[Qgis-community-team] RE: Help for digitization
Tim Sutton tim at linfiniti.com
Sun Oct 23 09:03:54 EDT 2011
Hi Jean-Phillipe
On Fri, Oct 21, 2011 at 12:39 PM, Jean-Philippe Puyravaud
<jp.puyravaud at gmail.com> wrote:
> Hi,
> Sorry for the message. After two bad days I found out the magical
> Settings->Snapping options->Enable topological editing
I'm glad you found the solution. For your information, this list is
used for internal organisation of the documentation work and similar,
you will probably get more value from subscribing to the qgis-user
mailing list.
Best regards
Tim
> Best regards,
> JP
> From: Jean-Philippe Puyravaud [mailto:jp.puyravaud at gmail.com]
> Sent: Friday, October 21, 2011 3:15 PM
> To: 'qgis-community-team at lists.osgeo.org'
> Subject: Help for digitization
> Hi to All,
> Till recently I had no problem with several projects.
> Right now, when I digitize (points or polygons), the next item gets
> systematically stuck with the first one... I probably changed an option but
> I am unable to find out what happened.
> Thanks for your help.
> Jean-Philippe
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
