[Qgis-community-team] Broken internal links in manual
MORREALE Jean Roc
jr.morreale at enoreth.net
Fri Oct 15 05:10:18 EDT 2010
Le 15/10/2010 09:46, Werner Macho a écrit :
> Am 15.10.2010 09:38, schrieb Alexander Bruy:
>> Wrong behaviour exists for next sections:
>> - Table of Contents
>> - List of Figures
>> - List of Tables
>> - List of QGIS Tips
>> - Index
>> - Cited Literature
> Just a guess ..
> With every new run LaTeX does not clean out old .toc files (and probably
> others too)
> So from time to time you should clean out those files by hand and do a
> clean run from start.
> Some Editors have "cleaning" in their menu and you could try that..
> Most of the time the links were correct again for me after cleaning out
> old files.
> Probably that helps for you too
> regards
> Werner
Alexander > I've submitted a fix solving the tips issue (if you clicked
on a link from the list of tips it would brings you back to the cover)
Werner > this is not linked to an outdated auxiliary file, it doesn't
seem to be the use of the roman package too nor the pagestyle{} as far I
can tell
a quick'n dirty fix would be to change the bookmark"s links within a pdf
editor
regards,
jean roc
More information about the Qgis-community-team
