code to central functions
  Commit: 9abba4021a87ee5523da836e1781b6197c34e36f
      https://github.com/qgis/QGIS/commit/9abba4021a87ee5523da836e1781b6197c34e36f
  Changed paths:
  Log Message:
  Implement write lines in dxf engine
  Commit: fa509b80e03b35a8e4638f3484331ec73a75d80a
      https://github.com/qgis/QGIS/commit/fa509b80e03b35a8e4638f3484331ec73a75d80a
  Date:   2013-11-26 (Tue, 26 Nov 2013)
  Changed paths:
    M src/core/symbology-ng/qgssymbollayerv2.cpp
  Log Message:
  Change symbol layer dxf method signature and make first test with a data defined property
  Commit: bcad16d552b89fc64b6378e30808464379e091af
      https://github.com/qgis/QGIS/commit/bcad16d552b89fc64b6378e30808464379e091af
  Date:   2013-11-29 (Fri, 29 Nov 2013)
  Changed paths:
  Log Message:
  Data defined size / color / rotation for marker export
  Commit: 14de6e6ddee53bc309de1ce383a1b048cb3b3c41
      https://github.com/qgis/QGIS/commit/14de6e6ddee53bc309de1ce383a1b048cb3b3c41
  Changed paths:
    M src/app/qgsdxfexportdialog.cpp
    M src/app/qgsdxfexportdialog.h
  Log Message:
  Export layers to dxf in drawing order
  Commit: ef3eee2daa9f568f6a10163a6a31c42d33c321f4
      https://github.com/qgis/QGIS/commit/ef3eee2daa9f568f6a10163a6a31c42d33c321f4
  Date:   2013-12-05 (Thu, 05 Dec 2013)
  Changed paths:
  Log Message:
  Linestyles for Qt pen styles
  Commit: 3fed0d0755a518395d136b6a608e89cda557de2d
      https://github.com/qgis/QGIS/commit/3fed0d0755a518395d136b6a608e89cda557de2d
  Changed paths:
  Log Message:
  Fix rotation for svg markers exported to dxf
  Commit: 642b0d5ee347b53391c2c6b182cbbb6d34ec2812
      https://github.com/qgis/QGIS/commit/642b0d5ee347b53391c2c6b182cbbb6d34ec2812
  Changed paths:
    M python/CMakeLists.txt
  Log Message:
  Add copy constructor and assignment operator for QgsDxfExport
  Commit: a75de2b81b8882b0d8bbb686b10707ca6bdb8758
      https://github.com/qgis/QGIS/commit/a75de2b81b8882b0d8bbb686b10707ca6bdb8758
  Date:   2013-12-06 (Fri, 06 Dec 2013)
  Changed paths:
  Log Message:
  Draw default point symbol if dxf export not supported by marker symbol
  Commit: ebbb976e8a1716b0e0cfa30ee51c6d24d69a87d0
      https://github.com/qgis/QGIS/commit/ebbb976e8a1716b0e0cfa30ee51c6d24d69a87d0
  Changed paths:
  Log Message:
  Show success / failure of dxf export in message bar
  Commit: 668403ace5e86f7aed9a6782a38d8e3c270180b6
      https://github.com/qgis/QGIS/commit/668403ace5e86f7aed9a6782a38d8e3c270180b6
  Changed paths:
  Log Message:
  Write dxf circle
  Commit: 0239b4d6c7a9f1ce5c070ad225250f57421ab7bd
      https://github.com/qgis/QGIS/commit/0239b4d6c7a9f1ce5c070ad225250f57421ab7bd
  Changed paths:
    M src/core/symbology-ng/qgsellipsesymbollayerv2.cpp
    M src/core/symbology-ng/qgsellipsesymbollayerv2.h
  Log Message:
  Dxf export for ellipse symbol layer
  Commit: 561f01c0c222ca6d4d7c2904606d66d00f963c66
      https://github.com/qgis/QGIS/commit/561f01c0c222ca6d4d7c2904606d66d00f963c66
  Changed paths:
    M python/core/symbology-ng/qgssymbollayerv2.sip
    M src/app/qgisapp.h
    M src/ui/qgisapp.ui
  Log Message:
  [FEATURE]: merge dxf_export branch
Compare: https://github.com/qgis/QGIS/compare/ba76c99037d8...561f01c0c222
More information about the QGIS-commit mailing list
