[Qgis-community-team] Information for new manual contributors
Otto Dassau otto.dassau at gmx.de
Mon Jun 7 03:49:59 EDT 2010
Hi Bogus, David, Martijn and Ves,
I just started to grant svn access for you. Please try to checkout the
manual with your osgeo ids - see below.
more instructions on how to work on the english qgis manual in trunk
a) Please read the wiki page. It includes a lot of hints:
http://www.qgis.org/wiki/Manual_Writing
b) General information about working with latex and subversion
http://www.qgis.org/wiki/Working_with_Subversion_and_Latex
Unfortunately, not all information is uptodate in the wiki page at the
moment. I will update it as soon as possible. So please ask, if you have
problems on the list and I will help.
how to download the current trunk:
You should be able to download the documentation trunk ('master'-document)
as a named user with your osgeo id. For a clean checkout you need a
svn-client.
# Checkout as a named user
svn co --username <your username here>
https://svn.osgeo.org/qgis/docs/trunk/english_us/
# Building
To build the user_guide as a PDF-doc, change into the folder user_guide and
do the following:
change into trunk/english_us/user_guide and type
pdflatex user_guide.tex
if it doesn't compile properly with a PDF as output, please write to the
list, because we just migrated from texlive to pdflatex and might be some
errors left.
Regards,
 Otto
More information about the Qgis-community-team mailing list
