[Qgis-community-team] automatically create substitutions for icons in global.rst
Diethard Jansen
diethard.jansen at gmail.com
Wed Jul 4 13:28:09 PDT 2012
Yes, maybe you are right.
I am finishing the replacements in an hour. It could take a few hours to
program the python program. I have seen quite a lot substitutions in
conf.py that definetely are used just in on rst. I will put all my
substitutions in top of the rst document when others find they can use it
as well it can be transferred to conf.py. I guess in the document
working_with_vector.rst you will find the majority, so just have a look
there first.
regards, Diethard.
2012/7/4 Paolo Corti <pcorti at gmail.com>
> On Wed, Jul 4, 2012 at 6:32 PM, Diethard Jansen
> <diethard.jansen at gmail.com> wrote:
> > Hi,
> > Yesterday I started with adding some substitutions for icons used in the
> RST
> > file I am working on.
> > 'working_with_vector.rst' contains many! It is not too hard but.. to
> include
> > them only in the document I am working on.
> > I found that substitutions for Icons like |nix| are defined in conf.py,
> but
> > I do not like the idea of adding the new definitions in there.
> > On the following interesting site I found an alternative way.
> http://packages.python.org/an_example_pypi_project/sphinx.html#substitutions
> > The idea:
> > I want to automatically create a global.rst using a python script to
> include
> > all substitutions to images of icons in there.
> > The script will search and include all png files < 8 kb that will be
> found
> > under directories "img/en/".
> > In the latex script most substitutions are equal to the icon name so it
> > should not be too hard to generate this file.
> > The advantage is that you only need to to include a single 'include' line
> > referring to the global.rst file and most of the icons should show up
> > immediately after the build. Another advantage is that you can remove
> most
> > of these substitions from config.py so it is less cluttered and it does
> not
> > need to be changed too often which (I believe) could break the build
> > process. It is also an easier place to find the substitutions. A
> > disadvantage could be that in a few places the reference needs to be
> changed
> > in the rst file because it was not equal to the name of the file. (i.e.
> in
> > rst file -> |labeling| however the image::
> ../img/en/mActionLabeling.png,
> > so in that case I will need to change it to |mActionLabeling|).
> > Whatever, I will write the python script. I am sure the result can also
> be
> > quickly included in the config.py instead of the global.rst.
> > Let me know when you see a problem with this idea.
> > Regards,
> > Diethard
> Hi
> the idea would be to have a common place where to store substitution
> only for images that are in many pages.
> I believe that a big part of the ones that now are in conf.py are used
> only once in the user guide, so it would make sense to me to leave in
> conf.py only the images that are used more times, and place the other
> to each single page.
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20120704/3d6048c2/attachment.html>
More information about the Qgis-community-team
