[Qgis-community-team] update qgis sample dataset
Jürgen E. Fischer
jef at norbit.de
Sun Oct 5 07:54:07 EDT 2008
On Mon, 15. Sep 2008 at 12:38:04 +0200, Otto Dassau wrote:
> For the updated dataset I changed almost only data in the GRASS location:
> - renamed folder grass to grassdata, because that is the usual name used for
> a GRASS Database folder in all known literature
> - fixed the gtopo30 elevation map.
> - fixed the alaska boundary map. There were some topological errors. I
> updated the fixed alaska map also into the vmap0_shapefiles folder.
A vector layer that has some attribute data to demonstrate the different
renderers would be nice too and maybe a sample project that also
contains a WMS and/or WFS layer with alaskan data - if available.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the Qgis-community-team
