[Qgis-community-team] Information for new manual contributors
David Quinn
djq at MIT.EDU
Tue Jun 8 10:13:56 EDT 2010
Hello All,
I just tried checking out the manual and got the following error:
<OPTIONS of 'https://svn.osgeo.org/qgis/docs/trunk/english_us/: Server
certificate verification failed: issuer is not trusted
(https://svn.osgeo.org)>
I'm using fink and SCToolbarButton on OSX 10.5
This is my first attempt at using svn; can anyone suggest what I need to do?
Regards,
David
On 6/7/10 3:49 AM, Otto Dassau wrote:
> Hi Bogus, David, Martijn and Ves,
> I just started to grant svn access for you. Please try to checkout the
> manual with your osgeo ids - see below.
> more instructions on how to work on the english qgis manual in trunk
> a) Please read the wiki page. It includes a lot of hints:
> http://www.qgis.org/wiki/Manual_Writing
> b) General information about working with latex and subversion
> http://www.qgis.org/wiki/Working_with_Subversion_and_Latex
> Unfortunately, not all information is uptodate in the wiki page at the
> moment. I will update it as soon as possible. So please ask, if you have
> problems on the list and I will help.
> how to download the current trunk:
> You should be able to download the documentation trunk ('master'-document)
> as a named user with your osgeo id. For a clean checkout you need a
> svn-client.
> # Checkout as a named user
> svn co --username<your username here>
> # Building
> To build the user_guide as a PDF-doc, change into the folder user_guide and
> do the following:
> change into trunk/english_us/user_guide and type
> pdflatex user_guide.tex
> if it doesn't compile properly with a PDF as output, please write to the
> list, because we just migrated from texlive to pdflatex and might be some
> errors left.
> Regards,
> Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
