[Qgis-community-team] sec 8.2.1 - CRS automatically set by 1st loaded layer
Otto Dassau otto.dassau at gmx.de
Tue Jan 20 04:34:12 EST 2009
Hi Lars,
On Mon, 19 Jan 2009 16:20:29 +0100
Lars Stöwesand <lars at sai.uni-heidelberg.de> wrote:
> Hi Tara and Otto - just found a description of a feature which is not
> supported anymore: page 73: 8.2.1 Specifying a Projection
> "QGIS automatically sets the map projection to the coordinate system
> of the first layer loaded."
> see: https://trac.osgeo.org/qgis/ticket/946
> see also: https://trac.osgeo.org/qgis/ticket/967 (can be tricky when
> creating a new layer (sec 5.4.4 ))
> Is it possible to add/change it in the current manual?
usually not, but I think this is an exception and since we haven't started the
translation yet, I changed it in trunk, in the tagged version and the pdf.
I changed quite a lot in that chapter to make the projection part hopefully
clearer and it would be great, if some people can have a closer look at the
chapter "Working with Projections" pp. 71. and check if I haven't made any
mistakes. You find the PDF here:
http://download.osgeo.org/qgis/doc/manual/qgis-1.0.0_user_guide_en.pdf
regards,
 Otto
> Regards
> /Lars
More information about the Qgis-community-team mailing list
