[Qgis-community-team] Release date for manual 1.1
Otto Dassau otto.dassau at gmx.de
Tue May 5 10:09:06 EDT 2009
Hi Stephan,
On Tue, 5 May 2009 16:02:38 +0200
Stephan Holl <stephan.holl at intevation.de> wrote:
> Hello Otto,
> Otto Dassau <otto.dassau at gmx.de>, [20090505 - 14:37:28]
> > Hi Stephan,
> > On Tue, 5 May 2009 14:29:40 +0200
> > > Hello Otto,
> > > Otto Dassau <otto.dassau at gmx.de>, [20090504 - 19:33:55]
> > > > Hi,
> > > > On Mon, 4 May 2009 10:14:05 -0700
> > > > Claudia A Engel <cengel at stanford.edu> wrote:
> > > > > I committed the remaining pieces of Chap 5 last night - hope I
> > > > > got it all right.
> > > > > I won't have time now until later in the week.
> > > > thanks Claudia!
> > > > I also finished my sections according to the table at:
> > > > http://www.qgis.org/wiki/index.php/Manual_Writing#Document_Maintainers
> > > > maybe the others Anne, Werner and Stephan can give us a short
> > > > "report" about the status and what is left and if you need some
> > > > help.
> > > I have reworked the OGC-chapter, only small enhancements and from my
> > > point of view we can release it as it is. I used QGIS-trunk from
> > > saturday as a reference, which should be new enough though.
> > thanks a lot Stephan!
> > > One question still remains: What about the proxy-settings described
> > > in another mail-thread? is this somewhere mentioned? I think it
> > > should be under the Options-dialog, as it can be found there. I
> > > have mentioned the proxy-settings within the OGC-parts certainly.
> > Apart from the OGC chapter, where I think proxy-settings is described
> > very well, it is only mentioned in section "features_at_a_glance" in
> > the Options-dialog part.
> > \minisec{Proxy Tab}
> > \begin{itemize}
> > \item \checkbox{Use proxy for web access} and define host, port,
> > user, and password. \end{itemize}
> > What else do you think should be added there or anywhere else?
> The proxy-types and the proxy-excludes should be mentioned somewhere,
> problably in the above mentioned chapter. This is IMO quite important
> for web-related stuff.
> I would describe it, if someone could assist in explaining the
> different types and its meanings.
that would be great, although I hope someone else can help here, because I don't
know enough about.
regards,
 Otto
> Best
> 	Stephan
More information about the Qgis-community-team mailing list
