[work] Re: [Qgis-community-team] Plugin icons
Tara Athan tara_athan at alt2is.com
Fri Aug 1 10:57:36 EDT 2008
Otto- I updated my local copy of the user guid: creation of new folders
such as operation_system_icon and moving those images is working OK.
However when I try to clean up the old files, I see this:
$ make updateicon
(cd ./images && rm -f *.png *.eps && cp
/software/qgis_head/src/plugins/../../images/themes/default/*.png .)
cp: cannot stat
`/software/qgis_head/src/plugins/../../images/themes/default/*.png': No
such file or directory
make: *** [updateicon] Error 1
I think we need to separate the removing of old eps files from the
copying of new images.
This is what I was thinking would be required:
One person will need to get the new images from the software source and
move them into their user guide local copy, then commit.
Everyone else will need to remove their old eps files and update from SVN.
Tara
> I did following steps now:
> - removed old png and eps image/icon files except screenies using Makefile
>   option 'updateicon'
> - moved operation system icons nix.png, osx.png and win.png to its own folder
>   /operation_system_icons. Otherwise they would be deleted during 'make
>   updateicon'.
> - adapted all .tex files, where image names in QGIS sources changed to make it
>   compile again.
> I hope this is what you wanted to. The step 'make updateicon' and 'adaption of
> all .tex files with changed icon names' need to be repeated before 1.0 release,
> but for now, i think we can move on with our task list.
> regards,
>  Otto
>> regards,
>>  Otto
>>> Tara
>>> Tim Sutton wrote:
>>>> Hi Tara
>>>> Ok so today I did the necessary changes so all plugin icons are named
>>>> after their parent directory. The exception is GRASS which is a more
>>>> complicated affair since the plugin supports themes. That said there
>>>> should no longer be any name collisions on plugin icons. Hope that
>>>> helps.
>>>> Regards
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.10/1584 - Release Date: 7/31/2008 12:00 PM
My e-mail delivery has been unreliable lately, so I am asking for
return receipts from all my email messages.
OK'ing the return receipt lets me know that my message was delivered.
Thank you.
Tara Athan
Principal, Alternatives to Invasive Species
tara_athan [AT] alt2is.com
707-485-1198
PO Box 415
Redwood Valley, CA 95470
More information about the Qgis-community-team mailing list
