[Qgis-community-team] some report and questions on our QGIS training
Werner Macho werner.macho at gmail.com
Wed Jun 2 08:33:47 EDT 2010
hi nikos!
Either you search for a corresponding bug in TRAC [1] or you just send
it to the developers list[2].
I sure a developer will react on this ..
regards
Werner
[1] https://trac.osgeo.org/qgis/
[2] http://www.qgis.org/en/community/mailing-lists.html
Am 02.06.2010 14:27, schrieb nikos ves:
> On Wed, 2010-06-02 at 10:27 +0800, maning sambale wrote:
>> * Saving file in a specified format does not append the file
>> extensions.  This was observed in the Map/Print Composer.  Although a
>> pdf filetype was activated, we had to create a complete filename with
>> the extension (i.e "map.pdf" and not "map") in order to save the file
>> with the extension.
> That qualifies as a bug. saving as SVG has the same issue
> I've fix it so, is there anyone who can sent me info on how to sent a
> patch for it?
More information about the Qgis-community-team mailing list
