[work] Re: [Qgis-community-team] Plugin icons
Tim Sutton
tim at linfiniti.com
Fri Aug 1 13:15:49 EDT 2008
Hi Folks
A small nomenclatural issue its probably better to call that dir
'operating_system' rather than 'operation_system'
Regards
Tim
2008/8/1 Otto Dassau <otto.dassau at gmx.de>:
> Hi Tara,
> On Fri, 01 Aug 2008 07:57:36 -0700
> Tara Athan <tara_athan at alt2is.com> wrote:
>> Otto- I updated my local copy of the user guid: creation of new folders
>> such as operation_system_icon and moving those images is working OK.
>> However when I try to clean up the old files, I see this:
>> $ make updateicon
>> (cd ./images && rm -f *.png *.eps && cp
>> /software/qgis_head/src/plugins/../../images/themes/default/*.png .)
>> cp: cannot stat
>> `/software/qgis_head/src/plugins/../../images/themes/default/*.png': No
>> such file or directory
>> make: *** [updateicon] Error 1
> you only need to adapt the path to qgis sources in the Makefiles on your system
> QGISPLUGINSOURCE=...
>> I think we need to separate the removing of old eps files from the
>> copying of new images.
>> This is what I was thinking would be required:
>> One person will need to get the new images from the software source and
>> move them into their user guide local copy, then commit.
> yes and he needs to adapt changes due to new names in the .tex files and
> Makefiles and make sure it all compiles well again.
>> Everyone else will need to remove their old eps files and update from SVN.
> all other users only need to use these 2 commands to make everything work again:
> make clean -> removes all current eps files and the folder finalpix
> svn up -> update to current images...
> or am I missing something?
> regards,
> Otto
>> Tara
>> > I did following steps now:
>> > - removed old png and eps image/icon files except screenies using Makefile
>> > option 'updateicon'
>> > - moved operation system icons nix.png, osx.png and win.png to its own
> folder
>> > /operation_system_icons. Otherwise they would be deleted during 'make
>> > updateicon'.
>> > - adapted all .tex files, where image names in QGIS sources changed to make
> it
>> > compile again.
>> > I hope this is what you wanted to. The step 'make updateicon' and 'adaption
> of
>> > all .tex files with changed icon names' need to be repeated before 1.0
> release,
>> > but for now, i think we can move on with our task list.
>> > regards,
>> > Otto
>> >> regards,
>> >> Otto
>> >>> Tara
>> >>> Tim Sutton wrote:
>> >>>> Hi Tara
>> >>>> Ok so today I did the necessary changes so all plugin icons are named
>> >>>> after their parent directory. The exception is GRASS which is a more
>> >>>> complicated affair since the plugin supports themes. That said there
>> >>>> should no longer be any name collisions on plugin icons. Hope that
>> >>>> helps.
>> >>>> Regards
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
Blog: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team
