[Qgis-community-team] compiling the manual
Otto Dassau
otto.dassau at gmx.de
Tue Sep 8 05:46:48 EDT 2009
Hi document writers,
can you have a look at http://www.qgis.org/wiki/ManualTasks and update the
"Updates QGIS 1.2 User Guide" table, so we know, what parts of the manual
are updated? I know at least that Micha finished already a lot for the GRASS
section...
Regards,
Otto
On Fri, 21 Aug 2009 15:42:56 +0300
Micha Silver <micha at arava.co.il> wrote:
> Otto Dassau wrote:
> > Hi Micha,
> > I revised the GRASS example section. It is very well done - thanks a lot!
I only
> > changed the structure a little bit, moved \underline to \minisec and put
parts
> > of the commands in an \itemize. Do you want me to create a PDF for you?
> Thanks for the encouragement. Yes, I'd like to see a PDF as it looks so
far.
> Anything else to do? The GRASS section seems long enough now, or would
> you add something else? A db.connect example?
> Anyone working on the print composer section. I'll have a bit more time
> this week, then in Sept. I'm off on vacation...
> Best regards,
> Micha
> > Regards,
> > Otto
> > On Mon, 17 Aug 2009 11:31:39 +0300
> >> Otto Dassau wrote:
> >> Hi Micha,
> >> On Mon, 17 Aug 2009 10:45:29 +0300
> >> Otto Dassau wrote:
> >> But I didn't get *any* images in the pdf. Not screenies and not icons
> >> throughout the document.
> >> are there any error messages when you compile the latex code? Maybe you
are
> >> Yes, tons of errors
> >> missing "convert" from ImageMagick? What OS do you use?
> >> Fedora 10, ImageMagick is installed.
> >> If you have some time to read thru what I've done so far, and give me
> >> some feedback, I'd appreciate it.
> >> yes, I will do, but probably not within the next days.
> >> thanks,
> >> Otto
> > This mail was received via Mail-SeCure System.
More information about the Qgis-community-team
