[QGIS Commit] [qgis/QGIS] b5502b: Add method for estimating the maximum amount a sym...
GitHub
noreply at github.com
Sat Jan 4 01:56:44 PST 2014
Branch: refs/heads/master
Home: https://github.com/qgis/QGIS
Commit: b5502b6307c688a6a55b6b740ad8fe60e179f71b
https://github.com/qgis/QGIS/commit/b5502b6307c688a6a55b6b740ad8fe60e179f71b
Author: Nyall Dawson <nyall.dawson at gmail.com>
Date: 2014-01-03 (Fri, 03 Jan 2014)
Changed paths:
M src/core/symbology-ng/qgsfillsymbollayerv2.cpp
M src/core/symbology-ng/qgsfillsymbollayerv2.h
M src/core/symbology-ng/qgslinesymbollayerv2.cpp
M src/core/symbology-ng/qgslinesymbollayerv2.h
M src/core/symbology-ng/qgssymbollayerv2.h
M src/core/symbology-ng/qgssymbollayerv2utils.cpp
M src/core/symbology-ng/qgssymbollayerv2utils.h
Log Message:
Add method for estimating the maximum amount a symbol bleeds out of the drawn polygon. Eg, half of the border width is actually drawn outside of a rectangle. Calculated values are an estimate only since the symbology may be affected by data defined parameters.
Commit: 6d918a1acfba1f559c7ed79cc27d824199852886
https://github.com/qgis/QGIS/commit/6d918a1acfba1f559c7ed79cc27d824199852886
Changed paths:
M src/core/composer/qgspaperitem.cpp
M src/core/composer/qgspaperitem.h
Log Message:
[composer] Make sure entire page symbol border is included when exporting compositions. Previously half the page border would be cropped out. Also fix nIRV's infamous 1px bad row at bottom of composer exports bug.
Commit: aae492fa432f3c04f7118de956af4172560acf95
https://github.com/qgis/QGIS/commit/aae492fa432f3c04f7118de956af4172560acf95
Changed paths:
M tests/testdata/control_images/expected_atlas_autoscale1/expected_atlas_autoscale1.png
M tests/testdata/control_images/expected_atlas_autoscale2/expected_atlas_autoscale2.png
M tests/testdata/control_images/expected_atlas_filtering1/expected_atlas_filtering1.png
M tests/testdata/control_images/expected_atlas_fixedscale1/expected_atlas_fixedscale1.png
M tests/testdata/control_images/expected_atlas_fixedscale2/expected_atlas_fixedscale2.png
M tests/testdata/control_images/expected_atlas_hiding1/expected_atlas_hiding1.png
M tests/testdata/control_images/expected_atlas_hiding2/expected_atlas_hiding2.png
M tests/testdata/control_images/expected_atlas_sorting1/expected_atlas_sorting1.png
M tests/testdata/control_images/expected_atlas_sorting2/expected_atlas_sorting2.png
M tests/testdata/control_images/expected_composereffects_blend/expected_composereffects_blend.png
M tests/testdata/control_images/expected_composereffects_transparency/expected_composereffects_transparency.png
M tests/testdata/control_images/expected_composerhtml_multiframe1/expected_composerhtml_multiframe1.png
M tests/testdata/control_images/expected_composerhtml_multiframe2/expected_composerhtml_multiframe2.png
M tests/testdata/control_images/expected_composerhtml_multiframe3/expected_composerhtml_multiframe3.png
M tests/testdata/control_images/expected_composerhtml_table/expected_composerhtml_table.png
M tests/testdata/control_images/expected_composermap_grid/expected_composermap_grid.png
M tests/testdata/control_images/expected_composermap_overview/expected_composermap_overview.png
M tests/testdata/control_images/expected_composermap_overview_blending/expected_composermap_overview_blending.png
M tests/testdata/control_images/expected_composermap_overview_center/expected_composermap_overview_center.png
M tests/testdata/control_images/expected_composermap_overview_invert/expected_composermap_overview_invert.png
M tests/testdata/control_images/expected_composermap_render/expected_composermap_render.png
M tests/testdata/control_images/expected_composermap_zebrastyle/expected_composermap_zebrastyle.png
M tests/testdata/control_images/expected_composerrotation_label/expected_composerrotation_label.png
M tests/testdata/control_images/expected_composerrotation_label_oldapi/expected_composerrotation_label_oldapi.png
M tests/testdata/control_images/expected_composerrotation_mapitemrotation/expected_composerrotation_mapitemrotation.png
M tests/testdata/control_images/expected_composerrotation_maprotation/expected_composerrotation_maprotation.png
M tests/testdata/control_images/expected_composerrotation_maprotation_oldapi/expected_composerrotation_maprotation_oldapi.png
M tests/testdata/control_images/expected_composerrotation_pictureitemrotation/expected_composerrotation_pictureitemrotation.png
M tests/testdata/control_images/expected_composerrotation_picturerotation/expected_composerrotation_picturerotation.png
M tests/testdata/control_images/expected_composerrotation_picturerotation_oldapi/expected_composerrotation_picturerotation_oldapi.png
M tests/testdata/control_images/expected_composerrotation_shape/expected_composerrotation_shape.png
M tests/testdata/control_images/expected_composerrotation_shape_oldapi/expected_composerrotation_shape_oldapi.png
M tests/testdata/control_images/expected_composerscalebar_doublebox/expected_composerscalebar_doublebox.png
M tests/testdata/control_images/expected_composerscalebar_numeric/expected_composerscalebar_numeric.png
M tests/testdata/control_images/expected_composerscalebar_singlebox/expected_composerscalebar_singlebox.png
M tests/testdata/control_images/expected_composerscalebar_tick/expected_composerscalebar_tick.png
M tests/testdata/control_images/expected_composershapes_ellipse/expected_composershapes_ellipse.png
M tests/testdata/control_images/expected_composershapes_rectangle/expected_composershapes_rectangle.png
M tests/testdata/control_images/expected_composershapes_roundedrect/expected_composershapes_roundedrect.png
M tests/testdata/control_images/expected_composershapes_triangle/expected_composershapes_triangle.png
Log Message:
[tests] Update composition based tests now that 1px bad row bug is fixed
Commit: 31e37af4f3c9e20d392845fc312ff39eab5429e3
https://github.com/qgis/QGIS/commit/31e37af4f3c9e20d392845fc312ff39eab5429e3
Date: 2014-01-04 (Sat, 04 Jan 2014)
Changed paths:
M tests/src/core/CMakeLists.txt
A tests/src/core/testqgscomposerpaper.cpp
A tests/testdata/control_images/expected_composerpaper_bordered/expected_composerpaper_bordered.png
A tests/testdata/control_images/expected_composerpaper_default/expected_composerpaper_default.png
A tests/testdata/control_images/expected_composerpaper_markerborder/expected_composerpaper_markerborder.png
A tests/testdata/control_images/expected_composerpaper_transparent/expected_composerpaper_transparent.png
Log Message:
[tests] Add test for composer paper styles
Compare: https://github.com/qgis/QGIS/compare/1215d0b01636...31e37af4f3c9
