[Qgis-community-team] Theme for trac
Tim Sutton
tim at linfiniti.com
Wed Apr 8 04:57:47 EDT 2009
Hi Otto
The new wiki theme is looking good. It would be great to theme the
wiki to match. I use a theme that is fairly similar the wiki theme
here at work. It would be great to install this and then tweak it a
little to match our other sites.
Here are my install notes:
5.10. Trac Theme Setup
I installed a custom theme for trac to make it a little more user friendly.
First install python-dev headers which is going to be needed by some
of the theme engine deps.
sudo apt-get install python2.5-dev
Next get the theme engine from here:
http://trac-hacks.org/wiki/ThemeEnginePlugin
Look for the "Download and Source" section on the above page.
Now unzip the zip and cd into its 0.11 dir then do:
sudo python setup.py install
Next get the crystal theme from here:
http://trac-hacks.org/wiki/CrystalxTheme
Download the theme and extract it then do:
cd crystalxtheme/0.11/
Finally add to the trac ini a couple of lines:
vim /opt/trac/sac/conf/trac.ini
# Added by Tim for crystal theme support
[components]
themeengine.* = enabled
crystalxtheme.* = enabled
[theme]
theme = CrystalX
After doing these steps go into trac admin and enble the themeengine
and crystal theme plugins.
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20090408/6bd19725/trac_themes-0001.jpeg
More information about the Qgis-community-team
