[Qgis-community-team] Re: Plugin icons
Tara Athan
tara_athan at alt2is.com
Fri Aug 1 15:46:58 EDT 2008
OK, lets see if I have this
Procedure to update icons
*This should be done once per release, as soon as the GUI freeze is in
place.
1. Use svn or an svn client to update local copy of QGIS source code and
user guide Makefile
2. Modify Makefile as follows
a. change QGISPLUGINSSOURCE to the correct path for the local copy
b. add commands to the target "updateicons" for any new plugins
c. verify the paths for existing plugins, modify if necessary
3. If any new plugins have been added, create a folder
"plugins_name_images" containing a Makefile, and also a file
"plugins_name.tex"
4. execute "make updateicons" from the command line
5. modify all Makefiles to be consistent with the new image names
5. insert %FIXME comments for all latex errors resulting from missing
images (This will happen for all screenshots and for missing icon images)
5. commit these changes
6. send an email to qgis-community-team with the following instructions
a. execute "make clean"
b. svn update your local copy
c. please update your sections wherever %FIXME appears
Does that look correct?
Otto Dassau wrote:
> Hi Tara,
> On Fri, 01 Aug 2008 07:57:36 -0700
> Tara Athan <tara_athan at alt2is.com> wrote:
>> Otto- I updated my local copy of the user guid: creation of new folders
>> such as operation_system_icon and moving those images is working OK.
>> However when I try to clean up the old files, I see this:
>> $ make updateicon
>> (cd ./images && rm -f *.png *.eps && cp
>> /software/qgis_head/src/plugins/../../images/themes/default/*.png .)
>> cp: cannot stat
>> `/software/qgis_head/src/plugins/../../images/themes/default/*.png': No
>> such file or directory
>> make: *** [updateicon] Error 1
> you only need to adapt the path to qgis sources in the Makefiles on your system
> QGISPLUGINSOURCE=...
>> I think we need to separate the removing of old eps files from the
>> copying of new images.
>> This is what I was thinking would be required:
>> One person will need to get the new images from the software source and
>> move them into their user guide local copy, then commit.
> yes and he needs to adapt changes due to new names in the .tex files and
> Makefiles and make sure it all compiles well again.
>> Everyone else will need to remove their old eps files and update from SVN.
> all other users only need to use these 2 commands to make everything work again:
> make clean -> removes all current eps files and the folder finalpix
> svn up -> update to current images...
> or am I missing something?
> regards,
> Otto
>> Tara
>>> I did following steps now:
>>> - removed old png and eps image/icon files except screenies using Makefile
>>> option 'updateicon'
>>> - moved operation system icons nix.png, osx.png and win.png to its own
> folder
>>> /operation_system_icons. Otherwise they would be deleted during 'make
>>> updateicon'.
>>> - adapted all .tex files, where image names in QGIS sources changed to make
> it
>>> compile again.
>>> I hope this is what you wanted to. The step 'make updateicon' and 'adaption
> of
>>> all .tex files with changed icon names' need to be repeated before 1.0
> release,
>>> but for now, i think we can move on with our task list.
>>> regards,
>>> Otto
>>>> regards,
>>>> Otto
>>>>> Tara
>>>>> Tim Sutton wrote:
>>>>>> Hi Tara
>>>>>> Ok so today I did the necessary changes so all plugin icons are named
>>>>>> after their parent directory. The exception is GRASS which is a more
>>>>>> complicated affair since the plugin supports themes. That said there
>>>>>> should no longer be any name collisions on plugin icons. Hope that
>>>>>> helps.
>>>>>> Regards
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.10/1585 - Release Date: 8/1/2008 6:39 AM
My e-mail delivery has been unreliable lately, so I am asking for
return receipts from all my email messages.
OK'ing the return receipt lets me know that my message was delivered.
Thank you.
Tara Athan
Principal, Alternatives to Invasive Species
tara_athan [AT] alt2is.com
707-485-1198
PO Box 415
Redwood Valley, CA 95470
More information about the Qgis-community-team
