[Qgis-community-team] Release date for manual 1.1
Claudia A Engel
cengel at stanford.edu
Mon May 4 13:14:05 EDT 2009
I committed the remaining pieces of Chap 5 last night - hope I got it
all right.
I won't have time now until later in the week.
Claudia
On May 4, 2009, at 10:07 AM, Carson Farmer wrote:
> Otto Dassau wrote:
>> Hi Claudia and Carson,
>> On Thu, 30 Apr 2009 00:05:16 -0700
>> Claudia A Engel <cengel at stanford.edu> wrote:
>>> Otto and Carson,
>>> I edited the changes for Postgis SLL mode, improved handling of
>>> postgis layers and the map units/pixels addition and committed
>>> those to svn.
>>> These edits are reflected on the Manual Task page. I tested to
>>> make sure, and it all seems to compile fine here. I hope this is
>>> all ok, but me know if I should do something differently, as I
>>> have never done this before.
>>> I also added the headers for the following subsections as
>>> discussed, but they need to be written:
>>> -Spatialite Layers
>>> -Diagram overlay tab
>> I added the diagram overlay section with an example. I also added a
>> new vector
>> shape layer to the qgis sample dataset and updated the files and
>> the readme.txt
>> on the server.
>> http://download.osgeo.org/qgis/data/
>> Maybe you can check if it is ok, especially with the language. It's
>> great to
>> have native speakers in the new team :).
>>> -Working with the attribute table
>>> Lastly, the new Vector Load dialogue needs still to be added in. I
>>> can probably do this, plus another of the chapters above, this
>>> weekend.
>>> So if anyone can help out with the other chapters, that would be
>>> great.
>>> Thanks, Claudia
>>> On Apr 29, 2009, at 2:50 AM, Carson Farmer wrote:
>>>> Hi team,
>>>>> I saw that Carson already did something here.
>>>>> Carson what was your idea when you created the
>>>>> "plugins_diagram_overlay_images"
>>>>> folder? Do you plan to add an extra subsection for this plugin
>>>>> in the plugin
>>>>> chapter?
>>>> Well for starters I needed an icon for the core plugins chapter ;-)
>>>> But yes, I will be adding a section to the plugin as well. It
>>>> would be nice to see what Claudia has done as well, so that we
>>>> don't end up duplicating each others work... Claudia, have you
>>>> committed your edits yet?
>>>>> Or should it work as for the SPIT Plugin. It is listed in
>>>>> section 12 "Using Core
>>>>> Plugins" but there doesn't exist a SPIT plugin subsection. The
>>>>> description can
>>>>> be found in section 5.2.4 together with the PostGIS stuff.
>>>> hmm, now that I think of it, this might be the best route to
>>>> take... this adds more work to Claudia's list, so Claudia if you
>>>> need help just let us know... I imagine that in the future the
>>>> vector overlay stuff will become completely part of core, so
>>>> putting it in the working with vector layers section now might
>>>> save some hassle later on as well...
>>>> In this case, I think I'll add two new subsections for SPIT and
>>>> the Overlay stuff in the Using core plugins chapter, pointing
>>>> the user to the sections in the working with vector layers
>>>> Chapter...
>>>>> For the diagram_overlay plugin this would mean, we add it to
>>>>> the list of core
>>>>> plugins but the description would go into
>>>>> working_with_vector.tex and we use the
>>>>> folder diagram_overlay plugin_images/ for the plugin icons and
>>>>> screenies. Is
>>>>> that correct?
>>>> see above
>>>>>> - Changes in attribute table
>>>>>> I could not find any description of the attribute table in the
>>>>>> manual, but maybe I looked in the wrong place. If there is
>>>>>> none, is it necessary to have one? Add another subsection?
>>>>> yes, I haven't found anything, too. In the other email I
>>>>> suggested to add a new
>>>>> subsubsection to 5.4 Editing \subsection{Working with the
>>>>> attribute table} just
>>>>> above the Query Builder?
>>>> This would be good. We should at least mention that there is an
>>>> attribute table somewhere... also, the attribute table is
>>>> relatively fast compared with other GIS, so this should probably
>>>> be mentioned...
>>>>>> - Improved handling of postGIS layers.
>>>>>> I did not look around very thoroughly, but at first glance I
>>>>>> could not figure out what this exactly refers to.
>>>>> I don't know either? Carson, do you know? Otherwise we can ask
>>>>> Jürgen, I guess
>>>>> we did those improvements.
>>>> Yeh, Jürgen would be the one to ask... the SSL mode change is
>>>> probably one of the bigger changes, and increases PostGIS access
>>>> speed by up to 5 times in some cases!
>> thanks Otto
> Hi guys,
> Sorry for my silence the last few days, I have been unexpectedly out
> of town for the past 4 days :-(
> I'm back now, and will have a look at the changes above... I did a
> bit of work on the road, so I will try to commit these tonight when
> I'm settled back in. I will keep you all updated with that, and
> hopefully we can make this deadline!
> As Otto mentioned in a previous email, I think it is really
> important that we have an IRC meeting when this is finished to
> debrief, and talk about what worked/didn't work for people etc.
> (I'll also make sure I show up this time!).
> Cheers,
> Carson
> Carson J. Q. Farmer
> ISSP Doctoral Fellow
> National Centre for Geocomputation (NCG),
> National University of Ireland, Maynooth,
> Email: Carson.Farmer at gmail.com
> Web: http://www.carsonfarmer.com/
> http://www.ftools.ca/
More information about the Qgis-community-team
