[QGIS Commit] [qgis/QGIS] a596b2: [tests] Update all expected images based on compos...
    GitHub
    noreply at github.com
    Tue Dec 31 14:31:38 PST 2013
  Branch: refs/heads/master
  Home:   https://github.com/qgis/QGIS
  Commit: a596b2243abeac6955df63e9a0951d00e8d97f57
      https://github.com/qgis/QGIS/commit/a596b2243abeac6955df63e9a0951d00e8d97f57
  Author: Nyall Dawson <nyall.dawson at gmail.com>
  Date:   2013-12-31 (Tue, 31 Dec 2013)
  Changed paths:
    M tests/testdata/control_images/expected_atlas_autoscale1/expected_atlas_autoscale1.png
    M tests/testdata/control_images/expected_atlas_autoscale2/expected_atlas_autoscale2.png
    M tests/testdata/control_images/expected_atlas_filtering1/expected_atlas_filtering1.png
    M tests/testdata/control_images/expected_atlas_fixedscale1/expected_atlas_fixedscale1.png
    M tests/testdata/control_images/expected_atlas_fixedscale2/expected_atlas_fixedscale2.png
    M tests/testdata/control_images/expected_atlas_hiding1/expected_atlas_hiding1.png
    M tests/testdata/control_images/expected_atlas_hiding2/expected_atlas_hiding2.png
    M tests/testdata/control_images/expected_atlas_sorting1/expected_atlas_sorting1.png
    M tests/testdata/control_images/expected_atlas_sorting2/expected_atlas_sorting2.png
    M tests/testdata/control_images/expected_composereffects_blend/expected_composereffects_blend.png
    M tests/testdata/control_images/expected_composereffects_transparency/expected_composereffects_transparency.png
    M tests/testdata/control_images/expected_composerhtml_multiframe1/expected_composerhtml_multiframe1.png
    M tests/testdata/control_images/expected_composerhtml_multiframe2/expected_composerhtml_multiframe2.png
    M tests/testdata/control_images/expected_composerhtml_multiframe3/expected_composerhtml_multiframe3.png
    M tests/testdata/control_images/expected_composerhtml_table/expected_composerhtml_table.png
    M tests/testdata/control_images/expected_composermap_grid/expected_composermap_grid.png
    M tests/testdata/control_images/expected_composermap_overview/expected_composermap_overview.png
    M tests/testdata/control_images/expected_composermap_overview_blending/expected_composermap_overview_blending.png
    M tests/testdata/control_images/expected_composermap_overview_center/expected_composermap_overview_center.png
    M tests/testdata/control_images/expected_composermap_overview_invert/expected_composermap_overview_invert.png
    M tests/testdata/control_images/expected_composermap_render/expected_composermap_render.png
    M tests/testdata/control_images/expected_composermap_zebrastyle/expected_composermap_zebrastyle.png
    M tests/testdata/control_images/expected_composerrotation_label/expected_composerrotation_label.png
    M tests/testdata/control_images/expected_composerrotation_label_oldapi/expected_composerrotation_label_oldapi.png
    M tests/testdata/control_images/expected_composerrotation_mapitemrotation/expected_composerrotation_mapitemrotation.png
    M tests/testdata/control_images/expected_composerrotation_maprotation/expected_composerrotation_maprotation.png
    M tests/testdata/control_images/expected_composerrotation_maprotation_oldapi/expected_composerrotation_maprotation_oldapi.png
    M tests/testdata/control_images/expected_composerrotation_pictureitemrotation/expected_composerrotation_pictureitemrotation.png
    M tests/testdata/control_images/expected_composerrotation_picturerotation/expected_composerrotation_picturerotation.png
    M tests/testdata/control_images/expected_composerrotation_picturerotation_oldapi/expected_composerrotation_picturerotation_oldapi.png
    M tests/testdata/control_images/expected_composerrotation_shape/expected_composerrotation_shape.png
    M tests/testdata/control_images/expected_composerrotation_shape_oldapi/expected_composerrotation_shape_oldapi.png
    M tests/testdata/control_images/expected_composerscalebar_doublebox/expected_composerscalebar_doublebox.png
    M tests/testdata/control_images/expected_composerscalebar_numeric/expected_composerscalebar_numeric.png
    M tests/testdata/control_images/expected_composerscalebar_singlebox/expected_composerscalebar_singlebox.png
    M tests/testdata/control_images/expected_composerscalebar_tick/expected_composerscalebar_tick.png
    M tests/testdata/control_images/expected_composershapes_ellipse/expected_composershapes_ellipse.png
    M tests/testdata/control_images/expected_composershapes_rectangle/expected_composershapes_rectangle.png
    M tests/testdata/control_images/expected_composershapes_roundedrect/expected_composershapes_roundedrect.png
    M tests/testdata/control_images/expected_composershapes_triangle/expected_composershapes_triangle.png
    M tests/testdata/control_images/expected_piediagram/expected_piediagram.png
  Log Message:
  [tests] Update all expected images based on composer tests. Prior to c3ec3b2d75 composer exports had a 1 pixel slightly-gray row at the bottom of images. After c3ec3b2d75 this bottom row is now a slightly transparent white row. The underlying issue causing this row still needs to be fixed, but in the meantime this gets composer tests passing again.
