[QGIS Commit] [qgis/QGIS] 72457b: [FEATURE] (Processing) Initial Grass 7 support
GitHub
noreply at github.com
Sun Mar 30 11:59:40 PDT 2014
Branch: refs/heads/grass7
Home: https://github.com/qgis/QGIS
Commit: 72457b331f1682350b631b4f585b5ce158ca1127
https://github.com/qgis/QGIS/commit/72457b331f1682350b631b4f585b5ce158ca1127
Author: Markus Neteler <neteler at osgeo.org>
Date: 2014-03-30 (Sun, 30 Mar 2014)
Changed paths:
M python/plugins/processing/CMakeLists.txt
M python/plugins/processing/core/Processing.py
A python/plugins/processing/grass7/CMakeLists.txt
A python/plugins/processing/grass7/Grass7Algorithm.py
A python/plugins/processing/grass7/Grass7AlgorithmProvider.py
A python/plugins/processing/grass7/Grass7Utils.py
A python/plugins/processing/grass7/__init__.py
A python/plugins/processing/grass7/description/TODO.txt
A python/plugins/processing/grass7/description/i.atcorr.txt
A python/plugins/processing/grass7/description/i.fft.txt
A python/plugins/processing/grass7/description/i.his.rgb.txt
A python/plugins/processing/grass7/description/i.ifft.txt
A python/plugins/processing/grass7/description/i.rgb.his.txt
A python/plugins/processing/grass7/description/i.zc.txt
A python/plugins/processing/grass7/description/m.cogo.txt
A python/plugins/processing/grass7/description/nviz.txt
A python/plugins/processing/grass7/description/r.aspect.txt
A python/plugins/processing/grass7/description/r.average.txt
A python/plugins/processing/grass7/description/r.basins.fill.txt
A python/plugins/processing/grass7/description/r.bilinear.txt
A python/plugins/processing/grass7/description/r.bitpattern.txt
A python/plugins/processing/grass7/description/r.buffer.txt
A python/plugins/processing/grass7/description/r.carve.txt
A python/plugins/processing/grass7/description/r.circle.txt
A python/plugins/processing/grass7/description/r.clump.txt
A python/plugins/processing/grass7/description/r.coin.txt
A python/plugins/processing/grass7/description/r.composite.txt
A python/plugins/processing/grass7/description/r.contour.level.txt
A python/plugins/processing/grass7/description/r.contour.step.txt
A python/plugins/processing/grass7/description/r.cost.txt
A python/plugins/processing/grass7/description/r.covar.txt
A python/plugins/processing/grass7/description/r.cross.txt
A python/plugins/processing/grass7/description/r.describe.txt
A python/plugins/processing/grass7/description/r.drain.txt
A python/plugins/processing/grass7/description/r.fill.dir.txt
A python/plugins/processing/grass7/description/r.fillnulls.txt
A python/plugins/processing/grass7/description/r.flow.txt
A python/plugins/processing/grass7/description/r.grow.distance.txt
A python/plugins/processing/grass7/description/r.grow.txt
A python/plugins/processing/grass7/description/r.gwflow.txt
A python/plugins/processing/grass7/description/r.his.txt
A python/plugins/processing/grass7/description/r.horizon.height.txt
A python/plugins/processing/grass7/description/r.horizon.txt
A python/plugins/processing/grass7/description/r.info.txt
A python/plugins/processing/grass7/description/r.kappa.txt
A python/plugins/processing/grass7/description/r.lake.coords.txt
A python/plugins/processing/grass7/description/r.lake.layer.txt
A python/plugins/processing/grass7/description/r.mapcalculator.txt
A python/plugins/processing/grass7/description/r.median.txt
A python/plugins/processing/grass7/description/r.mfilter.fp.txt
A python/plugins/processing/grass7/description/r.mfilter.txt
A python/plugins/processing/grass7/description/r.mode.txt
A python/plugins/processing/grass7/description/r.neighbors.txt
A python/plugins/processing/grass7/description/r.out.gridatb.txt
A python/plugins/processing/grass7/description/r.out.ppm.txt
A python/plugins/processing/grass7/description/r.out.vrml.txt
A python/plugins/processing/grass7/description/r.param.scale.txt
A python/plugins/processing/grass7/description/r.patch.txt
A python/plugins/processing/grass7/description/r.plane.txt
A python/plugins/processing/grass7/description/r.profile.txt
A python/plugins/processing/grass7/description/r.quant.txt
A python/plugins/processing/grass7/description/r.quantile.txt
A python/plugins/processing/grass7/description/r.random.cells.txt
A python/plugins/processing/grass7/description/r.random.raster.txt
A python/plugins/processing/grass7/description/r.random.txt
A python/plugins/processing/grass7/description/r.reclass.area.greater.txt
A python/plugins/processing/grass7/description/r.reclass.area.lesser.txt
A python/plugins/processing/grass7/description/r.reclass.txt
A python/plugins/processing/grass7/description/r.recode.txt
A python/plugins/processing/grass7/description/r.regression.line.txt
A python/plugins/processing/grass7/description/r.report.txt
A python/plugins/processing/grass7/description/r.resamp.interp.txt
A python/plugins/processing/grass7/description/r.resamp.rst.txt
A python/plugins/processing/grass7/description/r.resamp.stats.txt
A python/plugins/processing/grass7/description/r.resample.txt
A python/plugins/processing/grass7/description/r.rescale.eq.txt
A python/plugins/processing/grass7/description/r.rescale.txt
A python/plugins/processing/grass7/description/r.series.txt
A python/plugins/processing/grass7/description/r.shaded.relief.txt
A python/plugins/processing/grass7/description/r.sim.sediment.txt
A python/plugins/processing/grass7/description/r.sim.water.txt
A python/plugins/processing/grass7/description/r.slope.aspect.txt
A python/plugins/processing/grass7/description/r.spreadpath.txt
A python/plugins/processing/grass7/description/r.statistics.txt
A python/plugins/processing/grass7/description/r.stats.txt
A python/plugins/processing/grass7/description/r.stream.angle.txt
A python/plugins/processing/grass7/description/r.stream.basins.txt
A python/plugins/processing/grass7/description/r.stream.del.txt
A python/plugins/processing/grass7/description/r.stream.distance.txt
A python/plugins/processing/grass7/description/r.stream.extract.txt
A python/plugins/processing/grass7/description/r.stream.order.txt
A python/plugins/processing/grass7/description/r.stream.pos.txt
A python/plugins/processing/grass7/description/r.stream.stats.txt
A python/plugins/processing/grass7/description/r.sum.txt
A python/plugins/processing/grass7/description/r.sun.txt
A python/plugins/processing/grass7/description/r.sunmask.txt
A python/plugins/processing/grass7/description/r.surf.area.txt
A python/plugins/processing/grass7/description/r.surf.contour.txt
A python/plugins/processing/grass7/description/r.surf.gauss.txt
A python/plugins/processing/grass7/description/r.surf.idw.txt
A python/plugins/processing/grass7/description/r.surf.idw2.txt
A python/plugins/processing/grass7/description/r.surf.random.txt
A python/plugins/processing/grass7/description/r.terraflow.txt
A python/plugins/processing/grass7/description/r.thin.txt
A python/plugins/processing/grass7/description/r.to.vect.txt
A python/plugins/processing/grass7/description/r.topidx.txt
A python/plugins/processing/grass7/description/r.viewshed.txt
A python/plugins/processing/grass7/description/r.volume.txt
A python/plugins/processing/grass7/description/r.walk.txt
A python/plugins/processing/grass7/description/r.water.outlet.txt
A python/plugins/processing/grass7/description/r.watershed.txt
A python/plugins/processing/grass7/description/v.buffer.column.txt
A python/plugins/processing/grass7/description/v.buffer.distance.txt
A python/plugins/processing/grass7/description/v.class.txt
A python/plugins/processing/grass7/description/v.clean.advanced.txt
A python/plugins/processing/grass7/description/v.clean.txt
A python/plugins/processing/grass7/description/v.db.select.txt
A python/plugins/processing/grass7/description/v.delaunay.txt
A python/plugins/processing/grass7/description/v.dissolve.txt
A python/plugins/processing/grass7/description/v.distance.toattr.txt
A python/plugins/processing/grass7/description/v.distance.txt
A python/plugins/processing/grass7/description/v.drape.txt
A python/plugins/processing/grass7/description/v.extract.txt
A python/plugins/processing/grass7/description/v.generalize.txt
A python/plugins/processing/grass7/description/v.hull.txt
A python/plugins/processing/grass7/description/v.in.dxf.txt
A python/plugins/processing/grass7/description/v.in.wfs.txt
A python/plugins/processing/grass7/description/v.info.txt
A python/plugins/processing/grass7/description/v.kcv.txt
A python/plugins/processing/grass7/description/v.lidar.correction.txt
A python/plugins/processing/grass7/description/v.lidar.edgedetection.txt
A python/plugins/processing/grass7/description/v.lidar.growing.txt
A python/plugins/processing/grass7/description/v.mkgrid.txt
A python/plugins/processing/grass7/description/v.neighbors.txt
A python/plugins/processing/grass7/description/v.normal.txt
A python/plugins/processing/grass7/description/v.out.dxf.txt
A python/plugins/processing/grass7/description/v.out.pov.txt
A python/plugins/processing/grass7/description/v.outlier.txt
A python/plugins/processing/grass7/description/v.overlay.txt
A python/plugins/processing/grass7/description/v.parallel.txt
A python/plugins/processing/grass7/description/v.patch.txt
A python/plugins/processing/grass7/description/v.perturb.txt
A python/plugins/processing/grass7/description/v.qcount.txt
A python/plugins/processing/grass7/description/v.random.txt
A python/plugins/processing/grass7/description/v.reclass.txt
A python/plugins/processing/grass7/description/v.report.txt
A python/plugins/processing/grass7/description/v.sample.txt
A python/plugins/processing/grass7/description/v.segment.txt
A python/plugins/processing/grass7/description/v.select.txt
A python/plugins/processing/grass7/description/v.split.length.txt
A python/plugins/processing/grass7/description/v.split.vert.txt
A python/plugins/processing/grass7/description/v.surf.bspline.lambda.txt
A python/plugins/processing/grass7/description/v.surf.bspline.sparse.txt
A python/plugins/processing/grass7/description/v.surf.bspline.txt
A python/plugins/processing/grass7/description/v.surf.idw.txt
A python/plugins/processing/grass7/description/v.surf.rst.cvdev.txt
A python/plugins/processing/grass7/description/v.surf.rst.txt
A python/plugins/processing/grass7/description/v.to.points.txt
A python/plugins/processing/grass7/description/v.to.rast.attribute.txt
A python/plugins/processing/grass7/description/v.to.rast.value.txt
A python/plugins/processing/grass7/description/v.transform.pointsfile.txt
A python/plugins/processing/grass7/description/v.transform.txt
A python/plugins/processing/grass7/description/v.univar.txt
A python/plugins/processing/grass7/description/v.voronoi.txt
A python/plugins/processing/grass7/ext/CMakeLists.txt
A python/plugins/processing/grass7/ext/HtmlReportPostProcessor.py
A python/plugins/processing/grass7/ext/__init__.py
A python/plugins/processing/grass7/ext/r_coin.py
A python/plugins/processing/grass7/ext/r_covar.py
A python/plugins/processing/grass7/ext/r_describe.py
A python/plugins/processing/grass7/ext/r_info.py
A python/plugins/processing/grass7/ext/r_regression_line.py
A python/plugins/processing/grass7/ext/r_report.py
A python/plugins/processing/grass7/ext/r_stats.py
A python/plugins/processing/grass7/ext/v_class.py
A python/plugins/processing/grass7/ext/v_info.py
A python/plugins/processing/grass7/ext/v_normal.py
A python/plugins/processing/grass7/ext/v_report.py
A python/plugins/processing/grass7/ext/v_univar.py
A python/plugins/processing/grass7/grass7.txt
A python/plugins/processing/grass7/nviz7.py
Log Message:
