[Qgis-community-team] Q-GIS case study from Tanzania
Nick McWilliam
nmcwilliam at mapaction.org
Wed Feb 15 08:37:18 EST 2012
Hello all, and thank you for the various positive replies to my post.
Otto: great that you can create a case study. I will send you a text directly.
Giovanni: that's good news about the forthcoming shapefile field handling.
Also Giovanni: about the GPS connection, I struggled for a while to find all the correct GPSBabel commands to create a GPS new device, in this case a Garmin USB device. Indeed, for a relatively non-technical GIS user like me, it took a long time to realize that GPSBabel documentation was what I needed to look for. Something I found by trial and error was that a 'space' character in any file path would stop the GPS tool working. So, perhaps some pre-configured devices would be useful, and perhaps some more guidance in the "GPS Device Editor" window? Finally, is it possible to connect to a Garmin GPSMAP62? Oddly, this unit doesn’t seem to support Garmin comms protocol.
Cheers all -
Nick.
-----Original Message-----
From: qgis-community-team-bounces at lists.osgeo.org [mailto:qgis-community-team-bounces at lists.osgeo.org] On Behalf Of Otto Dassau
Sent: 13 February 2012 13:05
To: qgis-community-team at lists.osgeo.org
Subject: Re: [Qgis-community-team] Q-GIS case study from Tanzania
I can add the case study. Could someone, who was involved select 2 figures
and write a text, with structure and length similar to what you find in the
other already existing case studies, please?
Then send it directly to me as a zip file and I will add it this week.
Regards
Otto
Am Mon, 13 Feb 2012 12:08:56 +0000
schrieb Giovanni Manghi <giovanni.manghi at gmail.com>:
> Hi!
> On Mon, 2012-02-13 at 07:55 +0000, Nick McWilliam wrote:
> > Hello Q-GIS community team -
> > We just wanted to let you know about a successful two-day GIS training
> > session held in Tanzania last week, using Quantum GIS. Would you like to
> > use this as a case study?
> > (http://qgis.org/en/community/qgis-case-studies.html)
> this is really a nice case study! can someone add it to the QGIS page?
> I would also make another try (contacting Luiz Motta, that is a active
> member of the qgis community) to write a case study about this project
> in the Amazon forest
> http://portal.mda.gov.br/terralegal/pages/ferramentas
> > At a technical level, the one area of difficulty we encountered was with
> > direct GPS connection, so EasyGPS and MapSource were used as
> > intermediaries.
> what was the problem?
> > The Table Manager extension came to the rescue for altering and deleting
> > attribute fields - might this become part of the standard installation?
> When qgis will be compiled against gdal 1.9 (should happen soon) then it
> will be able to delete/rename shapefiles fields without the need of any
> 3rd party tool.
> cheers
> -- Giovanni --
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Davenstedter Str. 60 , D - 30453 Hannover , Germany
Phone: +49-(0)511-2615322 , Fax: +49-(0)511-2615323
More information about the Qgis-community-team
