[QGIS Commit] [qgis/QGIS] db4401: Rebuild labeling tests control images with smaller...
GitHub
noreply at github.com
Mon Mar 24 19:42:34 PDT 2014
Branch: refs/heads/master
Home: https://github.com/qgis/QGIS
Commit: db4401fe0097e3e72f81829f50eb331cd5998d33
https://github.com/qgis/QGIS/commit/db4401fe0097e3e72f81829f50eb331cd5998d33
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2014-03-24 (Mon, 24 Mar 2014)
Changed paths:
M tests/src/python/test_qgspallabeling_base.py
M tests/src/python/test_qgspallabeling_composer.py
M tests/src/python/test_qgspallabeling_server.py
M tests/src/python/test_qgspallabeling_tests.py
M tests/testdata/control_images/expected_pal_canvas/sp_background_rect/sp_background_rect.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_rect_w_offset/sp_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_svg/sp_background_svg.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_svg_w_offset/sp_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_canvas/sp_default_label/sp_default_label.png
M tests/testdata/control_images/expected_pal_canvas/sp_partials_labels_disabled/sp_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_canvas/sp_partials_labels_enabled/sp_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_color/sp_text_color.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_size_map_unit/sp_text_size_map_unit.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_rect/sp_img_background_rect.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_rect_w_offset/sp_img_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_svg/sp_img_background_svg.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_svg_w_offset/sp_img_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_img_default_label/sp_img_default_label.png
M tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_disabled/sp_img_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_enabled/sp_img_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_composer/sp_img_text_color/sp_img_text_color.png
M tests/testdata/control_images/expected_pal_composer/sp_img_text_size_map_unit/sp_img_text_size_map_unit.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_background_rect/sp_svg_background_rect.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_background_rect_w_offset/sp_svg_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_background_svg/sp_svg_background_svg.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_background_svg_w_offset/sp_svg_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_default_label/sp_svg_default_label.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_partials_labels_disabled/sp_svg_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_partials_labels_enabled/sp_svg_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_text_color/sp_svg_text_color.png
M tests/testdata/control_images/expected_pal_composer/sp_svg_text_size_map_unit/sp_svg_text_size_map_unit.png
M tests/testdata/control_images/expected_pal_server/sp_background_rect/sp_background_rect.png
M tests/testdata/control_images/expected_pal_server/sp_background_rect_w_offset/sp_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_server/sp_background_svg/sp_background_svg.png
M tests/testdata/control_images/expected_pal_server/sp_background_svg_w_offset/sp_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_server/sp_default_label/sp_default_label.png
M tests/testdata/control_images/expected_pal_server/sp_partials_labels_disabled/sp_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_server/sp_partials_labels_enabled/sp_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_server/sp_text_color/sp_text_color.png
M tests/testdata/control_images/expected_pal_server/sp_text_size_map_unit/sp_text_size_map_unit.png
Log Message:
Rebuild labeling tests control images with smaller size (420 x 280)
Commit: f29d44e75928a6e6832ca7d49f1fcb321e39308a
https://github.com/qgis/QGIS/commit/f29d44e75928a6e6832ca7d49f1fcb321e39308a
Changed paths:
A tests/testdata/control_images/expected_pal_composer/sp_pdf_background_rect/sp_pdf_background_rect.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_background_rect_w_offset/sp_pdf_background_rect_w_offset.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_background_svg/sp_pdf_background_svg.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_background_svg_w_offset/sp_pdf_background_svg_w_offset.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_default_label/sp_pdf_default_label.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_partials_labels_disabled/sp_pdf_partials_labels_disabled.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_partials_labels_enabled/sp_pdf_partials_labels_enabled.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_text_color/sp_pdf_text_color.png
A tests/testdata/control_images/expected_pal_composer/sp_pdf_text_size_map_unit/sp_pdf_text_size_map_unit.png
Log Message:
Add PDF composer output labeling tests setup
- Only support for Poppler with Cairo (pdftocairo), since without Cairo a PDF's vectors are not always rendered properly
Compare: https://github.com/qgis/QGIS/compare/90f012d5cc40...f29d44e75928
